[General] Appian ACD301勉強資料、ACD301シュミレーション問題集
103
【General】 Appian ACD301勉強資料、ACD301シュミレーション問題集
Posted at 1/27/2026 03:02:33      View:239 | Replies:1        Print      Only Author   [Copy Link] 1#
2026年Jpshikenの最新ACD301 PDFダンプおよびACD301試験エンジンの無料共有:https://drive.google.com/open?id=11nuN0fMPY3HQvFWZ9YDb04RdU849R5l6
Jpshikenは、最新のACD301試験トレントが能力を強化し、ACD301試験に合格して認定を取得するのに非常に役立つと深く信じています。嫌がらせから抜け出すために、ACD301学習教材は高品質で高い合格率を備えています。ほとんどの時間インターネットにアクセスできない場合、どこかに行く必要がある場合はオフライン状態ですが、ACD301試験のために学習したい場合。当社のウェブサイトは、優れたACD301試験問題の助けを借りて問題の解決に役立ちます。
Appian ACD301 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Application Design and Development: This section of the exam measures skills of Lead Appian Developers and covers the design and development of applications that meet user needs using Appian functionality. It includes designing for consistency, reusability, and collaboration across teams. Emphasis is placed on applying best practices for building multiple, scalable applications in complex environments.
トピック 2
  • Data Management: This section of the exam measures skills of Data Architects and covers analyzing, designing, and securing data models. Candidates must demonstrate an understanding of how to use Appian’s data fabric and manage data migrations. The focus is on ensuring performance in high-volume data environments, solving data-related issues, and implementing advanced database features effectively.
トピック 3
  • Project and Resource Management: This section of the exam measures skills of Agile Project Leads and covers interpreting business requirements, recommending design options, and leading Agile teams through technical delivery. It also involves governance, and process standardization.
トピック 4
  • Proactively Design for Scalability and Performance: This section of the exam measures skills of Application Performance Engineers and covers building scalable applications and optimizing Appian components for performance. It includes planning load testing, diagnosing performance issues at the application level, and designing systems that can grow efficiently without sacrificing reliability.
最新のACD301勉強資料試験-試験の準備方法-高品質なACD301シュミレーション問題集専門的に言えば、試験を受けるに関するテクニックを勉強する必要があります。Jpshikenというサイトは素晴らしいソースサイトで、AppianのACD301の試験材料、研究材料、技術材料や詳しい解答に含まれています。問題集が提供したサイトは近年で急速に増加しています。あなたは試験の準備をするときに見当もつかないかもしれません。JpshikenのAppianのACD301試験トレーニング資料は専門家と受験生の皆様に証明された有効なトレーニング資料で、あなたが試験の合格することを助けられます。
Appian Lead Developer 認定 ACD301 試験問題 (Q27-Q32):質問 # 27
You add an index on the searched field of a MySQL table with many rows (>100k). The field would benefit greatly from the index in which three scenarios?
  • A. The field contains long unstructured text such as a hash.
  • B. The field contains a structured JSON.
  • C. The field contains a textual short business code.
  • D. The field contains many datetimes, covering a large range.
  • E. The field contains big integers, above and below 0.
正解:C、D、E
Adding an index to a searched field in a MySQL table with over 100,000 rows improves query performance by reducing the number of rows scanned during searches, joins, or filters. The benefit of an index depends on the field's data type, cardinality (uniqueness), and query patterns. MySQL indexing best practices, as aligned with Appian's Database Optimization Guidelines, highlight scenarios where indices are most effective.
Option A (The field contains a textual short business code):
This benefits greatly from an index. A short business code (e.g., a 5-10 character identifier like "CUST123") typically has high cardinality (many unique values) and is often used in WHERE clauses or joins. An index on this field speeds up exact-match queries (e.g., WHERE business_code = 'CUST123'), which are common in Appian applications for lookups or filtering.
Option C (The field contains many datetimes, covering a large range):
This is highly beneficial. Datetime fields with a wide range (e.g., transaction timestamps over years) are frequently queried with range conditions (e.g., WHERE datetime BETWEEN '2024-01-01' AND '2025-01-01') or sorting (e.g., ORDER BY datetime). An index on this field optimizes these operations, especially in large tables, aligning with Appian's recommendation to index time-based fields for performance.
Option D (The field contains big integers, above and below 0):
This benefits significantly. Big integers (e.g., IDs or quantities) with a broad range and high cardinality are ideal for indexing. Queries like WHERE id > 1000 or WHERE quantity < 0 leverage the index for efficient range scans or equality checks, a common pattern in Appian data store queries.
Option B (The field contains long unstructured text such as a hash):
This benefits less. Long unstructured text (e.g., a 128-character SHA hash) has high cardinality but is less efficient for indexing due to its size. MySQL indices on large text fields can slow down writes and consume significant storage, and full-text searches are better handled with specialized indices (e.g., FULLTEXT), not standard B-tree indices. Appian advises caution with indexing large text fields unless necessary.
Option E (The field contains a structured JSON):
This is minimally beneficial with a standard index. MySQL supports JSON fields, but a regular index on the entire JSON column is inefficient for large datasets (>100k rows) due to its variable structure. Generated columns or specialized JSON indices (e.g., using JSON_EXTRACT) are required for targeted queries (e.g., WHERE JSON_EXTRACT(json_col, '$.key') = 'value'), but this requires additional setup beyond a simple index, reducing its immediate benefit.
For a table with over 100,000 rows, indices are most effective on fields with high selectivity and frequent query usage (e.g., short codes, datetimes, integers), making A, C, and D the optimal scenarios.
質問 # 28
You have 5 applications on your Appian platform in Production. Users are now beginning to use multiple applications across the platform, and the client wants to ensure a consistent user experience across all applications.
You notice that some applications use rich text, some use section layouts, and others use box layouts. The result is that each application has a different color and size for the header.
What would you recommend to ensure consistency across the platform?
  • A. Create constants for text size and color, and update each section to reference these values.
  • B. In the common application, create a rule that can be used across the platform for section headers, and update each application to reference this new rule.
  • C. In the common application, create one rule for each application, and update each application to reference its respective rule.
  • D. In each individual application, create a rule that can be used for section headers, and update each application to reference its respective rule.
Comprehensive and Detailed In-Depth Explanation:As an Appian Lead Developer, ensuring a consistent user experience across multiple applications on the Appian platform involves centralizing reusable components and adhering to Appian's design governance principles. The client's concern about inconsistent headers (e.g., different colors, sizes, layouts) across applications using rich text, section layouts, and box layouts requires a scalable, maintainable solution. Let's evaluate each option:
* A. Create constants for text size and color, and update each section to reference these values:Using constants (e.g., cons!TEXT_SIZE and cons!HEADER_COLOR) is a good practice for managing values, but it doesn't address layout consistency (e.g., rich text vs. section layouts vs. box layouts).
Constants alone can't enforce uniform header design across applications, as they don't encapsulate layout logic (e.g., a!sectionLayout() vs. a!richTextDisplayField()). This approach would require manual updates to each application's components, increasing maintenance overhead and still risking inconsistency. Appian's documentation recommends using rules for reusable UI components, not just constants, making this insufficient.
* B. In the common application, create a rule that can be used across the platform for section headers, and update each application to reference this new rule:This is the best recommendation. Appian supports a
"common application" (often called a shared or utility application) to store reusable objects like expression rules, which can define consistent header designs (e.g., rule!CommonHeader(size:
"LARGE", color: "PRIMARY")). By creating a single rule for headers and referencing it across all 5 applications, you ensure uniformity in layout, color, and size (e.g., using a!sectionLayout() or a!
boxLayout() consistently). Appian's design best practices emphasize centralizing UI components in a common application to reduce duplication, enforce standards, and simplify maintenance-perfect for achieving a consistent user experience.
* C. In the common application, create one rule for each application, and update each application to reference its respective rule:This approach creates separate header rules for each application (e.g., rule!
App1Header, rule!App2Header), which contradicts the goal of consistency. While housed in the common application, it introduces variability (e.g., different colors or sizes per rule), defeating the purpose. Appian's governance guidelines advocate for a single, shared rule to maintain uniformity, making this less efficient and unnecessary.
* D. In each individual application, create a rule that can be used for section headers, and update each application to reference its respective rule:Creating separate rules in each application (e.g., rule!
App1Header in App 1, rule!App2Header in App 2) leads to duplication and inconsistency, as each rule could differ in design. This approach increases maintenance effort and risks diverging styles, violating the client's requirement for a"consistent user experience." Appian's best practices discourage duplicating UI logic, favoring centralized rules in a common application instead.
Conclusion: Creating a rule in the common application for section headers and referencing it across the platform (B) ensures consistency in header design (color, size, layout) while minimizing duplication and maintenance. This leverages Appian's application architecture for shared objects, aligning with Lead Developer standards for UI governance.
* Appian Documentation: "Designing for Consistency Across Applications" (Common Application Best Practices).
* Appian Lead Developer Certification: UI Design Module (Reusable Components and Rules).
* Appian Best Practices: "Maintaining User Experience Consistency" (Centralized UI Rules).
The best way to ensure consistency across the platform is to create a rule that can be used across the platform for section headers. This rule can be created in the common application, and then each application can be updated to reference this rule. This will ensure that all of the applications use the same color and size for the header, which will provide a consistent user experience.
The other options are not as effective. Option A, creating constants for text size and color, and updating each section to reference these values, would require updating each section in each application. This would be a lot of work, and it would be easy to make mistakes. Option C, creating one rule for each application, would also require updating each application. This would be less work than option A, but it would still be a lot of work, and it would be easy to make mistakes. Option D, creating a rule in each individual application, would not ensure consistency across the platform. Each application would have its own rule, and the rules could be different. This would not provide a consistent user experience.
Best Practices:
* When designing a platform, it is important to consider the user experience. A consistent user experience will make it easier for users to learn and use the platform.
* When creating rules, it is important to use them consistently across the platform. This will ensure that the platform has a consistent look and feel.
* When updating the platform, it is important to test the changes to ensure that they do not break the user experience.
質問 # 29
You need to export data using an out-of-the-box Appian smart service. Which two formats are available (or data generation?
  • A. XML
  • B. Excel
  • C. CSV
  • D. JSDN
正解:B、C
The two formats that are available for data generation using an out-of-the-box Appian smart service are:
* A. CSV. This is a comma-separated values format that can be used to export data in a tabular form, such as records, reports, or grids. CSV files can be easily opened and manipulated by spreadsheet applications such as Excel or Google Sheets.
* C. Excel. This is a format that can be used to export data in a spreadsheet form, with multiple worksheets, formatting, formulas, charts, and other features. Excel files can be opened by Excel or other compatible applications.
The other options are incorrect for the following reasons:
* B. XML. This is a format that can be used to export data in a hierarchical form, using tags and attributes to define the structure and content of the data. XML files can be opened by text editors or XML parsers, but they are not supported by the out-of-the-box Appian smart service for data generation.
* D. JSON. This is a format that can be used to export data in a structured form, using objects and arrays to represent the data. JSON files can be opened by text editors or JSON parsers, but they are not supported by the out-of-the-box Appian smart service for data generation. Verified References: Appian Documentation, section "Write to Data Store Entity" and "Write to Multiple Data Store Entities".
質問 # 30
You are developing a case management application to manage support cases for a large set of sites. One of the tabs in this application s site Is a record grid of cases, along with Information about the site corresponding to that case. Users must be able to filter cases by priority level and status.
You decide to create a view as the source of your entity-backed record, which joins the separate case/site tables (as depicted in the following Image).
Which three column should be indexed?
  • A. status
  • B. modified_date
  • C. name
  • D. case_id
  • E. priority
  • F. site_id
正解:A、E、F
Indexing columns can improve the performance of queries that use those columns in filters, joins, or order by clauses. In this case, the columns that should be indexed are site_id, status, and priority, because they are used for filtering or joining the tables. Site_id is used to join the case and site tables, so indexing it will speed up the join operation. Status and priority are used to filter the cases by the user's input, so indexing them will reduce the number of rows that need to be scanned. Name, modified_date, and case_id do not need to be indexed, because they are not used for filtering or joining. Name and modified_date are only used for displaying information in the record grid, and case_id is only used as a unique identifier for each record. Verified Reference: Appian Records Tutorial, Appian Best Practices As an Appian Lead Developer, optimizing a database view for an entity-backed record grid requires indexing columns frequently used in queries, particularly for filtering and joining. The scenario involves a record grid displaying cases with site information, filtered by "priority level" and "status," and joined via the site_id foreign key. The image shows two tables (site and case) with a relationship via site_id. Let's evaluate each column based on Appian's performance best practices and query patterns:
A . site_id:
This is a primary key in the site table and a foreign key in the case table, used for joining the tables in the view. Indexing site_id in the case table (and ensuring it's indexed in site as a PK) optimizes JOIN operations, reducing query execution time for the record grid. Appian's documentation recommends indexing foreign keys in large datasets to improve query performance, especially for entity-backed records. This is critical for the join and must be included.
B . status:
Users filter cases by "status" (a varchar column in the case table). Indexing status speeds up filtering queries (e.g., WHERE status = 'Open') in the record grid, particularly with large datasets. Appian emphasizes indexing columns used in WHERE clauses or filters to enhance performance, making this a key column for optimization. Since status is a common filter, it's essential.
C . name:
This is a varchar column in the site table, likely used for display (e.g., site name in the grid). However, the scenario doesn't mention filtering or sorting by name, and it's not part of the join or required filters. Indexing name could improve searches if used, but it's not a priority given the focus on priority and status filters. Appian advises indexing only frequently queried or filtered columns to avoid unnecessary overhead, so this isn't necessary here.
D . modified_date:
This is a date column in the case table, tracking when cases were last updated. While useful for sorting or historical queries, the scenario doesn't specify filtering or sorting by modified_date in the record grid. Indexing it could help if used, but it's not critical for the current requirements. Appian's performance guidelines prioritize indexing columns in active filters, making this lower priority than site_id, status, and priority.
E . priority:
Users filter cases by "priority level" (a varchar column in the case table). Indexing priority optimizes filtering queries (e.g., WHERE priority = 'High') in the record grid, similar to status. Appian's documentation highlights indexing columns used in WHERE clauses for entity-backed records, especially with large datasets. Since priority is a specified filter, it's essential to include.
F . case_id:
This is the primary key in the case table, already indexed by default (as PKs are automatically indexed in most databases). Indexing it again is redundant and unnecessary, as Appian's Data Store configuration relies on PKs for unique identification but doesn't require additional indexing for performance in this context. The focus is on join and filter columns, not the PK itself.
Conclusion: The three columns to index are A (site_id), B (status), and E (priority). These optimize the JOIN (site_id) and filter performance (status, priority) for the record grid, aligning with Appian's recommendations for entity-backed records and large datasets. Indexing these columns ensures efficient querying for user filters, critical for the application's performance.
Appian Documentation: "Performance Best Practices for Data Stores" (Indexing Strategies).
Appian Lead Developer Certification: Data Management Module (Optimizing Entity-Backed Records).
Appian Best Practices: "Working with Large Data Volumes" (Indexing for Query Performance).
質問 # 31
You are reviewing log files that can be accessed in Appian to monitor and troubleshoot platform-based issues.
For each type of log file, match the corresponding Information that it provides. Each description will either be used once, or not at all.
Note: To change your responses, you may deselect your response by clicking the blank space at the top of the selection list.
正解:
* design_errors.csv # Errors in start forms, task forms, record lists, enabled environments
* devops_infrastructure.csv # Metrics such as the total time spent evaluating a plug-in function
* login-audit.csv # Inbound requests using HTTP basic authentication
Comprehensive and Detailed In-Depth Explanation:Appian provides various log files to monitor and troubleshoot platform issues, accessible through the Administration Console or exported as CSV files. These logs capture different aspects of system performance, security, and user interactions. The Appian Monitoring and Troubleshooting Guide details the purpose of each log file, enabling accurate matching.
* design_errors.csv # Errors in start forms, task forms, record lists, enabled environments:The design_errors.csv log file is specifically designed to track errors related to the design and runtime behavior of Appian objects such as start forms, task forms, and record lists. It alsoincludes information about issues in enabled environments, making it the appropriate match. This log helps developers identify and resolve UI or configuration errors, aligning with its purpose of capturing design-time and runtime issues.
* devops_infrastructure.csv # Metrics such as the total time spent evaluating a plug-in function:The devops_infrastructure.csv log file provides infrastructure and performance metrics for Appian Cloud instances. It includes data on system performance, such as the time spent evaluating plug-in functions, which is critical for optimizing custom integrations. This matches the description, as it focuses on operational metrics rather than errors or security events, consistent with Appian's infrastructure monitoring approach.
* login-audit.csv # Inbound requests using HTTP basic authentication:The login-audit.csv log file tracks user authentication and login activities, including details about inbound requests using HTTP basic authentication. This log is used to monitor security events, such as successful and failed login attempts, making it the best fit for this description. Appian's security logging emphasizes audit trails for authentication, aligning with this use case.
Unused Description:
* Number of enabled environments:This description is not matched to any log file. While it could theoretically relate to system configuration logs, none of the listed files (design_errors.csv, devops_infrastructure.csv, login-audit.csv) are specifically designed to report the number of enabled environments. This might be tracked in a separate administrative report or configuration log not listed here.
Matching Rationale:
* Each description is either used once or not at all, as specified. The matches are based on Appian's documented log file purposes: design_errors.csv for design-related errors, devops_infrastructure.csv for performance metrics, and login-audit.csv for authentication details.
* The unused description suggests the question allows for some descriptions to remain unmatched, reflecting real-world variability in log file content.
References:Appian Documentation - Monitoring and Troubleshooting Guide, Appian Administration Console - Log File Reference, Appian Lead Developer Training - Platform Diagnostics.
質問 # 32
我々Jpshikenは最高のアフターサービスを提供いたします。AppianのACD301試験ソフトを買ったあなたは一年間の無料更新サービスを得られて、AppianのACD301の最新の問題集を了解して、試験の合格に自信を持つことができます。あなたはAppianのACD301試験に失敗したら、弊社は原因に関わらずあなたの経済の損失を減少するためにもらった費用を全額で返しています。
ACD301シュミレーション問題集: https://www.jpshiken.com/ACD301_shiken.html
P.S.JpshikenがGoogle Driveで共有している無料の2026 Appian ACD301ダンプ:https://drive.google.com/open?id=11nuN0fMPY3HQvFWZ9YDb04RdU849R5l6
Posted at 2/12/2026 04:31:57        Only Author  2#
當您對我們的SAP C_BCBAI_2509考古題感到滿意的時候,趕快購買吧,付款之后,無需等待,你可以立刻獲得你所購買的C_BCBAI_2509考古題。雖然我們的C_BCBAI_2509考古題通過率高達98%,但是我們有退款保證來保護客戶的利益,如果您的C_BCBAI_2509考試失敗了,我們退還你的購買費用,所有考生可以放心購買。選擇SAP C_BCBAI_2509考古題可以保證你可以在短時間內增強考試知識,并順利高分通過考試。
