[General] Quiz Cisco - 300-430 - Implementing Cisco Enterprise Wireless Networks–The Best
91
【General】 Quiz Cisco - 300-430 - Implementing Cisco Enterprise Wireless Networks–The Best
Posted at 1/31/2026 21:25:34      View:116 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that Prep4King 300-430 dumps now are free: https://drive.google.com/open?id=1h2idvuy_1mUZ7qltZqt51DZf0krYiAaI
If you require any further information about either our 300-430 preparation exam or our corporation, please do not hesitate to let us know. High quality 300-430 practice materials leave a good impression on the exam candidates and bring more business opportunities in the future. And many of our cutomers use our 300-430 Exam Questions as their exam assistant and establish a long cooperation with us.
Cisco 300-430 certification exam is ideal for network professionals who are responsible for deploying wireless networks in enterprise settings. This includes network engineers, network administrators, and wireless network specialists. 300-430 Exam covers the latest technologies and best practices for wireless network deployment, including the use of Cisco DNA Center and Cisco Identity Services Engine (ISE).
Detailed 300-430 Study Dumps, New 300-430 Test ExperiencePrep4King is website that can help a lot of IT people realize their dreams. If you have a IT dream, then quickly click the click of Prep4King. It has the best training materials, which is Prep4King;s Cisco 300-430 Exam Training materials. This training materials is what IT people are very wanted. Because it will make you pass the exam easily, since then rise higher and higher on your career path.
Cisco Implementing Cisco Enterprise Wireless Networks Sample Questions (Q153-Q158):NEW QUESTION # 153
Refer to the exhibit. A network administrator deploys the DHCP profiler service in two ISE servers: 10.3.10.101 and 10.3.10.102.
All BYOD devices connecting to WLAN on VLAN63 have been incorrectly profiled and are assigned as unknown profiled endpoints.
Which action efficiently rectifies the issue according to Cisco recommendations?
  • A. Disable DHCP proxy on the Cisco WLC.
  • B. Disable DHCP proxy on the Cisco WLC and run the ip helper-address command under the VLAN interface to point to DHCP and the two ISE servers.
  • C. Keep DHCP proxy enabled on the Cisco WLC and define helper-address under the VLAN interface to point to the two ISE servers.
  • D. Nothing needed to be added on the Cisco WLC or VLAN interface. The ISE configuration must be fixed.
Disabling DHCP proxy on the Cisco WLC and running the ip helper-address command under the VLAN interface to point to DHCP and the two ISE servers is the recommended action. This allows direct communication between clients and DHCP/ISE servers, which is necessary for accurate device profiling.
NEW QUESTION # 154
For security purposes, an engineer enables CPU ACL and chooses an ACL on the Security > Access Control Lists > CPU Access Control Lists menu. Which kind of traffic does this change apply to, as soon as the change is made?
  • A. wired traffic only
  • B. wireless and wired traffic
  • C. VPN traffic
  • D. wireless traffic only
NEW QUESTION # 155
What must be configured on the Global Configuration page of the WLC for an access point to use 802.1x to authenticate to the wired infrastructure?
  • A. RADIUS shared secret
  • B. TACACS server IP address.
  • C. supplicant credentials
  • D. local access point credentials
https://www.cisco.com/c/en/us/su ... 946-LAP-802-1x.html
NEW QUESTION # 156
The image shows a packet capture that was taken at the CLI of the Cisco CMX server. It shows UDP traffic from the WLC coming into the server. What does the capture prove?
  • A. The Cisco CMX server receives NetFlow data from the WLC.
  • B. The Cisco CMX server receives Angle-of-Arrival data from the WLC.
  • C. The Cisco CMX server receives NMSP traffic from the WLC.
  • D. The Cisco CMX server receives SNMP traffic from the WLC.
NEW QUESTION # 157
The security team has implemented ISE as a AAA solution for the wireless network. The wireless engineer notices that though clients can authenticate successfully, the ISE policies that are designed to place them on different interfaces are not working. Which configuration must be applied in the RADIUS Authentication Settings section from the ISE Network Device page?
  • A. Disable KeyWrap
  • B. Use ASCII for the key input format
  • C. Change the CoA Port
  • D. Correct the shared secret.
NEW QUESTION # 158
Our 300-430 exam guide can stand the test of market as well as customers of various needs with passing rate up to 98 to 100 percent, which is a strong proof that attest to their efficacy. Our300-430 practice materials can provide the evidence of your working proficiency, and the high-efficiency of them are provided by our company can effectively advance your pace of making progress and speed up your pace of reviving it. So our 300-430 Practice Engine is your ideal choice.
Detailed 300-430 Study Dumps: https://www.prep4king.com/300-430-exam-prep-material.html
P.S. Free 2026 Cisco 300-430 dumps are available on Google Drive shared by Prep4King: https://drive.google.com/open?id=1h2idvuy_1mUZ7qltZqt51DZf0krYiAaI
Posted at 2/16/2026 02:35:23        Only Author  2#
The article is very rich in content, and I feel that I have benefited greatly. I’m offering free Plat-Dev-301 exam online exam materials. Good luck to everyone!
