[General] Get a Free Demo of Salesforce OmniStudio-Developer Questions Before Purchase
135
【General】 Get a Free Demo of Salesforce OmniStudio-Developer Questions Before Purchase
Posted at 1/21/2026 06:33:13      View:121 | Replies:3        Print      Only Author   [Copy Link] 1#
2026 Latest PassReview OmniStudio-Developer PDF Dumps and OmniStudio-Developer Exam Engine Free Share: https://drive.google.com/open?id=1ec2XuHVTm8t8cLyWj_OVDEp7zi9lzpZM
You choosing PassReview to help you pass Salesforce certification OmniStudio-Developer exam is a wise choice. You can first online free download PassReview's trial version of exercises and answers about Salesforce Certification OmniStudio-Developer Exam as a try, then you will be more confident to choose PassReview's product to prepare for Salesforce certification OmniStudio-Developer exam. If you fail the exam, we will give you a full refund.
Salesforce OmniStudio-Developer Exam Syllabus Topics:
  • Expression Sets & Decision Matrices: It gives an understanding of the mechanics of a Decision Matrix and an Expression Set.
  • OmniScripts: Various elements and their configuration are discussed in the topic. It also focuses on JSON data structure that supports OmniScript.
  • Omnistudio Data Raptors: This topic is all about DataRaptor Extract functionality, DataRaptor Load functionality, DataRaptor Transform functionality, and DataRaptor Turbo Extract functionality.
  • FlexCards: The focus of this topic is on data sources, fields, and actions to configure on cards and card states. Moreover, it covers concepts required to build the JSON data structure.
Salesforce OmniStudio platform is a powerful tool that enables developers to create and deploy customized solutions quickly and easily. The platform includes a variety of development tools, including Apex, Visualforce, and Lightning components, as well as pre-built templates and components that can be customized to meet specific business needs.
To become a Salesforce Certified OmniStudio Developer, candidates must pass a comprehensive exam that covers a broad range of topics related to the OmniStudio platform. Candidates must have experience in developing and implementing solutions on the Lightning Platform and must demonstrate their knowledge and skills through OmniStudio-Developer Exam. Salesforce Certified OmniStudio Developer certification is an excellent way for developers to demonstrate their expertise and differentiate themselves in the competitive Salesforce job market.
Web-Based Practice Exams to Evaluate OmniStudio-Developer Salesforce Certified OmniStudio Developer Exam PreparationTo choose our PassReview to is to choose success! PassReview provide you Salesforce certification OmniStudio-Developer exam practice questions and answers, which enable you to pass the exam successfully. Simulation tests before the formal Salesforce certification OmniStudio-Developer examination are necessary, and also very effective. If you choose PassReview, you can 100% pass the exam.
Salesforce Certified OmniStudio Developer Sample Questions (Q30-Q35):NEW QUESTION # 30
A customer sets up two LWC OmniScripts, one embedded into another. AccountId is set in a Set Values element in the parent OmniScript. The Accountid set in the parent OmniScript is used to set another Set values element ContextAccountId in the emvedded OmniScript. The embedded OmniScript is activated.
While previewing the OmniScript flow from the parent, it is found that Account I set correct in the parent OmniScript. However ContextAccount in the embedded OmniScript is not set with the Accountid from parent OmniScript. On previewing the embedded OmniScript individually. It is found that ContextAccountId is set correctly.
What is the reason for this? Refer to the exhibit below.
  • A. The flag passData.JSON in the parent OmniScript in not configured correctly.
  • B. Both parent and embedded OmniScripts have the same element name for the Set Values element.
  • C. A developer failed to include a Navigate Action Element to pass data from the parent OmniScript.
  • D. The WLC PubSub Messge flag in the Set Values action of the parent OmniScript has not been set.
NEW QUESTION # 31
Why woulda developerclone an Integration Procedure instead of versioning it?
  • A. The new Integration Procedure uses a Cache Block.
  • B. The new Integration Procedure it replacing stub data.
  • C. The new Integration Procedure is Chainable.
  • D. The new Integration Procedure will be used independently
Cloning an Integration Procedure creates a copy of it that can be modified and used independently from the original one. This is useful when the new Integration Procedure has a different purpose or functionality than the original one
NEW QUESTION # 32
A customer sets up to LWC Omniscripts, one embedded into another. Account is set in a Set Values element in the parent Omniscript.
The AccountId set in the parent Omniscript is used to another Set Values element ContextAccountid in the embedded OmniScript. The embedded Omniscript is activated.
While previewing the OmniScript flow from the parent, it is found that Account is set correctly in the parent OmniScript. However. ContextAccountId in the embedded OmniScript is not set with the AccountId from parent Omniscript. On previewing the embedded OmniScript individually, it is found that ContextAccountId is set correctly.
  • A. A developer failed to include a Navigation Element to pass data from the parent OmniScript.
  • B. The flag passDataJSON in the parent OmniScript in not configured correctly.
  • C. Both parent and embedded OmniScripts have the same element name for the Set values element.
  • D. The LWC PubSub Message flag in the Set Values action of the parent has not been set.
NEW QUESTION # 33
Refer to the exhibit below. A developer has configured an Integration Procedure element with SEND
/RESPONSE TRANSFORMATIONS as shown.
Alternatively, how could the developer configure Additional Input tosend exactly the same data? Assume that the developer checked Send Only Additional Input.
  • A.
  • B.
  • C.
  • D.
The Additional Input property allows the developer to specify additional input parameters to be sent to the Integration Procedure element. The input parameters can be specified as a JSON object or as a list of key- value pairs. If the developer checked Send Only Additional Input, then only the input parameters specified in Additional Input are sent, and the SEND/RESPONSE TRANSFORMATIONS are ignored. Therefore, the developer needs to specify the same input parameters as in the SEND/RESPONSE TRANSFORMATIONS in Additional Input. Option C shows how to do this using a JSON object with two properties: "DBExtractAction:
Account" and "DBExtractAction:SecondaryAccount". The values of these properties are the same as in the SEND/RESPONSE TRANSFORMATIONS.
NEW QUESTION # 34
What two advantages does a DataRaptor Turbo Extract have over a standard DataRaptor Extract?
Choose 2 answers
  • A. It is easier to configure
  • B. It populates data in PDF and DocuSign format
  • C. Ithas betterperformance at runtime
  • D. It supports complex field mappings
A DataRaptor Turbo Extract is a simplified version of a DataRaptor Extract that can retrieve data from a single object without changing the structure of the output data. It is easier to configure because it does not require defining extraction steps or JSON paths. It also has better performance at runtime because it uses a native query engine instead of a custom one
NEW QUESTION # 35
The Salesforce OmniStudio-Developer real questions are an advanced strategy to prepare you according to the test service. You can change the time and type of questions of the Salesforce OmniStudio-Developer exam dumps. OmniStudio-Developer practice questions improve your confidence and ability to complete the exam timely. We ensure success on the first attempt if you use our Salesforce OmniStudio-Developer Exam Dumps according to our instructions.
OmniStudio-Developer Exam Sample Questions: https://www.passreview.com/OmniStudio-Developer_exam-braindumps.html
P.S. Free 2026 Salesforce OmniStudio-Developer dumps are available on Google Drive shared by PassReview: https://drive.google.com/open?id=1ec2XuHVTm8t8cLyWj_OVDEp7zi9lzpZM
Posted at 1/22/2026 04:30:00        Only Author  2#
This article has helped me look at the problem from different perspectives, and I’ve gained a lot. Strengthen your IT abilities with free AZ-801 valid vce exam simulator. Wishing you all the best!
Posted at 1/23/2026 05:47:59        Only Author  3#
I deeply appreciate your share, this article is simply astonishing! Free access to C_ARSUM_2508 reliable exam dumps file, full of rich content, is available to enhance your studies.
Posted at 3/6/2026 23:59:15        Only Author  4#
The article is very rich in content and has introduced me to many new ideas. Free IIA-CIA-Part3 exam pass4sure resources for your exam prep. Best of luck to everyone!
