Latest ADA-C01 Questions & ADA-C01 Latest Torrent
Posted at 1/25/2026 01:47:42
P.S. Free 2026 Snowflake ADA-C01 dumps are available on Google Drive shared by Pass4Leader: https://drive.google.com/open?id=1Ck2Dk4HvHN0ROse6QWG8X20rKVR6BM5L
Before you buy our ADA-C01 study questions you can have a free download and tryout and you can have an understanding of our ADA-C01 exam questions by visiting our pages of our ADA-C01 learning guide on the website. The pages of our ADA-C01 guide torrent provide the demo and you can understand part of our titles and the form of our software. So before your purchase you can have an understanding of our ADA-C01 Exam Questions and then decide whether to buy our ADA-C01 study questions or not.
The Snowflake ADA-C01 certification exam is an industrial-recognized SnowPro Advanced Administrator (ADA-C01) certificate that is designed to validate candidates' skills, experience, and knowledge quickly. The SnowPro Advanced Administrator (ADA-C01) certification exam has been inspiring Snowflake professionals since its beginning. Now this ADA-C01 certification exam has become solid proof of certain skills set and knowledge.
ADA-C01 Latest Torrent | ADA-C01 Test CollectionThe pass rate is 98.65% for ADA-C01 study guide, and you can pass the exam just one time. In order to build up your confidence for the exam, we are pass guarantee and money back guarantee. If you fail to pass the exam by using ADA-C01 exam braindumps of us, we will give you full refund. Besides, ADA-C01 learning materials are edited and verified by professional specialists, and therefore the quality can be guaranteed, and you can use them at ease. We have online and offline service. If you have any questions for ADA-C01 Exam Materials, you can consult us, and we will give you reply as quick as possible.
Snowflake SnowPro Advanced Administrator Sample Questions (Q77-Q82):NEW QUESTION # 77
A data provider wants to share data from multiple databases with a data consumer account.
How can this be accomplished?
- A. The data provider needs to create a secure view and must grant the REFERENCE_USAGE privilege on the database where the secure view is created.
- B. The data provider needs to create a secure view and grant the REFERENCE_USAGE privilege on each database referenced by the secure view.
- C. The data provider needs to create a secure view and grant the USAGE privilege on each database referenced by the secure view.
- D. The data provider needs to create a secure view and grant the REFERENCE_USAGE privilege to a database role to include objects from multiple databases in a share
Option B is the correct answer because it follows the steps described in the Snowflake documentation for sharing data from multiple databases using secure views. The data provider needs to grant the REFERENCE_USAGE privilege on each database that contains objects referenced by the secure view, and the USAGE privilege only on the database where the secure view is created. Option A is incorrect because it grants the USAGE privilege instead of the REFERENCE_USAGE privilege. Option C is incorrect because it grants the REFERENCE_USAGE privilege to a database role, which is not supported. Option D is incorrect because it grants the REFERENCE_USAGE privilege on the wrong database.
NEW QUESTION # 78
A user has enrolled in Multi-factor Authentication (MFA) for connecting to Snowflake. The user informs the Snowflake Administrator that they lost their mobile phone the previous evening.
Which step should the Administrator take to allow the user to log in to the system, without revoking their MFA enrollment?
- A. Instruct the user to connect to Snowflake using SnowSQL, which does not support MFA authentication.
- B. Alter the user and set MINS TO BYPASS MFA to a value that will disable MFA long enough for the user to log in.
- C. Alter the user and set DISABLE_MFA to true, which will suspend the MFA requirement for 24 hours.
- D. Instruct the user to append the normal URL with /?mode=mfa_bypass&code= to log on.
The MINS_TO_BYPASS_MFA property allows the account administrator to temporarily disable MFA for a user who has lost their phone or changed their phone number1. The user can log in without MFA for the specified number of minutes, and then re-enroll in MFA using their new phone1. This does not revoke their MFA enrollment, unlike the DISABLE_MFA property, which cancels their enrollment and requires them to re-enroll from scratch1. The other options are not valid ways to bypass MFA, as SnowSQL does support MFA authentication2, and there is no such URL parameter as /?mode=mfa_bypass&code= for Snowflake3
NEW QUESTION # 79
An Administrator needs to implement an access control mechanism across an organization. The organization users access sensitive customer data that comes from different regions and needs to be accessible for Analysts who work in these regions. Some Analysts need very specific access control depending on their functional roles in the organization. Following Snowflake recommended practice, how should these requirements be met? (Select TWO).
- A. Implement row access policies and Dynamic Data Masking policies.
- B. Include masking rules as part of data ingestion and transformation pipelines.
- C. Use zero-copy cloning to replicate the database schema and provide access as needed.
- D. Implement views on top of base tables that exclude or mask sensitive data.
- E. Use a third-party tool to share the data.
Answer: A,D
NEW QUESTION # 80
A company has implemented Snowflake replication between two Snowflake accounts, both of which are running on a Snowflake Enterprise edition. The replication is for the database APP_DB containing only one schema, APP_SCHEMA. The company's Time Travel retention policy is currently set for 30 days for both accounts. An Administrator has been asked to extend the Time Travel retention policy to 60 days on the secondary database only.
How can this requirement be met?
- A. Set the data retention policy on the secondary database to 60 days.
- B. Set the data retention policy on the primary database to 60 days.
- C. Set the data retention policy on the primary database to 30 days and the schemas to 60 days.
- D. Set the data retention policy on the schemas in the secondary database to 60 days.
According to the Replication considerations documentation, the Time Travel retention period for a secondary database can be different from the primary database. The retention period can be set at the database, schema, or table level using the DATA_RETENTION_TIME_IN_DAYS parameter. Therefore, to extend the Time Travel retention policy to 60 days on the secondary database only, the best option is to set the data retention policy on the secondary database to 60 days using the ALTER DATABASE command. The other options are incorrect because:
* B. Setting the data retention policy on the schemas in the secondary database to 60 days will not affect the database-level retention period, which will remain at 30 days. The most specific setting overrides the more general ones, so the schema-level setting will apply to the tables in the schema, but not to the database itself.
* C. Setting the data retention policy on the primary database to 30 days and the schemas to 60 days will not affect the secondary database, which will have its own retention period. The replication process does not copy the retention period settings from the primary to the secondary database, so they can be configured independently.
* D. Setting the data retention policy on the primary database to 60 days will not affect the secondary database, which will have its own retention period. The replication process does not copy the retention period settings from the primary to the secondary database, so they can be configured independently.
NEW QUESTION # 81
An Administrator has a table named SALES_DATA which needs some edits, but the Administrator does not want to change the main table dat a. The Administrator decides to make a transient copy of this table and wants the transient table to have all the same permissions as the original table.
How can the Administrator create the transient table so it inherits the same permissions as the original table, and what considerations need to be made concerning the requirements? (Select TWO).
- A. Transient tables will be purged at the end of the user session and do not have any Fail-safe period.
- B. Use the following SQL command:
create transient table TRANSIENT_SALES_DATA as select * from SALES_DATA; - C. Transient tables will persist until explicitly dropped and contribute to overall storage costs.
- D. Use the following SQL command:
create transient table TRANSIENT SALES DATA as select * from SALES_DATA copy grants; - E. Use the following SQL commands:
create transient table TRANSIENT_SALES_DATA like SALES_DATA copy grants; insert into TRANSIENT_SALES_DATA select * from SALES_DATA;
According to the Snowflake documentation1, the COPY GRANTS option can be used to copy all privileges, except OWNERSHIP, from the existing table to the new transient table. This option also preserves any future grants defined for the object type in the schema. Option A is incorrect because it does not copy any grants from the original table. Option C is incorrect because it does not copy the data from the original table, only the structure and grants. Option E is incorrect because transient tables are not session-based and do not have a Fail-safe period, but they do have a Time Travel retention period2.
1: CREATE TABLE | Snowflake Documentation 2: Working with Temporary and Transient Tables | Snowflake Documentation
NEW QUESTION # 82
One of the most significant parts of your Snowflake ADA-C01 certification exam preparation is consistent practice. Pass4Leader has make sure that you get sufficient ADA-C01 exam practice by adding Snowflake ADA-C01 desktop practice exam software to your study course. This Snowflake ADA-C01 desktop-based practice exam software is compatible with all windows-based devices.
ADA-C01 Latest Torrent: https://www.pass4leader.com/Snowflake/ADA-C01-exam.html
Snowflake Latest ADA-C01 Questions They are conductive to your future as a fairly reasonable investment, Good practice on the success rate of ADA-C01 quiz guide is not fully indicate that you have mastered knowledge is skilled, therefore, the ADA-C01 test material let the user consolidate learning content as many times as possible, although the practice seems very boring, but it can achieve the result of good consolidate knowledge, One way to prove your profession and ability of ADA-C01 valid test question is absolutely the certificates, especially to employee of this area.
Each account appears within its own section on the page ADA-C01 and each account section has its own settings, One always is in a need of further experience and knowledge.
They are conductive to your future as a fairly reasonable investment, Good practice on the success rate of ADA-C01 Quiz guide is not fully indicate that you have mastered knowledge is skilled, therefore, the ADA-C01 test material let the user consolidate learning content as many times as possible, although the practice seems very boring, but it can achieve the result of good consolidate knowledge.
100% Pass Quiz ADA-C01 - High-quality Latest SnowPro Advanced Administrator QuestionsOne way to prove your profession and ability of ADA-C01 valid test question is absolutely the certificates, especially to employee of this area, We are ready for providing the best ADA-C01 test guide materials for you.
Snowflake SnowPro Advanced Administrator PDF prep material, however, give Dumps ADA-C01 Vce high priority to its quality, devoting itself wholeheartedly to better cater to the demand of customers.
- ADA-C01 Study Questions - ADA-C01 Guide Torrent -amp; ADA-C01 Exam Torrent 😬 Search for ➤ ADA-C01 ⮘ and download it for free on ➡ [url]www.verifieddumps.com ️⬅️ website 💢ADA-C01 Exam Training[/url]
- ADA-C01 Latest Mock Exam 🏭 Latest ADA-C01 Exam Materials 😋 ADA-C01 Test Discount Voucher ☣ Copy URL ☀ [url]www.pdfvce.com ️☀️ open and search for “ ADA-C01 ” to download for free 👊Free ADA-C01 Brain Dumps[/url]
- ADA-C01 Study Questions - ADA-C01 Guide Torrent -amp; ADA-C01 Exam Torrent 🗓 Simply search for ▛ ADA-C01 ▟ for free download on “ [url]www.verifieddumps.com ” 🧡ADA-C01 Valid Exam Prep[/url]
- Free PDF 2026 Accurate ADA-C01: Latest SnowPro Advanced Administrator Questions 💙 Download ☀ ADA-C01 ️☀️ for free by simply entering 《 [url]www.pdfvce.com 》 website 🕜Valid ADA-C01 Exam Camp Pdf[/url]
- New ADA-C01 Exam Sample 🕰 Test ADA-C01 Quiz 🛹 ADA-C01 Valid Study Materials 😬 《 [url]www.pdfdumps.com 》 is best website to obtain ▷ ADA-C01 ◁ for free download 🛶Latest ADA-C01 Exam Materials[/url]
- Reliable Test ADA-C01 Test 🤢 New ADA-C01 Exam Sample 👻 Reliable Test ADA-C01 Test 🍜 Search for ▷ ADA-C01 ◁ and download it for free immediately on ▶ [url]www.pdfvce.com ◀ 👶ADA-C01 Relevant Exam Dumps[/url]
- Free PDF Snowflake - ADA-C01 - SnowPro Advanced Administrator Accurate Latest Questions 🥕 Search for “ ADA-C01 ” and download it for free on ⇛ [url]www.examcollectionpass.com ⇚ website 🦝Latest ADA-C01 Exam Materials[/url]
- Valid ADA-C01 Exam Camp Pdf 💚 ADA-C01 New Braindumps Questions 💚 New ADA-C01 Exam Sample ↔ Search for ⇛ ADA-C01 ⇚ and obtain a free download on “ [url]www.pdfvce.com ” 🎴ADA-C01 Exam Training[/url]
- Latest ADA-C01 Exam Objectives 🌗 Trustworthy ADA-C01 Exam Torrent 📨 ADA-C01 Relevant Exam Dumps 🍤 Immediately open ➽ [url]www.troytecdumps.com 🢪 and search for ⮆ ADA-C01 ⮄ to obtain a free download 🍑Free ADA-C01 Brain Dumps[/url]
- Test ADA-C01 Quiz 🍞 Trustworthy ADA-C01 Exam Torrent 🌻 ADA-C01 Relevant Exam Dumps 🐼 Go to website ⏩ [url]www.pdfvce.com ⏪ open and search for ➥ ADA-C01 🡄 to download for free 💲Trustworthy ADA-C01 Exam Torrent[/url]
- ADA-C01 Intereactive Testing Engine 👧 ADA-C01 Relevant Exam Dumps 🕘 ADA-C01 Relevant Exam Dumps 🩲 Easily obtain free download of ➽ ADA-C01 🢪 by searching on ☀ [url]www.practicevce.com ️☀️ 🧜Valid ADA-C01 Exam Camp Pdf[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, connect.garmin.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, cocoasr18.blogspot.com, k12.instructure.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
P.S. Free & New ADA-C01 dumps are available on Google Drive shared by Pass4Leader: https://drive.google.com/open?id=1Ck2Dk4HvHN0ROse6QWG8X20rKVR6BM5L
