AWS-DevOps-Engineer-Professional Exam Dumps Pdf - AWS-DevOps-Engineer-Profession
Posted at 2/17/2026 05:13:16
2026 Latest Actual4Exams AWS-DevOps-Engineer-Professional PDF Dumps and AWS-DevOps-Engineer-Professional Exam Engine Free Share: https://drive.google.com/open?id=1MyIwWpIlqs_OUdRirXwfbMEwhflxWJHa
It will save you from the unnecessary mental hassle of wasting your valuable money and time. Actual4Exams announces another remarkable feature to its users by giving them the AWS Certified DevOps Engineer - Professional (AWS-DevOps-Engineer-Professional) dumps updates until 1 year after purchasing the AWS Certified DevOps Engineer - Professional (AWS-DevOps-Engineer-Professional) certification exam pdf questions. It will provide them with the AWS-DevOps-Engineer-Professional Exam PDF questions updates free of charge if the AWS-DevOps-Engineer-Professional certification exam issues the latest changes. If you work hard using our top-rated, updated, and excellent Amazon AWS-DevOps-Engineer-Professional pdf questions, nothing can refrain you from getting the AWS Certified DevOps Engineer - Professional (AWS-DevOps-Engineer-Professional) certificate on the maiden endeavor.
Amazon DOP-C01 (AWS Certified DevOps Engineer - Professional) Exam is a certification that validates the skills and expertise of professionals in the field of DevOps engineering. AWS Certified DevOps Engineer - Professional certification is designed to showcase the ability of candidates to design and manage dynamic and scalable systems on the AWS platform. AWS-DevOps-Engineer-Professional Exam is intended for those who have prior experience in developing and operating applications in a cloud environment.
AWS-DevOps-Engineer-Professional Reliable Real Test, Latest AWS-DevOps-Engineer-Professional Test Pass4sureActual4Exams provides AWS Certified DevOps Engineer - Professional AWS-DevOps-Engineer-Professional desktop-based practice software for you to test your knowledge and abilities. The AWS Certified DevOps Engineer - Professional AWS-DevOps-Engineer-Professional desktop-based practice software has an easy-to-use interface. You will become accustomed to and familiar with the free demo for AWS Certified DevOps Engineer - Professional AWS-DevOps-Engineer-Professional Exam Questions. Exam self-evaluation techniques in our AWS Certified DevOps Engineer - Professional AWS-DevOps-Engineer-Professional desktop-based software include randomized questions and timed tests. These tools assist you in assessing your ability and identifying areas for improvement to pass the AWS Certified DevOps Engineer - Professional certification exam.
Amazon AWS Certified DevOps Engineer - Professional Sample Questions (Q96-Q101):NEW QUESTION # 96
Which of the following is NOT an advantage of Docker's content addressable storage model?
- A. avoids content ID collisions
- B. random UUIDs improve filesystem performance
- C. guarantees data integrity after push, pull, load, and save operations
- D. improved security
Docker 1.10 introduced a new content addressable storage model. This is a completely new way to address image and layer data on disk. Previously, image and layer data was referenced and stored using a randomly generated UUID. In the new model this is replaced by a secure content hash.
The new model improves security, provides a built-in way to avoid ID collisions, and guarantees data integrity after pull, push, load, and save operations. It also enables better sharing of layers by allowing many images to freely share their layers even if they didn't come from the same build.
https://docs.docker.com/engine/u ... ontainers/#content- addressable-storage
NEW QUESTION # 97
Your company is using an Autoscaling Group to scale out and scale in instances. There is an expectation of a
peak in traffic every Monday at 8am. The traffic is then expected to come down before the weekend on Friday
5pm. How should you configure Autoscaling in this?
- A. Createdynamic scaling policies to scale up on Monday and scale down on Friday
- B. Create a scheduled policy to scale up on Fridayand scale down on Monday
- C. CreateascheduledpolicytoscaleuponMondayandscaledownonFriday
- D. Manuallyadd instances to the Autoscaling Group on Monday and remove them on Friday
The AWS Documentation mentions the following for Scheduled scaling
Scaling based on a schedule allows you to scale your application in response to predictable load changes. For
example, every week the traffic to your web application starts to increase on Wednesday, remains high on
Thursday, and starts to decrease on Friday. You can plan your scaling activities based on the predictable traffic
patterns of your web application.
For more information on scheduled scaling for Autoscaling, please visit the below URL
* http://docs.aws.amazon.com/autoscaling/latest/userguide/sched
ule_time.htm I
NEW QUESTION # 98
A web application for healthcare services runs on Amazon EC2 instances behind an ELB Application Load Balancer. The instances run in an Amazon EC2 Auto Scaling group across multiple Availability Zones. A DevOps Engineer must create a mechanism in which an EC2 instance can be taken out of production so its system logs can be analyzed for issues to quickly troubleshot problems on the web tier. How can the Engineer accomplish this task while ensuring availability and minimizing downtime?
- A. Implement EC2 Auto Scaling groups with lifecycle hooks. Create an AWS Lambda function that can modify an EC2 instance lifecycle hook into a standby state, extract logs from the instance through a remote script execution, and place them in an Amazon S3 bucket for analysis.
- B. Implement Amazon CloudWatch Events rules. Create an AWS Lambda function that can react to an instance termination to deploy the CloudWatch Logs agent to upload the system and access logs to Amazon S3 for analysis.
- C. Implement EC2 Auto Scaling groups cooldown periods. Use EC2 instance metadata to determine the instance state, and an AWS Lambda function to snapshot Amazon EBS volumes to preserve system logs.
- D. Terminate the EC2 instances manually. The Auto Scaling service will upload all log information to CloudWatch Logs for analysis prior to instance termination.
NEW QUESTION # 99
Your company has multiple applications running on AWS. Your company wants to develop a tool that notifies on-call teams immediately via email when an alarm is triggered in your environment. You have multiple on-call teams that work different shifts, and the tool should handle notifying the correct teams at the correct times. How should you implement this solution?
- A. Create an Amazon SNS topic and configure your on-call team email addresses as subscribers. Use the AWS SDK tools to integrate your application with Amazon SNS and send messages to this new topic.
Notifications will be sent to on-call users when a CloudWatch alarm is triggered. - B. Create an Amazon SNS topic and configure your on-call team email addresses as subscribers. Create a secondary Amazon SNS topic for alarms and configure your CloudWatch alarms to notify this topic when triggered. Create an HTTP subscriber to this topic that notifies your application via HTTP POST when an alarm is triggered. Use the AWS SDK tools to integrate your application with Amazon SNS and send messages to the first topic so that on-call engineers receive alerts.
- C. Create an Amazon SNS topic and an Amazon SQS queue. Configure the Amazon SQS queue as a subscriber to the Amazon SNS topic.
Configure CloudWatch alarms to notify this topic when an alarm is triggered. Create an Amazon EC2 Auto Scaling group with both minimum and desired Instances configured to 0. Worker nodes in this group spawn when messages are added to the queue. Workers then use Amazon Simple Email Service to send messages to your on call teams. - D. Create an Amazon SNS topic for each on-call group, and configure each of these with the team member emails as subscribers. Create another Amazon SNS topic and configure your CloudWatch alarms to notify this topic when triggered. Create an HTTP subscriber to this topic that notifies your application via HTTP POST when an alarm is triggered. Use the AWS SDK tools to integrate your application with Amazon SNS and send messages to the correct team topic when on shift.
Option D fulfils all the requirements
1) First is to create a SNS topic for each group so that the required members get the email addresses.
2) Ensure the application uses the HTTPS endpoint and the SDK to publish messages Option A is invalid because the SQS service is not required.
Option B and C are incorrect. As per the requirement we need to provide notification to only those on-call teams who are working in that particular shift when an alarm is triggered. It need not have to be send to all the on-call teams of the company. With Option B & C, since we are not configuring the SNS topic for each on call team the notifications will be send to all the on-call teams. Hence these 2 options are invalid. For more information on setting up notifications, please refer to the below document link: from AWS
* http://docs.aws.amazon.com/Amazo ... ng/US_SetupSNS.html
NEW QUESTION # 100
A healthcare company has a critical application running in AWS. Recently, the company experienced some down time. if it happens again, the company needs to be able to recover its application in another AWS Region. The application uses Elastic Load Balancing and Amazon EC2 instances. The company also maintains a custom AMI that contains its application. This AMI is changed frequently. The workload is required to run in the primary region, unless there is a regional service disruption, in which case traffic should fail over to the new region. Additionally, the cost for the second region needs to be low.
The RTO is 2 hours.
Which solution allows the company to fail over to another region in the event of a failure, and also meet the above requirements?
- A. Maintain a copy of the AMI from the main region in the backup region. Create an Auto Scaling group with one instance using a launch configuration that contains the copied AMI. Use an Amazon Route 53 record to direct traffic to the load balancer in the backup region in the event of failure, as required.
Allow the Auto Scaling group to scale out as needed during a failure. - B. Automate the copying of the AMI to the backup region. Create an AWS Lambda function that can create a launch configuration and assign it to an already created Auto Scaling group. Set the Auto Scaling group maximum size to 0 and only increase it with the Lambda function during a failure.
Trigger the Lambda function in the event of a failure. Use an Amazon Route 53 record and modify it with the same Lambda function to point to the load balancer in the backup region. - C. Place the AMI in a replicated Amazon S3 bucket. Generate an AWS Lambda function that can create a launch configuration and assign it to an already created Auto Scaling group. Have one instance in this Auto Scaling group ready to accept traffic. Trigger the Lambda function in the event of a failure. Use an Amazon Route 53 record and modify it with the same Lambda function to point to the load balancer in the backup region.
- D. Automate the copying of the AMI in the main region to the backup region. Generate an AWS Lambda function that will create an EC2 instance from the AMI and place it behind a load balancer. Using the same Lambda function, point the Amazon Route 53 record to the load balancer in the backup region.
B is not the best answer. It will create an instance in the backup region which will have cost. We should keep the cost low by not starting up the instance unless failover.
NEW QUESTION # 101
Actual4Exams is a wonderful study platform that contains our hearty wish for you to pass the AWS-DevOps-Engineer-Professional exam by our AWS-DevOps-Engineer-Professional exam materials. So our responsible behaviors are our instinct aim and tenet. By devoting in this area so many years, we are omnipotent to solve the problems about the AWS-DevOps-Engineer-Professional learning questions with stalwart confidence. And as long as you study with our AWS-DevOps-Engineer-Professional exam questions, you will find that our AWS-DevOps-Engineer-Professional learning guide is the best for the outstanding quality and high pass rate as 99% to 100%.
AWS-DevOps-Engineer-Professional Reliable Real Test: https://www.actual4exams.com/AWS-DevOps-Engineer-Professional-valid-dump.html
- Latest AWS Certified DevOps Engineer - Professional free dumps - AWS-DevOps-Engineer-Professional passleader braindumps 🐝 Simply search for ( AWS-DevOps-Engineer-Professional ) for free download on ⮆ [url]www.dumpsmaterials.com ⮄ 💔Real AWS-DevOps-Engineer-Professional Dumps Free[/url]
- Quiz Professional Amazon - AWS-DevOps-Engineer-Professional Exam Dumps Pdf 🤑 Search for ☀ AWS-DevOps-Engineer-Professional ️☀️ and download it for free immediately on 【 [url]www.pdfvce.com 】 🤴New AWS-DevOps-Engineer-Professional Exam Online[/url]
- AWS-DevOps-Engineer-Professional Test Dump ♿ AWS-DevOps-Engineer-Professional Reliable Dumps 🌸 AWS-DevOps-Engineer-Professional Training Courses 🏤 The page for free download of [ AWS-DevOps-Engineer-Professional ] on 「 [url]www.prepawaypdf.com 」 will open immediately ✡
opular AWS-DevOps-Engineer-Professional Exams[/url] - AWS-DevOps-Engineer-Professional Reliable Braindumps Files 🌹 Popular AWS-DevOps-Engineer-Professional Exams 🦲 AWS-DevOps-Engineer-Professional Exam Actual Questions 🕧 Search on ( [url]www.pdfvce.com ) for ➡ AWS-DevOps-Engineer-Professional ️⬅️ to obtain exam materials for free download 🧦Reliable AWS-DevOps-Engineer-Professional Test Camp[/url]
- AWS-DevOps-Engineer-Professional training materials: AWS Certified DevOps Engineer - Professional - AWS-DevOps-Engineer-Professional guide torrent - Amazon AWS-DevOps-Engineer-Professional quiz 📹 The page for free download of ➤ AWS-DevOps-Engineer-Professional ⮘ on ⮆ [url]www.vce4dumps.com ⮄ will open immediately 🦀AWS-DevOps-Engineer-Professional Test Dump[/url]
- 100% Pass Quiz Amazon - Fantastic AWS-DevOps-Engineer-Professional Exam Dumps Pdf 🐵 Open 《 [url]www.pdfvce.com 》 and search for ➠ AWS-DevOps-Engineer-Professional 🠰 to download exam materials for free 🐄Vce AWS-DevOps-Engineer-Professional Test Simulator[/url]
- AWS-DevOps-Engineer-Professional Key Concepts 🤛 AWS-DevOps-Engineer-Professional Study Test 🦍 AWS-DevOps-Engineer-Professional Well Prep 🐅 Search for ( AWS-DevOps-Engineer-Professional ) on ▶ [url]www.vceengine.com ◀ immediately to obtain a free download 🥧AWS-DevOps-Engineer-Professional Reliable Dumps[/url]
- AWS-DevOps-Engineer-Professional Reliable Real Test 🏡 AWS-DevOps-Engineer-Professional Reliable Braindumps Files ❣ AWS-DevOps-Engineer-Professional Reliable Dumps ⚪ The page for free download of ▷ AWS-DevOps-Engineer-Professional ◁ on ➡ [url]www.pdfvce.com ️⬅️ will open immediately 🥠AWS-DevOps-Engineer-Professional Reliable Real Test[/url]
- AWS-DevOps-Engineer-Professional Well Prep 🔹 Related AWS-DevOps-Engineer-Professional Certifications 🍻 Premium AWS-DevOps-Engineer-Professional Exam 🐯 Enter ➡ [url]www.troytecdumps.com ️⬅️ and search for ( AWS-DevOps-Engineer-Professional ) to download for free ⌛AWS-DevOps-Engineer-Professional Study Test[/url]
- Popular AWS-DevOps-Engineer-Professional Exams 👺 AWS-DevOps-Engineer-Professional Well Prep 📯 Premium AWS-DevOps-Engineer-Professional Exam ⏬ Search for ✔ AWS-DevOps-Engineer-Professional ️✔️ and download exam materials for free through ➤ [url]www.pdfvce.com ⮘ 🧟Reliable AWS-DevOps-Engineer-Professional Test Camp[/url]
- 2026 Valid AWS-DevOps-Engineer-Professional Exam Dumps Pdf | AWS-DevOps-Engineer-Professional 100% Free Reliable Real Test 🧯 Immediately open [ [url]www.pdfdumps.com ] and search for ▛ AWS-DevOps-Engineer-Professional ▟ to obtain a free download 👡AWS-DevOps-Engineer-Professional Reliable Dumps[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, www.stes.tyc.edu.tw, thesanctum.co.za, www.stes.tyc.edu.tw, indianagriexam.com, iibat-academy.com, tutorlms-test-14-05-24.diligite.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
BONUS!!! Download part of Actual4Exams AWS-DevOps-Engineer-Professional dumps for free: https://drive.google.com/open?id=1MyIwWpIlqs_OUdRirXwfbMEwhflxWJHa
