DeBrick FireWRT
7
DeBrick FireWRT
Posted at 10/16/2015 01:03:24      View5829 | Replies7        Print      Only Author   [Copy Link] 1#
Hey there, I would apprieciate some help on my bricked FirWRT:
Recently I bricked my FireWRT after trying to flash OpenWRT (openwrt-ramips-mt7621-firewrt-squashfs-sysupgrade.bin) from here:
http://wiki.openwrt.org/toh/firefly/firewrt
I could re-flash the original firmware
2015-05-07-firewrt-mt7621-openwrt-trunk.bin or
2015-06-02-firewrt-mt7621-openwrt-trunk.bin
from here:
http://en.t-firefly.com/en/firelink/firewrt/download/
as described in the official guide (HTTP download):
http://wiki.t-firefly.com/index. ... ad_OpenWrt_Firmware
The problem is, that the device is not coming up but running a boot loop.
The serial debug console looks like this:
  1. U-Boot 1.1.3 (May  7 2015 - 10:40:34)
  2. Board: Ralink APSoC DRAM:  448 MB
  3. relocate_code Pointer at: 9bfb4000
  4. Config XHCI 40M PLL
  5. ***********************
  6. Watchdog Reset Occurred
  7. ***********************
  8. flash manufacture id: ef, device id 40 18
  9. find flash: W25Q128BV
  10. ============================================
  11. FireWRT UBoot Version: 1.0
  12. --------------------------------------------
  13. ASIC MT7621A DualCore (MAC to MT7530 Mode)
  14. DRAM_CONF_FROM: Auto-Detection
  15. DRAM_TYPE: DDR3
  16. DRAM bus: 16 bit
  17. Xtal Mode=3 OCP Ratio=1/4
  18. Flash component: SPI Flash
  19. Date:May  7 2015  Time:10:40:34
  20. ============================================
  21. icache: sets:256, ways:4, linesz:32 ,total:32768
  22. dcache: sets:256, ways:4, linesz:32 ,total:32768
  23. set LAN/WAN WLL
  24. .-------.             __                __
  25. |  _____/            |  |              |  | __
  26. |  __/__ .----..----.|  |    __ .-----.|  |/  /
  27. |  | |  ||   _|| -__||  |__ |  ||     ||     <
  28. |__| |__||__|  |____||_____||__||__|__||__|\__\
  29. --------------------------------------------------
  30.                   FIREFLY Team
  31.           Full of enthusiasm and dream
  32.            <fl.service@t-firely.com>
  33. --------------------------------------------------
  34. Please choose the operation:
  35.    1: Load system code to SDRAM via TFTP.
  36.    2: Load system code then write to Flash via TFTP.
  37.    3: Boot system code via Flash (default).
  38.    4: Entr boot command line interface.
  39.    5: Load system code then write to Flash via Httpd.
  40.    7: Load Boot Loader code then write to Flash via Serial.
  41.    9: Load Boot Loader code then write to Flash via TFTP.
  42. 0
  43.
  44. 3: System Boot system code via Flash.
  45. ## Booting image at bfc50000 ...
  46.    Image Name:   MIPS OpenWrt Linux-3.18.11
  47.    Image Type:   MIPS Linux Kernel Image (lzma compressed)
  48.    Data Size:    1194098 Bytes =  1.1 MB
  49.    Load Address: 80001000
  50.    Entry Point:  80001000
  51.    Verifying Checksum ... OK
  52.    Uncompressing Kernel Image ... OK
  53. No initrd
  54. ## Transferring control to Linux (at address 80001000) ...
  55. ## Giving linux memsize in MB, 448
  56. Starting kernel ...
  57. [    0.000000] Linux version 3.18.11 (wengbj@tchip-server) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r45583) ) #8 SMP Tue Jun 2 16:56:47 CST 2015
  58. [    0.000000] SoC Type: Mediatek MT7621 ver:1 eco:3
  59. [    0.000000] bootconsole [early0] enabled
  60. [    0.000000] CPU0 revision is: 0001992f (MIPS 1004Kc)
  61. [    0.000000] MIPS: machine is Firefly FireWRT
  62. [    0.000000] Determined physical RAM map:
  63. [    0.000000]  memory: 10000000 @ 00000000 (usable)
  64. [    0.000000] Initrd not found or empty - disabling initrd
  65. [    0.000000] Zone ranges:
  66. [    0.000000]   Normal   [mem 0x00000000-0x0fffffff]
  67. [    0.000000]   HighMem  empty
  68. [    0.000000] Movable zone start for each node
  69. [    0.000000] Early memory node ranges
  70. [    0.000000]   node   0: [mem 0x00000000-0x0fffffff]
  71. [    0.000000] Initmem setup node 0 [mem 0x00000000-0x0fffffff]
  72. [    0.000000] Detected 3 available secondary CPU(s)
  73. [    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
  74. [    0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
  75. [    0.000000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
  76. [    0.000000] PERCPU: Embedded 9 pages/cpu @8120d000 s5696 r8192 d22976 u36864
  77. [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
  78. [    0.000000] Kernel command line: console=ttyS0,57600 rootfstype=squashfs,jffs2
  79. [    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
  80. [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
  81. [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
  82. [    0.000000] Writing ErrCtl register=00001031
  83. [    0.000000] Readback ErrCtl register=00001031
  84. [    0.000000] Memory: 255912K/262144K available (2688K kernel code, 144K rwdata, 520K rodata, 156K init, 224K bss, 6232K reserved, 0K highmem)
  85. [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  86. [    0.000000] Hierarchical RCU implementation.
  87. [    0.000000] NR_IRQS:256
  88. [    0.000000] gic: revision 3.0
  89. [    0.000000] CPU Clock: 880MHz
  90. [    0.000000] Calibrating delay loop... 577.53 BogoMIPS (lpj=2887680)
  91. [    0.060000] pid_max: default: 32768 minimum: 301
  92. [    0.070000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
  93. [    0.080000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
  94. [    0.090000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
  95. [    0.090000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
  96. [    0.090000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
  97. [    0.090000] CPU1 revision is: 0001992f (MIPS 1004Kc)
  98. [    0.200000] Synchronize counters for CPU 1: done.
  99. [    0.210000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
  100. [    0.210000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
  101. [    0.210000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
  102. [    0.210000] CPU2 revision is: 0001992f (MIPS 1004Kc)
  103. [    0.310000] Synchronize counters for CPU 2: done.
  104. [    0.330000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
  105. [    0.330000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
  106. [    0.330000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
  107. [    0.330000] CPU3 revision is: 0001992f (MIPS 1004Kc)
  108. [    0.430000] Synchronize counters for CPU 3: done.
  109. [    0.450000] Brought up 4 CPUs
  110. [    0.450000] pinctrl core: initialized pinctrl subsystem
  111. [    0.460000] NET: Registered protocol family 16
  112. [    0.470000] pull PCIe RST: RALINK_RSTCTRL = 6000000
  113. [    0.770000] release PCIe RST: RALINK_RSTCTRL = 7000000
  114. [    0.780000] ***** Xtal 40MHz *****
  115. [    0.780000] release PCIe RST: RALINK_RSTCTRL = 7000000
  116. [    0.790000] Port 0 N_FTS = 1b105000
  117. [    0.790000] Port 1 N_FTS = 1b105000
  118. [    0.800000] Port 2 N_FTS = 1b105000
  119. [    1.940000]  -> 21007f2
  120. [    1.940000] PCIE0 enabled
  121. [    1.950000] PCIE1 enabled
  122. [    1.950000] PCIE2 enabled
  123. [    1.960000] PCI host bridge /pcie@1e140000 ranges:
  124. [    1.970000]  MEM 0x0000000060000000..0x000000006fffffff
  125. [    1.980000]   IO 0x000000001e160000..0x000000001e16ffff
  126. [    2.020000] mt7621_gpio 1e000600.gpio: registering 32 gpios
  127. [    2.030000] mt7621_gpio 1e000600.gpio: registering 32 gpios
  128. [    2.040000] mt7621_gpio 1e000600.gpio: registering 32 gpios
  129. [    2.050000] PCI host bridge to bus 0000:00
  130. [    2.060000] pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fffffff]
  131. [    2.080000] pci_bus 0000:00: root bus resource [io  0xffffffff]
  132. [    2.090000] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
  133. [    2.110000] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
  134. [    2.130000] pci 0000:00:00.0: BAR 0: no space for [mem size 0x80000000]
  135. [    2.150000] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x80000000]
  136. [    2.160000] pci 0000:00:01.0: BAR 0: no space for [mem size 0x80000000]
  137. [    2.180000] pci 0000:00:01.0: BAR 0: failed to assign [mem size 0x80000000]
  138. [    2.190000] pci 0000:00:02.0: BAR 0: no space for [mem size 0x80000000]
  139. [    2.210000] pci 0000:00:02.0: BAR 0: failed to assign [mem size 0x80000000]
  140. [    2.220000] pci 0000:00:00.0: BAR 8: assigned [mem 0x60000000-0x600fffff]
  141. [    2.240000] pci 0000:00:00.0: BAR 9: assigned [mem 0x60100000-0x601fffff pref]
  142. [    2.250000] pci 0000:00:01.0: BAR 8: assigned [mem 0x60200000-0x602fffff]
  143. [    2.270000] pci 0000:00:01.0: BAR 9: assigned [mem 0x60300000-0x603fffff pref]
  144. [    2.290000] pci 0000:00:02.0: BAR 8: assigned [mem 0x60400000-0x604fffff]
  145. [    2.300000] pci 0000:00:02.0: BAR 9: assigned [mem 0x60500000-0x605fffff pref]
  146. [    2.320000] pci 0000:00:00.0: BAR 1: assigned [mem 0x60600000-0x6060ffff]
  147. [    2.330000] pci 0000:00:01.0: BAR 1: assigned [mem 0x60610000-0x6061ffff]
  148. [    2.350000] pci 0000:00:02.0: BAR 1: assigned [mem 0x60620000-0x6062ffff]
  149. [    2.360000] pci 0000:00:02.0: BAR 7: no space for [io  size 0x1000]
  150. [    2.380000] pci 0000:00:02.0: BAR 7: failed to assign [io  size 0x1000]
  151. [    2.390000] pci 0000:01:00.0: BAR 0: assigned [mem 0x60000000-0x600fffff 64bit]
  152. [    2.410000] pci 0000:01:00.0: BAR 6: assigned [mem 0x60100000-0x6010ffff pref]
  153. [    2.430000] pci 0000:00:00.0: PCI bridge to [bus 01]
  154. [    2.440000] pci 0000:00:00.0:   bridge window [mem 0x60000000-0x600fffff]
  155. [    2.450000] pci 0000:00:00.0:   bridge window [mem 0x60100000-0x601fffff pref]
  156. [    2.470000] pci 0000:02:00.0: BAR 0: assigned [mem 0x60200000-0x602fffff 64bit]
  157. [    2.490000] pci 0000:02:00.0: BAR 6: assigned [mem 0x60300000-0x6030ffff pref]
  158. [    2.500000] pci 0000:00:01.0: PCI bridge to [bus 02]
  159. [    2.510000] pci 0000:00:01.0:   bridge window [mem 0x60200000-0x602fffff]
  160. [    2.530000] pci 0000:00:01.0:   bridge window [mem 0x60300000-0x603fffff pref]
  161. [    2.540000] pci 0000:03:00.0: BAR 6: assigned [mem 0x60500000-0x6050ffff pref]
  162. [    2.560000] pci 0000:03:00.0: BAR 5: assigned [mem 0x60400000-0x604001ff]
  163. [    2.580000] pci 0000:03:00.0: BAR 4: no space for [io  size 0x0020]
  164. [    2.590000] pci 0000:03:00.0: BAR 4: failed to assign [io  size 0x0020]
  165. [    2.600000] pci 0000:03:00.0: BAR 0: no space for [io  size 0x0008]
  166. [    2.620000] pci 0000:03:00.0: BAR 0: failed to assign [io  size 0x0008]
  167. [    2.630000] pci 0000:03:00.0: BAR 2: no space for [io  size 0x0008]
  168. [    2.650000] pci 0000:03:00.0: BAR 2: failed to assign [io  size 0x0008]
  169. [    2.660000] pci 0000:03:00.0: BAR 1: no space for [io  size 0x0004]
  170. [    2.680000] pci 0000:03:00.0: BAR 1: failed to assign [io  size 0x0004]
  171. [    2.690000] pci 0000:03:00.0: BAR 3: no space for [io  size 0x0004]
  172. [    2.710000] pci 0000:03:00.0: BAR 3: failed to assign [io  size 0x0004]
  173. [    2.720000] pci 0000:00:02.0: PCI bridge to [bus 03]
  174. [    2.730000] pci 0000:00:02.0:   bridge window [mem 0x60400000-0x604fffff]
  175. [    2.750000] pci 0000:00:02.0:   bridge window [mem 0x60500000-0x605fffff pref]
  176. [    2.760000] BAR0 at slot 0 = 0
  177. [    2.770000] bus=0x0, slot = 0x0
  178. [    2.780000] BAR0 at slot 1 = 0
  179. [    2.780000] bus=0x0, slot = 0x1
  180. [    2.790000] BAR0 at slot 2 = 0
  181. [    2.800000] bus=0x0, slot = 0x2
  182. [    2.810000] bus=0x1, slot = 0x0, irq=0xff
  183. [    2.810000] bus=0x2, slot = 0x1, irq=0xff
  184. [    2.820000] bus=0x3, slot = 0x2, irq=0x0
  185. [    2.830000] Switched to clocksource MIPS
  186. [    2.850000] NET: Registered protocol family 2
  187. [    2.860000] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
  188. [    2.870000] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
  189. [    2.890000] TCP: Hash tables configured (established 2048 bind 2048)
  190. [    2.900000] TCP: reno registered
  191. [    2.910000] UDP hash table entries: 256 (order: 1, 8192 bytes)
  192. [    2.920000] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
  193. [    2.940000] NET: Registered protocol family 1
  194. [    2.950000] futex hash table entries: 1024 (order: 4, 65536 bytes)
  195. [    2.970000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  196. [    2.980000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
  197. [    3.000000] msgmni has been set to 499
  198. [    3.010000] io scheduler noop registered
  199. [    3.020000] io scheduler deadline registered (default)
  200. [    3.030000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
  201. [    3.050000] console [ttyS0] disabled
  202. [    3.060000] 1e000c00.uartlite: ttyS0 at MMIO 0x1e000c00 (irq = 34, base_baud = 3125000) is a 16550A
  203. [    3.080000] console [ttyS0] enabled
  204. [    3.080000] console [ttyS0] enabled
  205. [    3.090000] bootconsole [early0] disabled
  206. [    3.090000] bootconsole [early0] disabled
  207. [    3.110000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
  208. [    3.120000] m25p80 spi32766.0: using chunked io
  209. [    3.130000] 4 ofpart partitions found on MTD device spi32766.0
  210. [    3.150000] Creating 4 MTD partitions on "spi32766.0":
  211. [    3.160000] 0x000000000000-0x000000030000 : "u-boot"
  212. [    3.170000] 0x000000030000-0x000000040000 : "u-boot-env"
  213. [    3.180000] 0x000000040000-0x000000050000 : "factory"
  214. [    3.200000] 0x000000050000-0x000001000000 : "firmware"
  215. [    3.300000] random: nonblocking pool is initialized
  216. [    3.320000] 2 uimage-fw partitions found on MTD device firmware
  217. [    3.340000] 0x000000050000-0x0000001738b2 : "kernel"
  218. [    3.350000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
  219. [    3.380000] 0x0000001738b2-0x000001000000 : "rootfs"
  220. [    3.390000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
  221. [    3.420000] mtd: device 5 (rootfs) set to be root filesystem
  222. [    3.430000] 1 squashfs-split partitions found on MTD device rootfs
  223. [    3.440000] 0x000000640000-0x000001000000 : "rootfs_data"
  224. [    3.460000] netif_napi_add() called with weight 128 on device eth%d
  225. [    3.480000] change HW-TRAP to 0x17ccf
  226. [    3.490000] libphy: mdio: probed
  227. [    3.510000] ralink_soc_eth 1e100000.ethernet: loaded mt7530 driver
  228. [    3.530000] ralink_soc_eth 1e100000.ethernet eth0: ralink at 0xbe100000, irq 11
  229. [    3.540000] mt7621_wdt 1e000100.wdt: Initialized
  230. [    3.560000] TCP: cubic registered
  231. [    3.560000] NET: Registered protocol family 17
  232. [    3.570000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
  233. [    3.600000] 8021q: 802.1Q VLAN Support v1.8
  234. [    3.620000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
  235. [    3.640000] Freeing unused kernel memory: 156K (80349000 - 80370000)
  236. [    5.420000] init: failed to symlink /tmp -> /var
  237. [    5.430000] init: Console is alive
  238. [    5.440000] init: - watchdog -
  239. [    7.870000] ralink_soc_eth 1e100000.ethernet eth0: port 3 link up
  240. [    8.950000] usbcore: registered new interface driver usbfs
  241. [    8.960000] usbcore: registered new interface driver hub
  242. [    8.970000] usbcore: registered new device driver usb
  243. [    8.990000] exFAT: Version 1.2.9
  244. [    9.030000] SCSI subsystem initialized
  245. [    9.060000] ahci 0000:03:00.0: SSS flag set, parallel bus scan disabled
  246. [    9.070000] ahci 0000:03:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
  247. [    9.090000] ahci 0000:03:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
  248. [    9.110000] scsi host0: ahci
  249. [    9.120000] scsi host1: ahci
  250. [    9.120000] ata1: SATA max UDMA/133 abar m512@0x60400000 port 0x60400100 irq 33
  251. [    9.140000] ata2: SATA max UDMA/133 abar m512@0x60400000 port 0x60400180 irq 33
  252. [    9.510000] ata1: SATA link down (SStatus 0 SControl 300)
  253. [    9.870000] ata2: SATA link down (SStatus 0 SControl 300)
  254. [    9.900000] FM_OUT value: u4FmOut = 0(0x00000000)
  255. [    9.930000] FM_OUT value: u4FmOut = 0(0x00000000)
  256. [    9.960000] FM_OUT value: u4FmOut = 0(0x00000000)
  257. [    9.990000] FM_OUT value: u4FmOut = 0(0x00000000)
  258. [   10.020000] FM_OUT value: u4FmOut = 0(0x00000000)
  259. [   10.050000] FM_OUT value: u4FmOut = 0(0x00000000)
  260. [   10.080000] FM_OUT value: u4FmOut = 0(0x00000000)
  261. [   10.110000] FM_OUT value: u4FmOut = 0(0x00000000)
  262. [   10.140000] FM_OUT value: u4FmOut = 0(0x00000000)
  263. [   10.170000] FM_OUT value: u4FmOut = 0(0x00000000)
  264. [   10.240000] FM_OUT value: u4FmOut = 0(0x00000000)
  265. [   10.270000] FM_OUT value: u4FmOut = 0(0x00000000)
  266. [   10.300000] FM_OUT value: u4FmOut = 0(0x00000000)
  267. [   10.330000] FM_OUT value: u4FmOut = 0(0x00000000)
  268. [   10.360000] FM_OUT value: u4FmOut = 0(0x00000000)
  269. [   10.390000] FM_OUT value: u4FmOut = 0(0x00000000)
  270. [   10.420000] FM_OUT value: u4FmOut = 0(0x00000000)
  271. [   10.450000] FM_OUT value: u4FmOut = 0(0x00000000)
  272. [   10.480000] FM_OUT value: u4FmOut = 0(0x00000000)
  273. [   10.510000] FM_OUT value: u4FmOut = 0(0x00000000)
  274. [   10.670000] xhci-hcd xhci-hcd: xHCI Host Controller
  275. [   10.680000] xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 1
  276. [   10.700000] xhci-hcd xhci-hcd: irq 30, io mem 0x1e1c0000
  277. [   10.710000] hub 1-0:1.0: USB hub found
  278. [   10.720000] hub 1-0:1.0: 2 ports detected
  279. [   10.730000] xhci-hcd xhci-hcd: xHCI Host Controller
  280. [   10.740000] xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 2
  281. [   10.760000] hub 2-0:1.0: USB hub found
  282. [   10.760000] hub 2-0:1.0: 1 port detected
  283. [   10.780000] MTK MSDC device init.
  284. [   10.830000] msdc0 -> set mclk to 0!!! <- msdc_set_mclk() : L<641> PID<kworker/u8:1><0x17>
  285. [   10.830000] mtk-sd: MediaTek MT6575 MSDC Driver
  286. [   10.830000] sdhci: Secure Digital Host Controller Interface driver
  287. [   10.830000] sdhci: Copyright(c) Pierre Ossman
  288. [   10.830000] sdhci-pltfm: SDHCI platform and OF driver helper
  289. [   10.830000] usbcore: registered new interface driver usb-storage
  290. [   11.440000] init: - preinit -
  291. Press the [f] key and hit [enter] to enter failsafe mode
  292. Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
  293. [   15.180000] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
  294. [   15.210000] procd: - early -
  295. [   15.220000] procd: - watchdog -
  296. [   16.060000] procd: - ubus -
  297. [   17.070000] procd: - init -
  298. Please press Enter to activate this console.
  299. [   17.980000] NET: Registered protocol family 10
  300. [   18.000000] ntfs: driver 2.1.31 [Flags: R/O MODULE].
  301. [   18.020000] ip6_tables: (C) 2000-2006 Netfilter Core Team
  302. [   18.050000] hidraw: raw HID events driver (C) Jiri Kosina
  303. [   18.070000] fuse init (API version 7.23)
  304. [   19.070000]
  305. [   19.070000]
  306. [   19.070000] === pAd = c0781000, size = 1980536 ===
  307. [   19.070000]
  308. [   19.090000] <-- RTMPAllocTxRxRingMemory, Status=0
  309. [   19.100000] <-- RTMPAllocAdapterBlock, Status=0
  310. [   19.110000] device_id =0x7662
Copy the code
This is reproducable and always happening around second 18/19 after the following two lines:
I can enter boot command line interface, tftp and http-download and failsafe-mode via serial debug console.
The device is not responding to "ping" in any mode. The only mode where it responds is http-download. Telnet doesnt seem to work. TFTP wont accept any files.
In failsafe mode Im able to do "mount_root" and "firstboot":
  1. root@(none):/# mount_root
  2. [   90.950000] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
  3. root@(none):/# firstboot -y
  4. [   95.170000] jffs2reset: /dev/mtdblock6 is not mounted
  5. [   95.180000] jffs2reset: /dev/mtdblock6 will be erased on next mount
Copy the code
Is there any way to revive this device? I would be happy to bring in any details needed...
Thanks for your efforts _ moritz
Posted at 1/11/2026 15:23:04        Only Author  2#
CertShikenϡ¤ΥƥΥ`W줺ˤĤƤƥĤǤʤǥץ쥤ǤԇY|Ȼشˤmä褦ȤƤޤ줬˽κϸʤ98100ȸߤɤǤǩ`ϥ˩`ǡΥꥢФǤ Databricks-Certified-Professional-Data-Engineer㏊ΥȥȤʹäȡ쥸`ѧYSळȤǤDatabricks-Certified-Professional-Data-EngineerԇY˺ϸ񤹤ȴ_g˺ϸ񤷤ޤ Databricks-Certified-Professional-Data-EngineerʂYϤݤˤĤƤϡTҤˤäƺػ졢ǥץ쥤τĤOӋƤޤԇƘSǤ
Posted at 1/15/2026 13:06:26        Only Author  3#
That article was a real treasure trove of knowledge. Get your hands on the FCSS_SDW_AR-7.6 valid exam sample online test that helped me achieve a promotion and salary increase, and its available for free today. I hope you hit your career goals soon!
Posted at 1/16/2026 13:21:33        Only Author  4#
Thank you for your article, it left an unforgettable impression on me. NCP-AI reliable exam discount voucher is free and offers rich content to help you on your educational journey.
Posted at 1/24/2026 15:04:57        Only Author  5#
Your article has made a lasting impression, thank you! Heres the Latest test N16291GC10 sample questions test I took to earn my promotion and raise, now free for you today. Best of luck in your professional journey!
Posted at 1/25/2026 23:22:51        Only Author  6#
What an enlightening and motivating read, thank you for sharing! Free Valid real PT-AM-CPE exam exam questionsgood luck to everyone!
Posted at 1/28/2026 13:06:27        Only Author  7#
Thank you so much for your article, its something Ill remember. The Reliable practice 1z0-1065-25 exam online exam questions are available for freeyour ticket to a promotion and salary increase!
Posted at 1/28/2026 22:10:17        Only Author  8#
The content is so good, Im liking it immediately. About to face the Arch-302 valid exam sample online exam C hoping for good results!
