Amazon AWS-Developer exam questions & answers, AWS-Developer real exams
Posted at 2/18/2026 22:55:03
View102
Replies0
2026 Latest iPassleader AWS-Developer PDF Dumps and AWS-Developer Exam Engine Free Share: https://drive.google.com/open?id=1rFusLPSaWllsyGiAj0ADTiW7SiO7eyGf
To know well your level of AWS-Developer Exam Preparation, we offer you the online test engine version which is an exam simulation to help you in knowing your week point in AWS-Developer practice test and therefore provide an opportunity to fulfill your deficiencies prior to Amazon real exam. Once there are latest versions released, we will send it to your email immediately.
To some extent, to pass the AWS-Developer exam means that you can get a good job. The AWS-Developer exam materials you master will be applied to your job. The possibility to enter in big and famous companies is also raised because they need outstanding talents to serve for them. Our AWS-Developer Test Prep is compiled elaborately and will help the client a lot. Our product is of high quality and the passing rate and the hit rate are both high.
Valid AWS-Developer Exam Experience & Valid Dumps AWS-Developer FilesThese AWS-Developer practice exams train you to manage time so that you can solve questions of the AWS-Developer real test on time. iPassleader offers Amazon practice tests which provide you with real examination scenarios. By practicing under the pressure of AWS-Developer real test again and again, you can overcome your AWS Certified Developer Associate Exam (DVA-C02) exam anxiety. Taking AWS-Developer these practice exams is important for you to attempt Amazon real dumps questions and pass AWS-Developer certification exam test on the first take.
Amazon AWS Certified Developer Associate Exam (DVA-C02) Sample Questions (Q149-Q154):NEW QUESTION # 149
A development team uses AWS Elastic Beanstalk for application deployment. The team has configured the application version lifecycle policy to limit the number of application versions to 25.
However, even with the lifecycle policy, the source bundle is deleted from the Amazon S3 source bucket.
What should a developer do in the Elastic Beanstalk application version lifecycle settings to retain the source code in the S3 bucket?
- A. Set Retention to Retain source bundle in S3.
- B. Change the Set the application versions limit by total count setting to zero.
- C. Disable the Lifecycle policy setting.
- D. Change the Set the application version limit by age setting to zero.
https://digitalcloud.training/ce ... /elastic-beanstalk/
NEW QUESTION # 150
In Amazon SNS, to send push notifications to mobile devices using Amazon SNS and ADM, you need to obtain the following, except:
- A. Client ID
- B. Client secret
- C. Device token
- D. Registration ID
To send push notifications to mobile devices using Amazon SNS and ADM, you need to obtain the following: Registration ID and Client secret.
http://docs.aws.amazon.com/sns/latest/dg/SNSMobilePushPrereq.html
NEW QUESTION # 151
A Developer is designing a fault-tolerant environment where client sessions will be saved.
How can the Developer ensure that no sessions are lost if an Amazon EC2 instance fails?
- A. Use Amazon DynamoDB to perform scalable session hadling.
- B. Use Elastic Load Balancer connection draining to stop sending requests to failing instances.
- C. Use sticky sessions with an Elastic Load Balancer target group.
- D. Use Amazon SQS to save session data.
The key word is fault-tolerant. With sticky sessions the state is maintained on the EC2 instance if that fails state is lost. With DynamoDB the state is independent of EC2 therefore fault-tolerant.
NEW QUESTION # 152
A developer is migrating some features from a legacy monolithic application to use AWS Lambda functions instead. The application currently stores data in an Amazon Aurora DB cluster that runs in private subnets in a VPC. The AWS account has one VPC deployed. The Lambda functions and the DB cluster are deployed in the same AWS Region in the same AWS account.
The developer needs to ensure that the Lambda functions can securely access the DB cluster without crossing the public internet.
- A. Configure a NAT gateway and a security group for the Lambda functions.
- B. Configure an Amazon RDS database proxy for the Lambda functions.
- C. Configure the DB cluster's public access setting to Yes.
- D. Configure the VPC, subnets, and a security group for the Lambda functions.
This solution will meet the requirements by allowing the Lambda functions to access the DB cluster securely within the same VPC without crossing the public internet. The developer can configure a VPC endpoint for RDS in a private subnet and assign it to the Lambda functions. The developer can also configure a security group for the Lambda functions that allows inbound traffic from the DB cluster on port 3306 (MySQL).
Option A is not optimal because it will expose the DB cluster to public access, which may compromise its security and data integrity. Option B is not optimal because it will introduce additional latency and complexity to use an RDS database proxy for accessing the DB cluster from Lambda functions within the same VPC. Option C is not optimal because it will require additional costs and configuration to use a NAT gateway for accessing resources in private subnets from Lambda functions.
References: [Configuring a Lambda Function to Access Resources in a VPC]
NEW QUESTION # 153
A Developer has implemented a Lambda function that needs to add new customers to an RDS database that is expected to run hundreds of times per hour. The Lambda function is configured to use 512MB of RAM and is based on the following pseudo code:
After testing the Lambda function, the Developer notices that the Lambda execution time is much longer than expected. What should the Developer do to improve performance?
- A. Increase the amount of RAM allocated to the Lambda function, which will increase the number of threads the Lambda can use.
- B. Increase the size of the RDS database to allow for an increased number of database connections each hour.
- C. Move the database connection and close statement out of the handler. Place the connection in the global space.
- D. Replace RDS wit Amazon DynamoDB to implement control over the number of writes per second.
NEW QUESTION # 154
The AWS Certified Developer Associate Exam (DVA-C02) (AWS-Developer) practice test software keeps track of each previous attempt and highlights the improvements with each attempt. The AWS Certified Developer Associate Exam (DVA-C02) (AWS-Developer) mock exam setup can be configured to a particular style and arrive at unique questions. iPassleader Amazon AWS-Developer practice exam software went through real-world testing with feedback from more than 90,000 global professionals before reaching its latest form. The Amazon AWS-Developer Exam Dumps are similar to real exam questions. Our Amazon AWS-Developer practice test software is suitable for computer users with a Windows operating system.
Valid AWS-Developer Exam Experience: https://www.ipassleader.com/Amazon/AWS-Developer-practice-exam-dumps.html
Amazon Examcollection AWS-Developer Dumps We always put our customers in the first place, If you study AWS-Developer exam once you will pass your exam with high grades in the first attempt, Amazon Examcollection AWS-Developer Dumps Read on to check out the features of these three formats, Amazon AWS-Developer certification exam requires expensive materials, classes, and even flights to reach the exam centers, Amazon Examcollection AWS-Developer Dumps Furthermore, the users get 90 days free updates.
It explains each warehousing option, storage and handling operations, AWS-Developer strategic planning, and the effects of warehousing decisions on total logistics costs and customer service.
You also learn different ways in which Kafka can be used, including Exam AWS-Developer Simulator Free as a message system, a storage system, and for stream processing, We always put our customers in the first place.
Don't Miss Up to 365 Days of Free Updates - Buy Amazon AWS-Developer Questions NowIf you study AWS-Developer Exam once you will pass your exam with high grades in the first attempt, Read on to check out the features of these three formats, Amazon AWS-Developer certification exam requires expensive materials, classes, and even flights to reach the exam centers.
- AWS-Developer New Braindumps Files 👦 AWS-Developer Reliable Test Bootcamp 🕥 AWS-Developer Test Questions 🍶 Search on { [url]www.prepawaypdf.com } for ➡ AWS-Developer ️⬅️ to obtain exam materials for free download 🛴AWS-Developer Torrent[/url]
- AWS-Developer Exam Paper Pdf 🛢 AWS-Developer Dumps Discount 🛃 New AWS-Developer Braindumps Files 🥊 The page for free download of [ AWS-Developer ] on [url]www.pdfvce.com will open immediately ⏏AWS-Developer Reliable Test Bootcamp[/url]
- Simplified Document Sharing and Accessibility With Amazon AWS-Developer PDF (Dumps) ↕ Search on ➤ [url]www.troytecdumps.com ⮘ for ⏩ AWS-Developer ⏪ to obtain exam materials for free download 🌝AWS-Developer Updated Dumps[/url]
- Free PDF 2026 AWS-Developer - Examcollection AWS Certified Developer Associate Exam (DVA-C02) Dumps 🧒 Search for ▶ AWS-Developer ◀ and download it for free immediately on [url]www.pdfvce.com 🕚Latest AWS-Developer Exam Guide[/url]
- 2026 RealisticValid AWS-Developer Exam Experience - Amazon Examcollection AWS Certified Developer Associate Exam (DVA-C02) Dumps 100% Pass 😒 Download ▛ AWS-Developer ▟ for free by simply searching on ⏩ [url]www.pass4test.com ⏪ 💕Valid Test AWS-Developer Format[/url]
- Realistic Examcollection AWS-Developer Dumps - Pass AWS-Developer Exam 🎍 Search for ➠ AWS-Developer 🠰 and download it for free immediately on ➽ [url]www.pdfvce.com 🢪 🌞AWS-Developer Hot Questions[/url]
- Simplified Document Sharing and Accessibility With Amazon AWS-Developer PDF (Dumps) 🎀 Search for ➽ AWS-Developer 🢪 and download it for free immediately on ⇛ [url]www.practicevce.com ⇚ ↕AWS-Developer Exam Vce Format[/url]
- AWS-Developer Exam Vce Format 🛢 AWS-Developer Test Questions ⚗ Latest AWS-Developer Exam Guide 🥥 Copy URL [url]www.pdfvce.com open and search for ⏩ AWS-Developer ⏪ to download for free 🏋Latest AWS-Developer Exam Notes[/url]
- Valid Test AWS-Developer Format 🧑 Valid Test AWS-Developer Format 🤕 AWS-Developer Exam Paper Pdf 🪐 Search for AWS-Developer and download it for free immediately on ➽ [url]www.troytecdumps.com 🢪 🔌AWS-Developer Torrent[/url]
- Free PDF 2026 AWS-Developer - Examcollection AWS Certified Developer Associate Exam (DVA-C02) Dumps 🛹 Go to website ➤ [url]www.pdfvce.com ⮘ open and search for ⏩ AWS-Developer ⏪ to download for free 😿Valid Test AWS-Developer Vce Free[/url]
- 2026 RealisticValid AWS-Developer Exam Experience - Amazon Examcollection AWS Certified Developer Associate Exam (DVA-C02) Dumps 100% Pass 🤶 Open website ☀ [url]www.torrentvce.com ️☀️ and search for ▷ AWS-Developer ◁ for free download 👼Valid Test AWS-Developer Vce Free[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, technoeducat.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
P.S. Free & New AWS-Developer dumps are available on Google Drive shared by iPassleader: https://drive.google.com/open?id=1rFusLPSaWllsyGiAj0ADTiW7SiO7eyGf
