[Hardware] First-grade C_ACDET_2506 Test Free to Obtain SAP Certification
98
【Hardware】 First-grade C_ACDET_2506 Test Free to Obtain SAP Certification
Posted at 1/17/2026 20:30:54      View:137 | Replies:2        Print      Only Author   [Copy Link] 1#
Dear every IT candidates, here, I will recommend ExamcollectionPass C_ACDET_2506 exam training material to all of you. If you use SAP C_ACDET_2506 test bootcamp, you will not need to purchase anything else or attend other training. We promise that you can pass your C_ACDET_2506 Certification at first attempt. The high pass rate has helped lots of IT candidates get their IT certification. In case of failure, we promise to give you full refund. No help, full refund!
All the C_ACDET_2506 training files of our company are designed by the experts and professors in the field. The quality of our study materials is guaranteed. According to the actual situation of all customers, we will make the suitable study plan for all customers. If you buy the C_ACDET_2506 Learning Materials from our company, we can promise that you will get the professional training to help you pass your C_ACDET_2506 exam easily. By our professional training, you will pass your C_ACDET_2506 exam and get the related certification in the shortest time.
Latest C_ACDET_2506 Exam Labs & C_ACDET_2506 Simulations PdfOur company has always been following the trend of the C_ACDET_2506 certification. Our research and development team not only study what questions will come up in the C_ACDET_2506 exam. The content of our C_ACDET_2506 practice materials is chosen so carefully that all the questions for the exam are contained. And our study materials have three formats which help you to read, test and study anytime, anywhere. This means with our products you can prepare for exams efficiently. If you desire a C_ACDET_2506 Certification, our products are your best choice.
SAP C_ACDET_2506 Exam Syllabus Topics:
  • Deploy and Migration: This part of the exam assesses the expertise of an SAP Deployment Specialist and focuses on the final deployment of the configured solution and the data migration process. Candidates should demonstrate a solid grasp of how to move configurations from a testing environment into production while minimizing disruption. It also includes knowledge of tools and strategies used for data extraction.
  • Project Overview, Roles and Responsibilities: This section of the exam measures the skills of an SAP Cloud Consultant and covers the fundamental understanding of SAP Activate methodology within the context of a cloud implementation project. Candidates are expected to be familiar with the project lifecycle, including phases such as Prepare, Explore, Realize, Deploy, and Run. This part also focuses on identifying key roles and responsibilities within a cloud project team, ensuring clarity in collaboration between consultants, clients, and SAP. It checks whether the consultant understands governance, stakeholder management, and the high-level structure of cloud deployment using SAP best practices.
  • Field Configuration: This domain evaluates the knowledge of an SAP Deployment Specialist and focuses on customizing and configuring business fields in the SAP system according to client-specific needs. This includes adjusting system settings for master data, transaction data, and other essential field-level controls to support business processes effectively. The section tests the candidate’s ability to use configuration tools, apply SAP standard templates, and ensure that the field configurations align with the desired operational workflows of the business. It also touches upon validation, testing, and documenting the configuration changes made during the implementation.
SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite Sample Questions (Q33-Q38):NEW QUESTION # 33
What does ? represent in the ariba expression below? HierarchicalType=="SubAgreement" ? false: true
  • A. if
  • B. then
  • C. else
  • D. replace
NEW QUESTION # 34
What is the key role of the SAP Deployment Lead assigned to the project?
  • A. To act as the liaison between the customer and SAP Support in resolving technical issues and manage customer escalations
  • B. To test and validate the solution prior to go-live
  • C. To perform configuration changes required to the SAP Ariba Strategic Sourcing suite solutions
  • D. To advise the customer and partner in solution configurations
TheSAP Deployment Lead acts as the primary liaison between the customer and SAP Support, managing technical issues, escalations, and coordination during the deployment lifecycle. They oversee environment readiness, migration activities, and issue resolution. Advising on configurations is typically the Functional Lead's role, configuration changes are done by consultants, and testing is led by the customer or testing teams. The Deployment Lead focuses on technical project management and communication.
NEW QUESTION # 35
Which of the following considerations are important when creating custom fields? Note: There are 2 correct answers to this question.
  • A. When a field has been created and published, that field type has been consumed from the number of available fields on the class
  • B. Published field changes can be reverted via Un-publish to free up memory
  • C. There's a limit to the number of fields, by data type, that can be added to a class
  • D. The data type of a field can be dynamically changed, depending on data type availability
NEW QUESTION # 36
You want to apply a preset filter to a custom field so that it only shows valid values based on the value of another field. What do you use to apply predefined filter criteria for a field?
  • A. Define a Visibility Condition in the Conditions tab
  • B. Enable field property "Use relationship chooser" in the Advanced tab
  • C. Populate the "Relation Name" and "NameTableConstraintFieldPath" in the Advanced tab
  • D. Enable field property "Enable for Template Field Setter" in the Advanced tab
  • E. Load Relation types and Relation entries
To filter a custom field's available values based on another field's value in SAP Ariba, youpopulate the
"Relation Name" and "NameTableConstraintFieldPath" properties in the field's Advanced tab. This configuration links the field to a predefined relation type and specifies the constraint field used for filtering.
Simply loading relation types (B) is a prerequisite but does not configure filtering on the field itself. Visibility conditions (C) control whether a field is shown, not the filtering of its values. Enabling "Use relationship chooser" (D) is necessary but insufficient alone without defining the relation and constraint field. The "Enable for Template Field Setter" (E) option is unrelated to filtering.
This filtering enables dynamic picklists where options depend on another field's selection, improving data accuracy and user experience.
NEW QUESTION # 37
You are performing a Brownfield migration for a customer with live transactions in their SAP Ariba Production environment. The customer plans to introduce new required fields for contract workspaces that are associated with flex master data templates and enumeration lists Based on the correct Brownfield process, what is the correct sequence of activities to avoid system errors or user disruption?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 38
This is similar to the C_ACDET_2506 desktop format but this is browser-based. It requires an active internet connection to run and is compatible with all browsers such as Google Chrome, Mozilla Firefox, Opera, MS Edge, Safari, Internet Explorer, and others. The SAP C_ACDET_2506 Mock Exam helps you self-evaluate your SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite exam preparation and mistakes. This way you improve consistently and attempt the C_ACDET_2506 certification exam in an optimal way for excellent results in the exam.
Latest C_ACDET_2506 Exam Labs: https://www.examcollectionpass.com/SAP/C_ACDET_2506-practice-exam-dumps.html
Posted at 1/21/2026 03:16:27        Only Author  2#
This article is incredibly motivating, thank you for sharing it! The New 312-97 exam certification cost test papers are now available for free. Wishing you all the best!
Posted at 2/17/2026 15:35:53        Only Author  3#
What an enlightening and motivating read, thank you for sharing! I’m diving into the Valid test Experience-Cloud-Consultant questions and answers exam soon, please wish me luck!
