[General] New HP HPE7-A01 Exam Book - HPE7-A01 Related Certifications
103
【General】 New HP HPE7-A01 Exam Book - HPE7-A01 Related Certifications
Posted at 2/15/2026 00:03:06      View:137 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE7-A01 dumps are available on Google Drive shared by PassExamDumps: https://drive.google.com/open?id=1AjnT5nn1NEzUkHnQkLBlxmsodtfXLvrc
With regard to the Internet, if you use our HPE7-A01 study materials in a network environment, then you can use our products in a non-network environment. HPE7-A01 learning guide guarantee that you can make full use of all your free time to learn, if you like. The reason why we emphasize this is that we know you have a lot of other things to do. Many users stated that they can only use fragmented time to learn. Experts at HPE7-A01 practice prep also fully considered this point.
To prepare for the HPE7-A01 certification exam, candidates can take advantage of a variety of resources, including Aruba training courses, study guides, and practice exams. Aruba offers a number of training courses that cover topics related to wireless networking and network design. These courses are designed to help candidates prepare for the HPE7-A01 Certification Exam.
HPE7-A01 Related Certifications, HPE7-A01 Valid Cram MaterialsOur company conducts our HPE7-A01 real questions as high quality rather than unprincipled company which just cuts and pastes content into their materials and sells them to exam candidates. We have always been the vanguard of this field over ten years. It means we hold the position of supremacy of HPE7-A01 practice materials by high quality and high accuracy. Besides, all exam candidates who choose our HPE7-A01 real questions gain unforeseen success in this exam, and continue buying our HPE7-A01 practice materials when they have other exam materials’ needs. It is our running tenet to offer the most considerate help and services for exam candidates just like you. By virtue of our HPE7-A01 study tool, many customers get comfortable experiences of whole package of services and of course passing the HPE7-A01 exam successfully.
HP HPE7-A01 exam, also known as the Aruba Certified Campus Access Professional exam, is a certification exam designed for IT professionals who want to validate their skills and knowledge in implementing and configuring Aruba wireless and wired networks. Aruba Certified Campus Access Professional Exam certification is ideal for IT professionals who work with small to medium-sized enterprise networks and want to excel in their careers.
HP HPE7-A01 certification exam is an excellent opportunity for IT professionals who want to validate their knowledge and skills in Aruba campus access solutions. Aruba Certified Campus Access Professional Exam certification exam covers a wide range of topics related to Aruba networks, and it is designed to test the candidate's ability to design, deploy, and maintain secure and reliable networks. The HPE7-A01 Exam is an online, proctored exam that can be taken at any time from any location, and it leads to the Aruba Certified Campus Access Professional (ACCP) certification.
HP Aruba Certified Campus Access Professional Exam Sample Questions (Q112-Q117):NEW QUESTION # 112
Match the topics with the underlying technologies (Options may be used more than once or not at all.)
NEW QUESTION # 113
Two AOS-CX switches are configured with VSX at the the Access-Aggregation layer where servers attach to them An SVI interface is configured for VLAN 10 and serves as the default gateway for VLAN 10. The ISL link between the switches fails, but the keepalive interface functions. Active gateway has been configured on the VSX switches.
What is correct about access from the servers to the Core? (Select two.)
  • A. Server 1 can access the core layer via the keepalrve link
  • B. Server 1 and Server 2 can communicate with each other via the core layer
  • C. Server 2 can access the core layer via the keepalive link
  • D. Server 1 can access the core layer on only one uplink
  • E. Server 1 can access the core layer via both uplinks
  • F. Server 2 cannot access the core layer.
Answer: B,E
These are the correct statements about access from the servers to the Core when the ISL link between the switches fails, but the keepalive interface functions. Server 1 can access the core layer via both uplinks because it is connected to VSX-A, which is still active for VLAN 10. Server 2 can also access the core layer via its uplink to VSX-B, which is still active for VLAN 10 because of Active Gateway feature. Server 1 and Server 2 can communicate with each other via the core layer because they are in the same VLAN and subnet, and their traffic can be routed through the core switches. The other statements are incorrect because they either describe scenarios that are not possible or not relevant to the question. References:
https://www.arubanetworks.com/te ... TML/5200-6728/bk01-
NEW QUESTION # 114
When configuring UBT on a switch what will happen when a gateway role is not specified?
  • A. The gateway will assign a default role to the client
  • B. The switch will assign the default deny role to the client.
  • C. The gateway will send back the deny role to the client.
  • D. The switch will put the client on the access VLAN
According to the Aruba Documentation Portal1, user-based tunneling (UBT) is a feature that uses GRE to tunnel ingress traffic on a switch interface to a gateway for further processing. UBT enables a switch to provide a centralized security policy, using per-user authentication and access control to ensure consistent access and permissions.
Option A: The switch will put the client on the access VLAN This is because option A shows how UBT works on an Aruba switch. When a device connects to the network, it is authenticated using either MAC Authentication or 802.1X and triggers an enforcement policy from ClearPass, which contains an enforcement profile with a user role configuration. The user role can be assigned locally on the switch or on ClearPass as part of an enforcement profile. The user role determines the VLAN that the device belongs to and the access policies that apply to it.
NEW QUESTION # 115
Which statements regarding 0SPFv2 route redistribution are true for Aruba OS CX switches?
(Select two.)
  • A. The "redistribute ospf" command will redistribute routes from all OSPF V2 and V3 processes
  • B. The "redistribute static route-map connected-routes" command will redistribute all static routes with a matching permit in the route map "connected-routes-
  • C. The "redistribute static route-map connected-routes" command will redistribute all static routes without a matching deny in the route map "connected-routes".
  • D. The "redistribute connected" command will redistribute all connected routes for the switch except local loopback addresses.
  • E. The "redistribute connected" command will redistribute all connected routes for the switch including local loopback addresses
Answer: B,E
These are two correct statements regarding OSPFv2 route redistribution for Aruba OS CX switches. Route redistribution is a process that allows routes from one routing protocol or source to be injected into another routing protocol or destination. OSPFv2 is a link-state routing protocol that supports route redistribution from various sources, such as connected, static, BGP, etc. The
"redistribute connected" command will redistribute all connected routes for the switch, including local loopback addresses, into OSPFv2. The "redistribute static route-map connected-routes" command will redistribute all static routes that have a matching permit statement in the route map named "connected-routes" into OSPFv2. The other statements are incorrect because they either do not reflect the correct behavior of route redistribution commands or do not exist as valid commands.
NEW QUESTION # 116
You need to ensure that voice traffic sent through an ArubaOS-CX switch arrives with minimal latency What is the best scheduling technology to use for this task?
  • A. Rate limiting
  • B. QoS shaping
  • C. DWRR queuing
  • D. Strict queuing
Strict queuing is the best scheduling technology to use for voice traffic on an AOS-CX switch. Scheduling is a mechanism that determines how packets are transmitted from different queues on an egress port. Strict queuing is a scheduling method that gives the highest priority queue absolute preference over all other queues, regardless of their size or utilization. Voice traffic should be assigned to the highest priority queue and scheduled with strict queuing to ensure minimal latency and jitter. The other options are incorrect because they are either not scheduling methods or not optimal for voice traffic. References:
https://www.arubanetworks.com/te ... 6728/bk01-ch02.html
https://www.arubanetworks.com/te ... 6728/bk01-ch03.html
NEW QUESTION # 117
HPE7-A01 Related Certifications: https://www.passexamdumps.com/HPE7-A01-valid-exam-dumps.html
P.S. Free 2026 HP HPE7-A01 dumps are available on Google Drive shared by PassExamDumps: https://drive.google.com/open?id=1AjnT5nn1NEzUkHnQkLBlxmsodtfXLvrc
Posted at 2/20/2026 23:26:10        Only Author  2#
Thank you for your article; it was truly stunning! Here are the free SC-300 Pdf braindumps materials. Best of luck to everyone!
