[General] Latest NCM-MCI-6.10 Pass4sure Pdf & NCM-MCI-6.10 Free Demo & NCM-MCI-6.1
114
【General】 Latest NCM-MCI-6.10 Pass4sure Pdf & NCM-MCI-6.10 Free Demo & NCM-MCI-6.1
Posted at 2/14/2026 13:31:10      View:111 | Replies:0        Print      Only Author   [Copy Link] 1#
After purchasing our NCM-MCI-6.10 exam questions, we provide email service and online service you can contact us any time within one year. Also we provide one year free updates of NCM-MCI-6.10 learning guide if we release new version in one year, our system will send the link of the latest version of our NCM-MCI-6.10 training braindump to your email box for your downloading. It is free of charge. And you can save a lot of time and money for our updates of NCM-MCI-6.10 study guide. We make sure that you will have a happy free-shopping experience.
You may want to own a NCM-MCI-6.10 certificate to prove that you are competent and boost excellent practical abilities in some certain area. Thus you will be regarded as the capable people and be respected. Passing the test NCM-MCI-6.10 certification can help you realize your goals and if you buy our NCM-MCI-6.10 Guide Torrent you will pass the NCM-MCI-6.10 exam easily. Our NCM-MCI-6.10 exam questions are written by the most professional experts, so the quality of our NCM-MCI-6.10 learning material is wonderful. And we always keep our NCM-MCI-6.10 study guide the most updated for you to pass the exam.
NCM-MCI-6.10 Online Lab Simulation & NCM-MCI-6.10 Updated Study Material & NCM-MCI-6.10 Pdf Test TrainingOur NCM-MCI-6.10 real quiz boosts 3 versions: the PDF, the Softwate and the APP online which will satisfy our customers by their varied functions to make you learn comprehensively and efficiently. The learning of our NCM-MCI-6.10 study materials costs you little time and energy and we update them frequently. We can claim that you will be ready to write your exam after studying with our NCM-MCI-6.10 Exam Guide for 20 to 30 hours. To understand our NCM-MCI-6.10 learning questions in detail, just come and try!
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q31-Q36):NEW QUESTION # 31
Task 13
An administrator found a CentOS VM, Cent_Down, on the cluster with a corrupted network stack. To correct the issue, the VM will need to be restored from a previous snapshot to become reachable on the network again.
VM credentials:
Username: root
Password: nutanix/4u
Restore the VM and ensure it is reachable on the network by pinging 172.31.0.1 from the VM.
Power off the VM before proceeding.
See the Explanation for step by step solution.
To restore the VM and ensure it is reachable on the network, you can follow these steps:
Log in to the Web Console of the cluster where the VM is running.
Click on Virtual Machines on the left menu and find Cent_Down from the list. Click on the power icon to power off the VM.
Click on the snapshot icon next to the power icon to open the Snapshot Management window.
Select a snapshot from the list that was taken before the network stack was corrupted. You can use the date and time information to choose a suitable snapshot.
Click on Restore VM and confirm the action in the dialog box. Wait for the restore process to complete.
Click on the power icon again to power on the VM.
Log in to the VM using SSH or console with the username and password provided.
Run the command ping 172.31.0.1 to verify that the VM is reachable on the network. You should see a reply from the destination IP address.
Go to VMS from the prism central gui
Select the VMand go to More -> Guest Shutdown
Go to Snapshots tab and revert to latest snapshot available
power on vm and verify if ping is working
NEW QUESTION # 32
Due to new security requirements, an administrator has been tasked with updating the security settings for user accounts within Prism Element on Cluster 1.
An SSL Certificate Signing Request with Subject Alternative Name should be generated for submission to the security team's Certificate Authority with the following details:
countryName = US
stateOrProvinceName = North Carolina
localityName = Durham
organizationName = ACME
organizationalUnitName = Infrastructure
commonName = prism_element.ACME.org
emailAddress = administrator@ACME.org
Alternate names = cvm1.ACME.org, cvm2.ACME.org, cvm3.ACME.org
Encryption: RSA 2048, sha256
When the Certificate Signing Request is generated, place a copy of both the .cnf file and the .csr file on the desktop named 'prism_element_acme.cnf' and 'prism_element_acme.csr' Save a copy of the command(s) used for this scenario to a new file on the desktop named "Task 5.txt".
Note: You must copy and paste the command(s) and output from SSH to the "Task 5.txt" file to achieve all points available.
See the Explanation below for detailed answer.
Here is the step-by-step solution to generate the Certificate Signing Request (CSR) on Cluster 1.
This entire process is performed from an SSH session connected to a CVM (Controller VM) on Cluster 1.
1. Access Cluster 1 CVM
* From Prism Central, navigate to Hardware > Clusters and click on Cluster 1 to open its Prism Element (PE) interface.
* In the Cluster 1 PE, navigate to Hardware > CVMs to find the IP address of any CVM in the cluster.
* Use an SSH client (like PuTTY) to connect to the CVM's IP address.
* Log in with the admin user and password.
2. Create the Configuration File (.cnf)
To include the Subject Alternative Names (SANs), you must first create a configuration file.
* In the CVM's command line, create the .cnf file using a text editor:
vi prism_element_acme.cnf
* Press i to enter "Insert" mode.
* Paste the following text exactly into the editor:
Ini, TOML
[ req ]
default_bits = 2048
distinguished_name = req_distinguished_name
req_extensions = v3_req
prompt = no
[ req_distinguished_name ]
C = US
ST = North Carolina
L = Durham
O = ACME
OU = Infrastructure
CN = prism_element.ACME.org
[ v3_req ]
subjectAltName = @alt_names
[ alt_names ]
DNS.1 = cvm1.ACME.org
DNS.2 = cvm2.ACME.org
DNS.3 = cvm3.ACME.org
* Press Esc to exit "Insert" mode, then type :wq and press Enter to save and quit vi.
3. Generate the CSR and Key
* Run the following openssl command. This command uses the .cnf file to generate the new CSR (.csr) and a corresponding private key (.key), applying the sha256 encryption as requested.
Bash
openssl req -new -nodes -out prism_element_acme.csr -keyout prism_element_acme.key -config prism_element_acme.cnf -sha256
* The command will output the following, confirming the key generation:
* Generating a 2048 bit RSA private key
* writing new private key to 'prism_element_acme.key'
4. Save Files to the Desktop
You will now copy the contents of the generated files from the CVM to your desktop.
* For Task 5.txt (Commands and Output):
* Open a new Notepad file on the desktop.
* Copy and paste all the commands you ran in the SSH session and their full output (as shown in steps 2 and 3) into this file.
* Save the file on the desktop as Task 5.txt.
* For prism_element_acme.cnf:
* In the CVM SSH session, display the file's content:
cat prism_element_acme.cnf
* Copy the entire text output (starting from [ req ]).
* Paste the content and save the file as prism_element_acme.cnf.
* For prism_element_acme.csr:
cat prism_element_acme.csr
* Copy the entire text output, including the -----BEGIN CERTIFICATE REQUEST----- and ----- END CERTIFICATE REQUEST----- lines.
* Open a new C:UsersadminDesktopNotepad file on the desktop.
* Paste the content and save the file as prism_element_acme.csr.
NEW QUESTION # 33
Task 12
The application team is reporting performance degradation for a business-critical application that runs processes all day on Saturdays.
The team is requesting monitoring or processor, memory and storage utilization for the three VMs that make up the database cluster for the application: ORA01, ORA02 and ORA03.
The report should contain tables for the following:
At the cluster level, only for the current cluster:
The maximum percentage of CPU used
At the VM level, including any future VM with the prefix ORA:
The maximum time taken to process I/O Read requests
The Maximum percentage of time a VM waits to use physical CPU, out of the local CPU time allotted to the VM.
The report should run on Sundays at 12:00 AM for the previous 24 hours. The report should be emailed to appdev@cyberdyne.net when competed.
Create a report named Weekends that meets these requirements
Note: You must name the report Weekends to receive any credit. Any other objects needed can be named as you see fit. SMTP is not configured.
To create a report named Weekends that meets the requirements, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and click on Create Report.
Enter Weekends as the report name and a description if required. Click Next.
Under the Custom Views section, select Data Table. Click Next.
Under the Entity Type option, select Cluster. Click Next.
Under the Custom Columns option, add the following variable: CPU Usage (%). Click Next.
Under the Aggregation option for CPU Usage (%), select Max. Click Next.
Under the Filter option, select Current Cluster from the drop-down menu. Click Next.
Click on Add to add this custom view to your report. Click Next.
Under the Custom Views section, select Data Table again. Click Next.
Under the Entity Type option, select VM. Click Next.
Under the Custom Columns option, add the following variables: Name, I/O Read Latency (ms), VM Ready Time (%). Click Next.
Under the Aggregation option for I/O Read Latency (ms) and VM Ready Time (%), select Max. Click Next.
Under the Filter option, enter ORA* in the Name field. This will include any future VM with the prefix ORA.
Click Next.
Under the Report Settings option, select Weekly from the Schedule drop-down menu and choose Sunday as the day of week. Enter 12:00 AM as the time of day. Enter appdev@cyberdyne.net as the Email Recipient.
Select CSV as the Report Output Format. Click Next.
Review the report details and click Finish.
NEW QUESTION # 34
The Infosec team has requested that all operational tasks performed within Cluster 1 be properly logged to include the top 4 severity levels and pushed to their syslog system using highest reliability possible for analysis. This is to include any Virtual Machine changes only.
The Infosec team has also requested that monitor logs for the given RSyslog Server Module be included for now. No extra logs should be included.
No other clusters should connect to this syslog server.
Syslog configuration:
* Syslog Name: Corp_Syslog
* Syslog IP: 34.142.155.231
* Port: TCP/514
Ensure only Cluster 1 is configured to meet these requirements.
Here is the step-by-step solution to configure syslog for Cluster 1.
1. Access Cluster 1 Prism Element
Since the requirement is to only configure Cluster 1 and not other clusters, this task must be performed in the Prism Element (PE) interface for Cluster 1.
* From the main Prism Central dashboard, navigate to Hardware > Clusters.
* Find Cluster 1 in the list and click its name. This will open the specific Prism Element login page for that cluster.
* Log in to Cluster 1's Prism Element interface.
2. Add the Syslog Server
* In the Cluster 1 PE interface, click the gear icon (Settings) in the top-right corner.
* From the left-hand menu, select Syslog.
* In the "Remote Syslog Server" section, click the + Add Syslog Server button.
* Fill in the server details as required:
* Name: Corp_Syslog
* IP Address: 34.142.155.231
* Port: 514
* Protocol: TCP (This provides the highest reliability, as requested).
* Click Save.
3. Configure Log Modules and Severities
Now, we must specify which logs to send to the new server.
* On the same Syslog settings page, find the "Syslog Configuration" section and click the Configure button (or Modify if a default is present).
* A dialog box "Select Modules and Levels" will appear.
* Uncheck all modules to ensure no extra logs are sent.
* Check the box for the RSyslog Server Module (or rsyslog_forwarder).
* For this module, check the boxes for the severities: Critical, Warning, and Info.
* Check the box for the ApiServer module.
* This module logs all operational tasks and audit trails, which includes all Virtual Machine changes.
* For this module, check the boxes for the top severity levels: Critical, Warning, and Info.
* Ensure no other modules (like Stargate, Cerebro, Zookeeper, etc.) are checked.
* Click Save.
Cluster 1 is now configured to send its audit logs (including VM changes) and its own syslog monitoring logs to the Corp_Syslog server via TCP, fulfilling all security requirements.
Topic 2, Performance Based Questions Set 2
Environment
You have been provisioned a dedicated environment for your assessment which includes the following:
Workstation
* windows Server 2019
* All software/tools/etc to perform the required tasks
* Nutanix Documentation and whitepapers can be found in desktop ilesDocumentation
* Note that the workstation is the system you are currently togged into Nutanix Cluster
* There are three clusters provided. The connection information for the relevant cluster will be displayed to the high of the question Please make sure you are working on the correct cluster for each item Please ignore any licensing violations
* Cluster A is a 3-node cluster with Prism Central 2022.6 where most questions will be performed
* Cluster B is a one-node cluster and has one syslog item and one security item to perform
* Cluster D is a one-node duster with Prism Central 5.17 and has a security policy item to perform Important Notes
* If the text is too small and hard to read, or you cannot see an of the GUI. you can increase/decrease the zoom of the browser with CTRL + ,and CTRL + (the plus and minus keys) You will be given 3 hours to complete the scenarios for Nutanix NCMMCI Once you click the start button below, you will be provided with:
- A Windows desktop A browser page with the scenarios and credentials (Desktopinstructions) Notes for this exam delivery:
The browser can be scaled lo Improve visibility and fit all the content on the screen.
- Copy and paste hot-keys will not work Use your mouse for copy and paste.
- The Notes and Feedback tabs for each scenario are to leave notes for yourself or feedback for
- Make sure you are performing tasks on the correct components.
- Changing security or network settings on the wrong component may result in a falling grade.
- Do not change credentials on an component unless you are instructed to.
- All necessary documentation is contained in the DesktopFilesDocumentation directory
NEW QUESTION # 35
An administrator is working to create a VM using Nutanix V3 API calls with the following specifications.
VM specifications:
* vCPUs: 2
* Memory: 8Gb
* Disk Size: 50Gb
* Cluster: Cluster 1
* Network: default-net
* Branding must be disabled on the VM
The API call is failing, indicating an issue with the payload:
"'metadata' is a required property",
"'spec' is a required property"
"message": "Request could not be processed.",
"reason": "INVALID_REQUEST"
The body is saved in desktopAPI_Create_VM.txt.
Correct any issues in the text file that would prevent it from creating the VM. Also ensure the VM will be created as specified and make sure it is saved for re-use using that filename.
Deploy the VM through the API.
Note: Do not power on the VM.
Here is the step-by-step solution to correct the API payload and deploy the VM.
This task is performed using the REST API Explorer within Prism Central.
1. Get Required UUIDs
To create a VM, you first need the unique IDs (UUIDs) for the target cluster and network.
* From the Prism Central dashboard, click the question mark (?) icon in the top-right corner and select REST API Explorer.
* Find Cluster 1 UUID:
* In the API Explorer, search for and select the clusters/list (POST) endpoint.
* In the Body field, paste a simple filter: { "kind": "cluster" }
* Click Send.
* In the "Response" body, find the entry for Cluster 1 and copy its metadata.uuid value.
* Find default-net UUID:
* Search for and select the subnets/list (POST) endpoint.
* In the Body field, paste: { "kind": "subnet" }
* Click Send.
* In the "Response" body, find the entry where spec.name is default-net and copy its metadata.uuid value.
2. Correct the API Payload File
The error message "'metadata' is a required property" and "'spec' is a required property" indicates the JSON in the file is malformed and missing the required root-level objects. The file content also does not match the VM specifications.
* On the desktop, open API_Create_VM.txt in Notepad.
* Delete all existing text in the file (including the POST Call and Body: lines).
* Paste the following corrected and complete JSON payload into the file.
* Replace <UUID_for_Cluster_1> and <UUID_for_default-net> with the actual UUIDs you copied in the previous step.
JSON
"spec": {
"name": "API_VM_Task15",
"resources": {
"power_state": "OFF",
"num_sockets": 2,
"num_vcpus_per_socket": 1,
"memory_size_mib": 8192,
"disk_list": [
"disk_size_mib": 51200,
"device_properties": {
"device_type": "DISK"
"nic_list": [
"subnet_reference": {
"kind": "subnet",
"uuid": "<UUID_for_default-net>"
"guest_customization": {
"is_overridable": true,
"override_branding": true
"cluster_reference": {
"kind": "cluster",
"uuid": "<UUID_for_Cluster_1>"
"metadata": {
"kind": "vm"
* Save and close the API_Create_VM.txt file.
Correction Summary:
* JSON Structure: The original file was malformed. The new payload provides the required spec and metadata objects at the root level.
* vCPUs: Set to 2 sockets (2 vCPUs total).
* Memory: Set to 8192 MiB (8 GB).
* Disk: Set to 51200 MiB (50 GB) and removed the unneeded CDROM.
* Cluster/Network: Placeholders are added for the required UUIDs.
* Branding: guest_customization.override_branding: true is added to disable branding for the VM.
3. Deploy the VM via API
* Return to the REST API Explorer.
* Search for and select the vms (POST) endpoint (the one with the description "Create a new vm").
* Open the corrected API_Create_VM.txt file, copy its entire contents (which now includes your specific UUIDs).
* Paste the complete JSON payload into the Body field of the vms (POST) endpoint.
* Click Send.
The API will return a 202 Accepted response, and the VM will be created (and remain powered off) on Cluster 1.
NEW QUESTION # 36
Are you a new comer in your company and eager to make yourself outstanding? Our NCM-MCI-6.10 exam materials can help you. After a few days' studying and practicing with our products you will easily pass the NCM-MCI-6.10 examination. God helps those who help themselves. If you choose our NCM-MCI-6.10 Study Guide, you will find God just by your side. The only thing you have to do is just to make your choice and study. Isn't it very easy? So know more about our NCM-MCI-6.10 practice engine right now!
Exam NCM-MCI-6.10 Blueprint: https://www.torrentvce.com/NCM-MCI-6.10-valid-vce-collection.html
Moreover, the natural and seamless user interfaces of Exam NCM-MCI-6.10 Blueprint - Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) simulated test torrents have grown to be more fluent and offer a total ease of use, Taking this into consideration, and in order to cater to the different requirements of people from different countries in the international market, we have prepared three kinds of versions of our NCM-MCI-6.10 preparation questions in this website, namely, PDF version, online engine and software version, and you can choose any one version of NCM-MCI-6.10 exam questions as you like, Nutanix NCM-MCI-6.10 Free Exam Dumps When it comes to other some negative effects accompanied by the emergence of electronic equipments like eyestrain, some people may adopt the original paper study.
With his daughter, Aubri, he plays games, critiques NCM-MCI-6.10 her artwork, and generally goofs off, The strength of our the IT elite team will make you feel incredible, Moreover, the natural and seamless user interfaces Exam NCM-MCI-6.10 Blueprint of Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) simulated test torrents have grown to be more fluent and offer a total ease of use.
100% Pass Nutanix - NCM-MCI-6.10 –High Hit-Rate Free Exam DumpsTaking this into consideration, and in order to cater to the different Exam NCM-MCI-6.10 Blueprint requirements of people from different countries in the international market, we have prepared three kinds of versionsof our NCM-MCI-6.10 Preparation questions in this website, namely, PDF version, online engine and software version, and you can choose any one version of NCM-MCI-6.10 exam questions as you like.
When it comes to other some negative effects accompanied NCM-MCI-6.10 Hot Spot Questions by the emergence of electronic equipments like eyestrain, some people may adopt the original paper study.
We promise you pass NCM-MCI-6.10 actual test with high pass rate, It means it is not inevitably the province of small part of people who can obtain our Nutanix study material.
