[General] C_THR81_2505시험내용 - C_THR81_2505인기Nj
85
【General】 C_THR81_2505시험내용 - C_THR81_2505인기Nj
Posted at 2/19/2026 21:08:42      View:163 | Replies:1        Print      Only Author   [Copy Link] 1#
그 외, ExamPassdump C_THR81_2505 시험 문제집 일부가 지금은 무료입니다: https://drive.google.com/open?id=1VcXzIHxLid50joRJNsbFwwH6Wjgbq8zf
ExamPassdump에서 제공해드리는 SAP인증 C_THR81_2505덤프는 가장 출중한SAP인증 C_THR81_2505시험전 공부자료입니다. 덤프품질은 수많은 IT인사들로부터 검증받았습니다. SAP인증 C_THR81_2505덤프뿐만아니라 ExamPassdump에서는 모든 IT인증시험에 대비한 덤프를 제공해드립니다. IT인증자격증을 취득하려는 분들은ExamPassdump에 관심을 가져보세요. 구매의향이 있으시면 할인도 가능합니다. 고득점으로 패스하시면 지인분들께 추천도 해주실거죠?
SAP C_THR81_2505 시험요강:
주제소개
주제 1
  • Position Management: This section of the exam evaluates the knowledge of SAP Consultants in configuring and managing Position Management functionality. It focuses on understanding position hierarchy, relationship assignments, and synchronization with job information. Candidates are assessed on how effectively they support organizational planning through accurate position data setup and integration with other SAP modules.
주제 2
  • Scenario 1: HR Transaction Rules: This section of the exam tests the proficiency of HRIS Analysts in applying HR transaction rules within the system. It focuses on the creation and use of business rules for automating actions, enforcing data accuracy, and streamlining HR processes. Candidates demonstrate the ability to define rule contexts and apply logic relevant to specific HR transactions.
주제 3
  • Scenario 2: Approvals for Self-Service: This section of the exam assesses the competency of SAP Consultants in configuring self-service approval workflows. It covers the setup of dynamic approval chains and ensures policy compliance for employee-initiated actions. The focus is on enabling seamless and scalable workflow automation tailored to organizational structures and user roles.
주제 4
  • Employee Central Core: This section of the exam measures the skills of HRIS Analysts and covers the essential components of the SAP SuccessFactors Employee Central Core module. It assesses the ability to configure foundational system features, including data models, business rules, event reasons, and workflows. Emphasis is placed on navigating the core employee data lifecycle, managing personal and employment information, and maintaining organizational structure within Employee Central.
시험대비 C_THR81_2505시험내용 최신버전 덤프데모문제 다운받기SAP인증 C_THR81_2505시험을 패스하여 자격증을 취득하여 승진이나 이직을 꿈구고 있는 분이신가요? 이 글을 읽게 된다면SAP인증 C_THR81_2505시험패스를 위해 공부자료를 마련하고 싶은 마음이 크다는것을 알고 있어 시장에서 가장 저렴하고 가장 최신버전의 SAP인증 C_THR81_2505덤프자료를 강추해드립니다. 높은 시험패스율을 자랑하고 있는SAP인증 C_THR81_2505덤프는 여러분이 승진으로 향해 달리는 길에 날개를 펼쳐드립니다.자격증을 하루 빨리 취득하여 승진꿈을 이루세요.
최신 SAP Certified Associate C_THR81_2505 무료샘플문제 (Q34-Q39):질문 # 34
How do you create country/region-specific fields (CSF) for a country that does NOT have pre- delivered Legal Entity CSF fields? Note: There are 3 correct answers to this question.
  • A. Create a new generic object.
  • B. Update the field criteria of the association.
  • C. Create a composite association on the new generic object to Legal Entity.
  • D. Update the condition and condition values of the association.
  • E. Create a composite association to the new generic object on Legal Entity.
정답:A,B,E
설명:
To create country/region-specific fields (CSF) for a country that does not have pre-delivered Legal Entity CSF fields, follow these steps:
Create a New Generic Object: Develop a new generic object to define the specific fields required for the country/region. This object will store the additional data fields pertinent to the Legal Entity.
Create a Composite Association to the New Generic Object on Legal Entity: Establish a composite association from the Legal Entity to the newly created generic object. This association links the Legal Entity to the country/region-specific fields, enabling the system to recognize and utilize these fields appropriately.
Update the Field Criteria of the Association: Modify the field criteria within the association to ensure that the new fields are correctly associated with the Legal Entity. This step involves setting conditions that determine when the new fields are applicable, based on factors such as country/region.
These steps align with the standard procedures for extending the data model in SAP SuccessFactors Employee Central to accommodate country/region-specific requirements.
질문 # 35
An HR admin/Global Mobility person must create a transfer for an employee. The employee will be moving from Position A in Team A to Position B in Team B. Both managers will have to approve the transfer.
How do you configure a two-step workflow so that the approval goes first to the current manager and second to the future manager?
  • A. By selecting in Step 1. Position Relationship - Parent Parent Position - Source
    *By selecting in Step 2: Position Relationship - Parent Position - Target
  • B. By selecting in Step 1. Role-Manager - Source
    *By selecting in Step 2: Role - Manager - Target
  • C. By selecting in Step 1: Role - Manager - Source
    *By selecting in Slep 2. Role-Manager Manager - Target
  • D. By selecting in Step 1: Role - Self-Source
    *By selecting in Step 2. Role- Manager - Target
정답:B
설명:
To configure a two-step workflow where the approval first goes to the current manager and then to the future manager, you must set the following in the workflow:
* Step 1: Role - Manager - Source (current manager of the employee).
* Step 2: Role - Manager - Target (future manager of the employee).This setup ensures that the workflow sequentially routes approval to both the current and future managers.
질문 # 36
You have updated several position departments using Import and Export data, but the incumbent's data still shows the previous information for the department hris-field.
What are some possible causes for this data inconsistency? Note: There are 2 correct answers to this question.
  • A. The technicalParameters value has NOT been set to SYNC in the position records.
  • B. The technicalParameters column with a value of SYNC has NOT been included in the import file.
  • C. The business rule to sync data changes sets the Job Information.Department to be equal to Job Information.Position.Department.
  • D. The business rule to sync data changes sets the Position Department to be equal to Job Information.Department.
정답:B,D
설명:
B . The technicalParameters column with a value of SYNC has NOT been included in the import file:
When importing position data, the technicalParameters column with the value "SYNC" must be included to ensure that changes to position attributes are synchronized to the incumbent's data.
C . The business rule to sync data changes sets the Position Department to be equal to Job Information.Department:
If the rule is incorrectly configured, the department field on the incumbent's job information may not update as expected. The correct configuration should align the position department with the incumbent's job information.
These factors contribute to discrepancies between position and incumbent data.
질문 # 37
Which object supports &&NO_OVERWRITE&& in imports? Note: There are 2 correct answers to this question.
  • A. Job Relationships
  • B. Employment Details
  • C. Job History
  • D. Addresses
정답:B,C
설명:
The &&NO_OVERWRITE&& operator is supported in imports for:
A . Job History
This ensures that existing job history records are not overwritten during imports.
D . Employment Details
Employment details such as hire dates or termination records can also be preserved using this operator.
Job Relationships and Addresses do not support the &&NO_OVERWRITE&& operator.
질문 # 38
How do you trigger a business rule to populate the Standard Hours field from Legal Entity records in the Add New Employee wizard?
  • A. Event Type: onInit; Base Object: Standard Hours
  • B. Event Type: onEdit; Base Object: Employee Information
  • C. Event Type: onChange; Base Object: Employee Information
  • D. Event Type: onSave: Base Object: Legal Entity
정답:A
설명:
To populate the Standard Hours field from Legal Entity records in the Add New Employee wizard, the business rule should be configured with:
Event Type: onInit
This event triggers the rule during the initialization phase of the Add New Employee wizard.
The rule applies to the Standard Hours field, pulling data from the Legal Entity record.
Other event types such as onChange, onEdit, or onSave are not appropriate for pre-populating fields during the Add New Employee process.
질문 # 39
ExamPassdump의SAP인증 C_THR81_2505덤프는 고객님의 IT인증자격증을 취득하는 소원을들어줍니다. IT업계에 금방 종사한 분은 자격증을 많이 취득하여 자신만의 가치를 업그레이드할수 있습니다. ExamPassdump의SAP인증 C_THR81_2505덤프는 실제 시험문제에 대비하여 연구제작된 퍼펙트한 시험전 공부자료로서 시험이 더는 어렵지 않게 느끼도록 편하게 도와드립니다.
C_THR81_2505인기덤프: https://www.exampassdump.com/C_THR81_2505_valid-braindumps.html
참고: ExamPassdump에서 Google Drive로 공유하는 무료, 최신 C_THR81_2505 시험 문제집이 있습니다: https://drive.google.com/open?id=1VcXzIHxLid50joRJNsbFwwH6Wjgbq8zf
Posted at 2/24/2026 07:18:28        Only Author  2#
This article is absolutely excellent, I’m grateful for your share. I’m giving away the Advanced-Administrator new practice questions sheet test resources for free. Good luck!
