2026 Exam 1Z0-182 Tips | Efficient Oracle 1Z0-182: Oracle Database 23ai Administ
61
Posted at 2/13/2026 23:08:09      View118 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest ExamTorrent 1Z0-182 PDF Dumps and 1Z0-182 Exam Engine Free Share: https://drive.google.com/open?id=1ftzKHo-moxC8jEdfEDJN7wJXF-dlFCI_
Life of future will definitely be much more easy and convenient than the life of today, it is not late whenever you want to work as an IT engine. Our 1Z0-182 exam questions and answers help you realize your dream easily. We ExamTorrent offer the top-class exam materials similar with the real test. 1Z0-182 Exam Questions And Answers assist people to master the real test questions and key knowledge so that candidates will fell easy and casual in real test so that they can clear exams and obtain a Oracle certification certainly.
Often candidates fail the 1Z0-182 exam due to the fact that they do not know the tactics of attempting the Oracle Database 23ai Administration Associate (1Z0-182) exam in an ideal way. The decisive part is often effective time management. Some Oracle 1Z0-182 Exam Questions demand more attention than others, which disturbs the time allotted to each topic. The best way to counter them is to use an updated 1Z0-182 Dumps.
Free PDF 2026 Oracle Updated Exam 1Z0-182 TipsOur App online version of 1Z0-182 study materials, it is developed on the basis of a web browser, as long as the user terminals on the browser, can realize the application which has applied by the 1Z0-182 simulating materials of this learning model, users only need to open the App link, you can quickly open the learning content in real time in the ways of the 1Z0-182 Exam Guide, can let users anytime, anywhere learning through our App, greatly improving the use value of our 1Z0-182 exam prep.
Oracle Database 23ai Administration Associate Sample Questions (Q60-Q65):NEW QUESTION # 60
Script abc.sql must be executed to perform a certain task. User HR with password HR exists in the target database and the account is unlocked. The TNSNAMES.ORA file is up to date. Examine this command attempted by the user: $ sqlplus hr/hr@orcl @abc. What will happen and why?
  • A. The command succeeds and HR will be connected to the orcl database and after logging out to the abc database.
  • B. The command fails and reports an error because @ is used twice.
  • C. The command succeeds and HR will be connected to the orcl database instance, and the abc script will be executed.
  • D. The command fails because the script must refer to the full path name.
  • E. The command succeeds and HR will be connected to the orcl database instance, and the abc script will be executed.
Answer: E
A .False. "Logging out to the abc database" is nonsensical; abc is a script, not a database.
B .False. SQL*Plus finds abc.sql in the current directory by default; a full path isn't required unless it's elsewhere.
C .False. The first @ specifies the TNS alias (orcl), the second runs the script (@abc); this is valid syntax.
D & E.True (identical options). The command connects to orcl via TNSNAMES.ORA, authenticates HR, and executes abc.sql.
Mechanics:sqlplus hr/hr@orcl resolves orcl to a listener address, connects, and@abc runs the script post-login.
NEW QUESTION # 61
Which three statements are true about the Oracle Database server during and immediately after SHUTDOWN TRANSACTIONAL?
  • A. Uncommitted transactions are allowed to continue to the next COMMIT.
  • B. Instance recovery occurs automatically during the shutdown.
  • C. Sessions remain connected even if they are not running a transaction.
  • D. Uncommitted transactions are allowed to continue to the next ROLLBACK.
  • E. New connection requests made to the database instance are refused.
Answer: A,C,E
A .False. Recovery happens on startup, not shutdown.
B .False. TRANSACTIONAL waits for commits or rollbacks, then disconnects.
C .True. New connections are blocked during shutdown.
D .True. Inactive sessions persist until shutdown completes.
E .True. Active transactions can commit before disconnection.
NEW QUESTION # 62
Which three statements are true about dynamic performance views?
  • A. Data displayed by querying dynamic performance views is derived from metadata in the data dictionary.
  • B. They are owned by the SYSTEM user.
  • C. Read consistency is not guaranteed.
  • D. They can be queried only when the database is open.
  • E. V$FIXED_TABLE can be queried to display the names of all dynamic performance views.
Answer: A,C,E
A .True. V$ views reflect real-time memory data, not consistent snapshots.
B .True. V$FIXED_TABLE lists all V$ views.
C .True. Data comes from memory structures and data dictionary metadata.
D .False. Owned by SYS, not SYSTEM.
E .False. Some V$ views are accessible in MOUNT state.
NEW QUESTION # 63
Which two are benefits of external tables?
  • A. They support UPDATEs, which transparently updates records in the file system as if they were table rows.
  • B. The results of a complex join or aggregating function or both can be unloaded to a file for transportation to other systems.
  • C. They support DELETEs, which transparently deletes records in the file system as if they were table rows.
  • D. They can be queried, transformed, and joined with other tables without having to load the data first.
  • E. They can be queried while the database is in the MOUNT state like dynamic performance views.
A .False. External tables are read-only; no DELETE.
B .False. Require OPEN state, unlike V$ views.
C .False. No UPDATE support; read-only.
D .True. Queryable like regular tables without loading.
E .True. Data Pump can unload query results to files.
NEW QUESTION # 64
Which two statements are true concerning logical and physical database structures?
  • A. Segments can span multiple tablespaces.
  • B. A segment might have only one extent.
  • C. A segment's blocks can be of different sizes.
  • D. A segment can span multiple data files in some tablespaces.
  • E. A segment's blocks can be of different sizes.
  • F. All tablespaces may have one or more data files.
False. All blocks in a segment use the tablespace's block size (e.g., 8KB). While a database can have tablespaces with different block sizes (e.g., 8KB, 32KB), a single segment's blocks are uniform, as it resides in one tablespace.
Logical structures (e.g., segments, extents) map to physical structures (e.g., data files, blocks). Let's dissect each option:
A : A segment can span multiple data files in some tablespaces.
True. A segment (e.g., a table or index) is a logical entity stored in a tablespace. In a smallfile tablespace (default in Oracle), a segment's extents can span multiple data files if the tablespace has multiple files and space allocation requires it. This is common in large tables or when autoextend adds new files.
Mechanics:Oracle allocates extents across available data files in a round-robin fashion (with ASSM) or as needed, ensuring the segment's data is distributed. This doesn't apply to bigfile tablespaces, which use a single data file.
Example:A 10GB table in a tablespace with two 5GB data files will span both.
B : Segments can span multiple tablespaces.
False. A segment is confined to a single tablespace. Oracle enforces this to maintain logical separation (e.g., a table's data stays in its assigned tablespace). Partitioned tables can have partitions in different tablespaces, but each partition is a separate segment.
Why Not:The segment header and extent map reside in one tablespace, preventing cross-tablespace spanning for a single segment.
C : A segment might have only one extent.
True. A segment starts with one extent upon creation (e.g., a small table or index). If no further growth occurs, it remains a single-extent segment. This is common with small objects or when INITIAL extent size suffices.
Mechanics:In locally managed tablespaces (default), the initial extent is allocated based on INITIAL or tablespace defaults (e.g., 64KB), and additional extents are added only as needed.
D : All tablespaces may have one or more data files.
False. Bigfile tablespaces are restricted to one data file (up to 128TB). Smallfile tablespaces (traditional) can have multiple data files (up to 1022), but the "all" phrasing makes this false due to bigfile exceptions.
Clarification:The question's intent may assume smallfile tablespaces, but Oracle 23ai supports both types.
NEW QUESTION # 65
Using our 1Z0-182 practice engine may be the most important step for you to improve your strength. You know, like the butterfly effect, one of your choices may affect your life. And our 1Z0-182 exam questions are definitely the exact effect that will change your life. In fact, our 1Z0-182 Study Materials have been tested and proved to make it. Many of our customers gave our feedbacks to say that our 1Z0-182 training guide helped them lead a better life and brighter future.
Practice 1Z0-182 Exams Free: https://www.examtorrent.com/1Z0-182-valid-vce-dumps.html
Oracle Exam 1Z0-182 Tips Our amazing data saving assures your data satisfaction guarantee and keeps your privacy fully locked and protected, Oracle Exam 1Z0-182 Tips A: Our material includes the best features similar to those included in many other sites, compiled by the same dedicated experts who have come together to offer an integrated solution, The Oracle Database 23ai Administration Associate (1Z0-182) certification exam can play a significant role in career success.
To prevent an item from starting automatically in the future, right-click 1Z0-182 the entry and select Delete from the shortcut menu, To end processes in Windows, use the Task Manager or the `taskkill` command.
Free PDF Quiz Oracle - Valid Exam 1Z0-182 TipsOur amazing data saving assures your data satisfaction Dumps 1Z0-182 Questions guarantee and keeps your privacy fully locked and protected, A: Our material includes the bestfeatures similar to those included in many other sites, Dumps 1Z0-182 Questions compiled by the same dedicated experts who have come together to offer an integrated solution.
The Oracle Database 23ai Administration Associate (1Z0-182) certification exam can play a significant role in career success, Are you preparing for the Oracle 1Z0-182 certification exam?
you should have a credit card.
