Pdf Data-Engineer-Associate Version | Data-Engineer-Associate Simulation Questio
Posted at 2/17/2026 07:28:20
View160
Replies1
What's more, part of that DumpsTorrent Data-Engineer-Associate dumps now are free: https://drive.google.com/open?id=1hnuP9KvK6Q-YdKXh2xaEFhuNIdR7LzJY
We try to meet different requirements by setting different versions of our Data-Engineer-Associate question dumps. The first one is online Data-Engineer-Associate engine version. As an online tool, it is convenient and easy to study, supports all Web Browsers and system including Windows, Mac, Android, iOS and so on. You can practice online anytime and check your test history and performance review, which will do help to your study. The second is Data-Engineer-Associate Desktop Test Engine. As an installable Data-Engineer-Associate software application, it simulated the real Data-Engineer-Associate exam environment, and builds 200-125 exam confidence. The third one is Practice PDF version. PDF Version is easy to read and print. So you can study anywhere, anytime.
Our customers receive Amazon Data-Engineer-Associate questions updates for up to 365 days after their purchase. They can also try a free demo for satisfaction before buying our Amazon Data-Engineer-Associate dumps. And a 24/7 support system assists them whenever they are stuck in any problem or issue. This Amazon Data-Engineer-Associate Questions is a complete package and a blessing for candidates who want to prepare quickly for the Data-Engineer-Associate exam. Buy It Now!
Data-Engineer-Associate Simulation Questions & Data-Engineer-Associate Reliable Test VoucherThe Data-Engineer-Associate PDF is the most convenient format to go through all exam questions easily. It is a compilation of actual Amazon Data-Engineer-Associate exam questions and answers. The PDF is also printable so you can conveniently have a hard copy of Amazon Data-Engineer-Associate Dumps with you on occasions when you have spare time for quick revision.
Amazon AWS Certified Data Engineer - Associate (DEA-C01) Sample Questions (Q200-Q205):NEW QUESTION # 200
A company uses Amazon RDS to store transactional data. The company runs an RDS DB instance in a private subnet. A developer wrote an AWS Lambda function with default settings to insert, update, or delete data in the DB instance.
The developer needs to give the Lambda function the ability to connect to the DB instance privately without using the public internet.
Which combination of steps will meet this requirement with the LEAST operational overhead? (Choose two.)
- A. Update the security group of the DB instance to allow only Lambda function invocations on the database port.
- B. Attach the same security group to the Lambda function and the DB instance. Include a self-referencing rule that allows access through the database port.
- C. Configure the Lambda function to run in the same subnet that the DB instance uses.
- D. Turn on the public access setting for the DB instance.
- E. Update the network ACL of the private subnet to include a self-referencing rule that allows access through the database port.
To enable the Lambda function to connect to the RDS DB instance privately without using the public internet, the best combination of steps is to configure the Lambda function to run in the same subnet that the DB instance uses, and attach the same security group to the Lambda function and the DB instance. This way, the Lambda function and the DB instance can communicate within the same private network, and the security group can allow traffic between them on the database port. This solution has the least operational overhead, as it does not require any changes to the public access setting, the network ACL, or the security group of the DB instance.
The other options are not optimal for the following reasons:
A: Turn on the public access setting for the DB instance. This option is not recommended, as it would expose the DB instance to the public internet, which can compromise the security and privacy of the data. Moreover, this option would not enable the Lambda function to connect to the DB instance privately, as it would still require the Lambda function to use the public internet to access the DB instance.
B: Update the security group of the DB instance to allow only Lambda function invocations on the database port. This option is not sufficient, as it would only modify the inbound rules of the security group of the DB instance, but not the outbound rules of the security group of the Lambda function.
E: Update the network ACL of the private subnet to include a self-referencing rule that allows access through the database port. This option is not necessary, as the network ACL of the private subnet already allows all traffic within the subnet by default. Moreover, this option would not enable the Lambda function to connect to the DB instance privately, as it would still require the Lambda function to use the public internet to access the DB instance.
1: Connecting to an Amazon RDS DB instance
2: Configuring a Lambda function to access resources in a VPC
3: Working with security groups
4: Network ACLs
NEW QUESTION # 201
A company has three subsidiaries. Each subsidiary uses a different data warehousing solution. The first subsidiary hosts its data warehouse in Amazon Redshift. The second subsidiary uses Teradata Vantage on AWS. The third subsidiary uses Google BigQuery.
The company wants to aggregate all the data into a central Amazon S3 data lake. The company wants to use Apache Iceberg as the table format.
A data engineer needs to build a new pipeline to connect to all the data sources, run transformations by using each source engine, join the data, and write the data to Iceberg.
Which solution will meet these requirements with the LEAST operational effort?
- A. Use the native Amazon Redshift, Teradata, and BigQuery connectors in Amazon Appflow to write data to Amazon S3 and AWS Glue Data Catalog. Use Amazon Athena to join the data. Run a Merge operation on the data lake Iceberg table.
- B. Use native Amazon Redshift, Teradata, and BigQuery connectors to build the pipeline in AWS Glue. Use native AWS Glue transforms to join the data. Run a Merge operation on the data lake Iceberg table.
- C. Use the Amazon Athena federated query connectors for Amazon Redshift, Teradata, and BigQuery to build the pipeline in Athena. Write a SQL query to read from all the data sources, join the data, and run a Merge operation on the data lake Iceberg table.
- D. Use the native Amazon Redshift connector, the Java Database Connectivity (JDBC) connector for Teradata, and the open source Apache Spark BigQuery connector to build the pipeline in Amazon EMR. Write code in PySpark to join the data. Run a Merge operation on the data lake Iceberg table.
Amazon Athena provides federated query connectors that allow querying multiple data sources, such as Amazon Redshift, Teradata, and Google BigQuery, without needing to extract the data from the original source. This solution is optimal because it offers the least operational effort by avoiding complex data movement and transformation processes.
Amazon Athena Federated Queries:
Athena's federated queries allow direct querying of data stored across multiple sources, including Amazon Redshift, Teradata, and BigQuery. With Athena's support for Apache Iceberg, the company can easily run a Merge operation on the Iceberg table.
The solution reduces complexity by centralizing the query execution and transformation process in Athena using SQL queries.
Alternatives Considered:
A (AWS Glue pipeline): This would work but requires more operational effort to manage and transform the data in AWS Glue.
C (Amazon EMR): Using EMR and writing PySpark code introduces more operational overhead and complexity compared to a SQL-based solution in Athena.
D (Amazon AppFlow): AppFlow is more suitable for transferring data between services but is not as efficient for transformations and joins as Athena federated queries.
Amazon Athena Documentation
Federated Queries in Amazon Athena
NEW QUESTION # 202
A company maintains multiple extract, transform, and load (ETL) workflows that ingest data from the company's operational databases into an Amazon S3 based data lake. The ETL workflows use AWS Glue and Amazon EMR to process data.
The company wants to improve the existing architecture to provide automated orchestration and to require minimal manual effort.
Which solution will meet these requirements with the LEAST operational overhead?
- A. AWS Step Functions tasks
- B. AWS Glue workflows
- C. AWS Lambda functions
- D. Amazon Managed Workflows for Apache Airflow (Amazon MWAA) workflows
AWS Glue workflows are a feature of AWS Glue that enable you to create and visualize complex ETL pipelines using AWS Glue components, such as crawlers, jobs, triggers, and development endpoints. AWS Glue workflows provide automated orchestration and require minimal manual effort, as they handle dependency resolution, error handling, state management, and resource allocation for your ETL workflows.
You can use AWS Glue workflows to ingest data from your operational databases into your Amazon S3 based data lake, and then use AWS Glue and Amazon EMR to process the data in the data lake. This solution will meet the requirements with the least operational overhead, as it leverages the serverless and fully managed nature of AWS Glue, and the scalability and flexibility of Amazon EMR12.
* B. AWS Step Functions tasks. AWS Step Functions is a service that lets you coordinate multiple AWS services into serverless workflows. You can use AWS Step Functions tasks to invoke AWS Glue and Amazon EMR jobs as part of your ETL workflows, and use AWS Step Functions state machines to define the logic and flow of your workflows. However, this option would require more manual effort than AWS Glue workflows, as you would need to write JSON code to define your state machines, handle errors and retries, and monitor the execution history and status of your workflows3.
* C. AWS Lambda functions. AWS Lambda is a service that lets you run code without provisioning or managing servers. You can use AWS Lambda functions to trigger AWS Glue and Amazon EMR jobs as part of your ETL workflows, and use AWS Lambda event sources and destinations to orchestrate the flow of your workflows. However, this option would also require more manual effort than AWS Glue workflows, as you would need to write code to implement your business logic, handle errors and retries, and monitor the invocation and execution of your Lambda functions. Moreover, AWS Lambda functions have limitations on the execution time, memory, and concurrency, which may affect the performance and scalability of your ETL workflows.
* D. Amazon Managed Workflows for Apache Airflow (Amazon MWAA) workflows. Amazon MWAA is a managed service that makes it easy to run open source Apache Airflow on AWS. Apache Airflow is a popular tool for creating and managing complex ETL pipelines using directed acyclic graphs (DAGs).
You can use Amazon MWAA workflows to orchestrate AWS Glue and Amazon EMR jobs as part of your ETL workflows, and use the Airflow web interface to visualize and monitor your workflows.
However, this option would have more operational overhead than AWS Glue workflows, as you would need to set up and configure your Amazon MWAA environment, write Python code to define your DAGs, and manage the dependencies and versions of your Airflow plugins and operators.
1: AWS Glue Workflows
2: AWS Glue and Amazon EMR
3: AWS Step Functions
4: AWS Lambda
5: Amazon Managed Workflows for Apache Airflow
NEW QUESTION # 203
A mobile gaming company wants to capture data from its gaming app. The company wants to make the data available to three internal consumers of the data. The data records are approximately 20 KB in size.
The company wants to achieve optimal throughput from each device that runs the gaming app. Additionally, the company wants to develop an application to process data streams. The stream-processing application must have dedicated throughput for each internal consumer.
- A. Configure the mobile app to call the PutRecordBatch API operation to send data to Amazon Data Firehose. Submit an AWS Support case to turn on dedicated throughput for the company's AWS account. Allow each internal consumer to access the stream.
- B. Configure the mobile app to use the Amazon Kinesis Producer Library (KPL) to send data to Amazon Data Firehose. Use the enhanced fan-out feature with a stream for each internal consumer.
- C. Configure the mobile app to call the PutRecords API operation to send data to Amazon Kinesis Data Streams. Host the stream-processing application for each internal consumer on Amazon EC2 instances.Configure auto scaling for the EC2 instances.
- D. Configure the mobile app to call the PutRecords API operation to send data to Amazon Kinesis Data Streams. Use the enhanced fan-out feature with a stream for each internal consumer.
Problem Analysis:
Input Requirements: Gaming app generates approximately 20 KB data records, which must be ingested and made available to three internal consumers with dedicated throughput.
Key Requirements:
High throughput for ingestion from each device.
Dedicated processing bandwidth for each consumer.
Key Considerations:
Amazon Kinesis Data Streams supports high-throughput ingestion with PutRecords API for batch writes.
The Enhanced Fan-Out feature provides dedicated throughput to each consumer, avoiding bandwidth contention.
This solution avoids bottlenecks and ensures optimal throughput for the gaming application and consumers.
Solution Analysis:
Option A: Kinesis Data Streams + Enhanced Fan-Out
PutRecords API is designed for batch writes, improving ingestion performance.
Enhanced Fan-Out allows each consumer to process the stream independently with dedicated throughput.
Option B: Data Firehose + Dedicated Throughput Request
Firehose is not designed for real-time stream processing or fan-out. It delivers data to destinations like S3, Redshift, or OpenSearch, not multiple independent consumers.
Option C: Data Firehose + Enhanced Fan-Out
Firehose does not support enhanced fan-out. This option is invalid.
Option D: Kinesis Data Streams + EC2 Instances
Hosting stream-processing applications on EC2 increases operational overhead compared to native enhanced fan-out.
Final Recommendation:
Use Kinesis Data Streams with Enhanced Fan-Out for high-throughput ingestion and dedicated consumer bandwidth.
Kinesis Data Streams Enhanced Fan-Out
PutRecords API for Batch Writes
NEW QUESTION # 204
A company uses an Amazon QuickSight dashboard to monitor usage of one of the company's applications.
The company uses AWS Glue jobs to process data for the dashboard. The company stores the data in a single Amazon S3 bucket. The company adds new data every day.
A data engineer discovers that dashboard queries are becoming slower over time. The data engineer determines that the root cause of the slowing queries is long-running AWS Glue jobs.
Which actions should the data engineer take to improve the performance of the AWS Glue jobs? (Choose two.)
- A. Convert the AWS Glue schema to the DynamicFrame schema class.
- B. Adjust AWS Glue job scheduling frequency so the jobs run half as many times each day.
- C. Partition the data that is in the S3 bucket. Organize the data by year, month, and day.
- D. Modify the 1AM role that grants access to AWS glue to grant access to all S3 features.
- E. Increase the AWS Glue instance size by scaling up the worker type.
Answer: C,E
Partitioning the data in the S3 bucket can improve the performance of AWS Glue jobs by reducing the amount of data that needs to be scanned and processed. By organizingthe data by year, month, and day, the AWS Glue job can use partition pruning to filter out irrelevant data and only read the data that matches the query criteria.
This can speed up the data processing and reduce the cost of running the AWS Glue job. Increasing the AWS Glue instance size by scaling up the worker type can also improve the performance of AWS Glue jobs by providing more memory and CPU resources for the Spark execution engine. This can help the AWS Glue job handle larger data sets and complex transformations more efficiently. The other options are either incorrect or irrelevant, as they do not affect the performance of the AWS Glue jobs. Converting the AWS Glue schema to the DynamicFrame schema class does not improve the performance, but rather provides additional functionality and flexibility for data manipulation. Adjusting the AWS Glue job scheduling frequency does not improve the performance, but rather reduces the frequency of data updates. Modifying the IAM role that grants access to AWS Glue does not improve the performance, but rather affects the security and permissions of the AWS Glue service. References:
Optimising Glue Scripts for Efficient Data Processing: Part 1 (Section: Partitioning Data in S3) Best practices to optimize cost and performance for AWS Glue streaming ETL jobs (Section:
Development tools)
Monitoring with AWS Glue job run insights (Section: Requirements)
AWS Certified Data Engineer - Associate DEA-C01 Complete Study Guide (Chapter 5, page 133)
NEW QUESTION # 205
We provide candidates with comprehensive Amazon Data-Engineer-Associate exam questions with up to three months of free updates. If you are doubtful, feel free to download a free demo of DumpsTorrent AWS Certified Data Engineer - Associate (DEA-C01) (Data-Engineer-Associate) PDF dumps, desktop practice exam software, and web-based AWS Certified Data Engineer - Associate (DEA-C01) (Data-Engineer-Associate) practice exam. Don't wait. Purchase AWS Certified Data Engineer - Associate (DEA-C01) (Data-Engineer-Associate) exam dumps at an affordable price and start preparing for the updated Amazon Data-Engineer-Associate certification exam today.
Data-Engineer-Associate Simulation Questions: https://www.dumpstorrent.com/Data-Engineer-Associate-exam-dumps-torrent.html
These AWS Certified Data Engineer - Associate (DEA-C01) (Data-Engineer-Associate) mock tests will give you real Data-Engineer-Associate exam experience, Amazon Pdf Data-Engineer-Associate Version After all, no one can steal your knowledge, According to user needs, Data-Engineer-Associate Training exam prep provides everything possible to ensure their success, Amazon Pdf Data-Engineer-Associate Version Questions specific to a Knowledge Area- If lets say you just finished studying Scope Management, you may want to check your knowledge on this or readiness for the exam on the Scope Knowledge Area, There are many advantages of our Amazon Data-Engineer-Associate pdf torrent: latest real questions, accurate answers, instantly download and high passing rate.
There is another technique that should be a part of every programmer's toolkit, Valid Data-Engineer-Associate practice test questions will help you clear exam at the first time, it will be fast for you to obtain certifications and achieve your dream.
Free PDF Quiz 2026 Data-Engineer-Associate: High Hit-Rate Pdf AWS Certified Data Engineer - Associate (DEA-C01) VersionThese AWS Certified Data Engineer - Associate (DEA-C01) (Data-Engineer-Associate) mock tests will give you real Data-Engineer-Associate exam experience, After all, no one can steal your knowledge, According to user needs, Data-Engineer-Associate Training exam prep provides everything possible to ensure their success.
Questions specific to a Knowledge Area- If lets say you just finished Data-Engineer-Associate studying Scope Management, you may want to check your knowledge on this or readiness for the exam on the Scope Knowledge Area.
- 100% Pass 2026 Amazon Data-Engineer-Associate CTrustable Pdf Version 🛰 Immediately open [url]www.troytecdumps.com and search for ➡ Data-Engineer-Associate ️⬅️ to obtain a free download 💹Data-Engineer-Associate New Guide Files[/url]
- Online Amazon Data-Engineer-Associate Practice Test Engine Designed by Experts 🚄 Open ➡ [url]www.pdfvce.com ️⬅️ and search for Data-Engineer-Associate to download exam materials for free 😍Data-Engineer-Associate Latest Real Exam[/url]
- Data-Engineer-Associate Pdf Free ☮ Latest Braindumps Data-Engineer-Associate Ppt 🥡 Test Data-Engineer-Associate Testking 🥌 Search for ⏩ Data-Engineer-Associate ⏪ on ▛ [url]www.pdfdumps.com ▟ immediately to obtain a free download 🥧Latest Braindumps Data-Engineer-Associate Ppt[/url]
- Exam Data-Engineer-Associate Bootcamp 🌻 Data-Engineer-Associate Interactive Course 🦆 Data-Engineer-Associate Updated Testkings 👙 Open [url]www.pdfvce.com and search for [ Data-Engineer-Associate ] to download exam materials for free 🚐Data-Engineer-Associate Pdf Free[/url]
- Data-Engineer-Associate Questions Pdf 📃 Data-Engineer-Associate New Guide Files 📼 Data-Engineer-Associate Pdf Free 🍱 Go to website ➠ [url]www.vce4dumps.com 🠰 open and search for ⇛ Data-Engineer-Associate ⇚ to download for free 😃Data-Engineer-Associate Examcollection Questions Answers[/url]
- Data-Engineer-Associate Reliable Exam Camp 🥚 Valid Data-Engineer-Associate Practice Materials 🩺 Data-Engineer-Associate Updated Testkings ⭐ Enter ⇛ [url]www.pdfvce.com ⇚ and search for ☀ Data-Engineer-Associate ️☀️ to download for free 🔵Exam Data-Engineer-Associate Bootcamp[/url]
- Data-Engineer-Associate Pdf Free 😟 Valid Study Data-Engineer-Associate Questions 🏏 Latest Data-Engineer-Associate Exam Book 🌺 Open website ⮆ [url]www.testkingpass.com ⮄ and search for ▶ Data-Engineer-Associate ◀ for free download 🍑Data-Engineer-Associate Updated Testkings[/url]
- Latest Data-Engineer-Associate Exam Testking 🏏 Data-Engineer-Associate Updated Testkings ⏩ Data-Engineer-Associate Questions Pdf 🚜 Search for Data-Engineer-Associate and download it for free on [url]www.pdfvce.com website 🐯Valid Data-Engineer-Associate Practice Materials[/url]
- Amazon Pdf Data-Engineer-Associate Version - [url]www.dumpsmaterials.com - Certification Success Guaranteed, Easy Way of Training 🐸 Search on ▛ www.dumpsmaterials.com ▟ for ▶ Data-Engineer-Associate ◀ to obtain exam materials for free download 🃏Data-Engineer-Associate New Guide Files[/url]
- Data-Engineer-Associate Latest Dumps Questions 🤬 Data-Engineer-Associate Examcollection Questions Answers 😁 Data-Engineer-Associate Latest Dumps Questions 🔀 Open ➤ [url]www.pdfvce.com ⮘ enter ▛ Data-Engineer-Associate ▟ and obtain a free download 🕚Data-Engineer-Associate Latest Dumps Questions[/url]
- Data-Engineer-Associate Examcollection Questions Answers 🟨 Test Data-Engineer-Associate Testking 🎀 Valid Data-Engineer-Associate Practice Materials 🚕 Search for ▛ Data-Engineer-Associate ▟ and easily obtain a free download on ➤ [url]www.examdiscuss.com ⮘ 🍶Valid Data-Engineer-Associate Practice Materials[/url]
- www.stes.tyc.edu.tw, geekfusion.net, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
P.S. Free & New Data-Engineer-Associate dumps are available on Google Drive shared by DumpsTorrent: https://drive.google.com/open?id=1hnuP9KvK6Q-YdKXh2xaEFhuNIdR7LzJY
