CertkingdomPDF Offers Three Formats of Updated Nutanix NCM-MCI Exam Questions
Posted at 4/19/2026 17:37:11
P.S. Free 2026 Nutanix NCM-MCI dumps are available on Google Drive shared by CertkingdomPDF: https://drive.google.com/open?id=1NOmN-DGAt_WduP4xG724-cqH4JOCCurb
CertkingdomPDF is the leading position in this field and famous for high pass rate. If you are headache about your qualification exams, our NCM-MCI learning guide materials will be a great savior for you. Now it is your opportunity that we provide the best valid and professional NCM-MCI study guide materials which have 100% pass rate. If you really want to Clear NCM-MCI Exam and gain success one time, choosing us will be the wise thing for you. If you hesitate about us please pay attention on below about our satisfying service and high-quality NCM-MCI guide torrent.
How To Get Nutanix NCM-MCI ExamNutanix NCM-MCI exam questions are getting popular among students and professionals these days. Nutanix NCM-MCI exam is a tough subject, but if you have the right Nutanix NCM-MCI exam dumps, then you will pass it without any difficulties.
Despite the fact that there are many Nutanix NCM-MCI exam dumps available on the web, most of them don't provide the right kind of help that students need to prepare for their exams. Certification Questions offers its clients with top quality Nutanix NCM-MCI Exam Dumps so that they can pass their exams easily.
There are many other reasons why Certification Questions is considered one of the best online sources for Nutanix NCM-MCI exam questions. Some of them are:
The Nutanix NCM-MCI Dumps offered by Certification Questions comes with a 100 percent success rate.
Certification Topics of Nutanix NCM-MCI Exam- Customer consultation
- Conceptual/logical design
- Physical design
Free PDF Quiz 2026 Nutanix NCM-MCI – High-quality Practice Exam PdfThe CertkingdomPDF Nutanix Certified Master - Multicloud Infrastructure v6.10 (NCM-MCI) exam dumps are ready for quick download. Just choose the right NCM-MCI exam questions format and download it after paying an affordable Nutanix Certified Master - Multicloud Infrastructure v6.10 in NCM-MCI Practice Questions charge and start this journey. Best of luck in the Nutanix NCM-MCI exam and career!!!
Nutanix Certified Master - Multicloud Infrastructure v6.10 Sample Questions (Q11-Q16):NEW QUESTION # 11
Task 8
Depending on the order you perform the exam items, the access information and credentials could change. Please refer to the other item performed on Cluster B if you have problems accessing the cluster.
The infosec team has requested that audit logs for API Requests and replication capabilities be enabled for all clusters for the top 4 severity levels and pushed to their syslog system using highest reliability possible. They have requested no other logs to be included.
Syslog configuration:
Syslog Name: Corp_syslog
Syslop IP: 34.69.43.123
Port: 514
Ensure the cluster is configured to meet these requirements.
See the Explanation for step by step solution
To configure the cluster to meet the requirements of the infosec team, you need to do the following steps:
Log in to Prism Central and go to Network > Syslog Servers > Configure Syslog Server. Enter Corp_syslog as the Server Name, 34.69.43.123 as the IP Address, and 514 as the Port. Select TCP as the Transport Protocol and enable RELP (Reliable Logging Protocol). This will create a syslog server with the highest reliability possible.
Click Edit against Data Sources and select Cluster B as the cluster. Select API Requests and Replication as the data sources and set the log level to CRITICAL for both of them. This will enable audit logs for API requests and replication capabilities for the top 4 severity levels (EMERGENCY, ALERT, CRITICAL, and ERROR) and push them to the syslog server. Click Save.
Repeat step 2 for any other clusters that you want to configure with the same requirements.
To configure the Nutanix clusters to enable audit logs for API Requests and replication capabilities, and push them to the syslog system with the highest reliability possible, you can follow these steps:
Log in to the Nutanix Prism web console using your administrator credentials.
Navigate to the "Settings" section or the configuration settings interface within Prism.
Locate the "Syslog Configuration" or "Logging" option and click on it.
Configure the syslog settings as follows:
Syslog Name: Enter "Corp_syslog" as the name for the syslog configuration.
Syslog IP: Set the IP address to "34.69.43.123", which is the IP address of the syslog system.
Port: Set the port to "514", which is the default port for syslog.
Enable the option for highest reliability or persistent logging, if available. This ensures that logs are sent reliably and not lost in case of network interruptions.
Save the syslog configuration.
Enable Audit Logs for API Requests:
In the Nutanix Prism web console, navigate to the "Cluster" section or the cluster management interface.
Select the desired cluster where you want to enable audit logs.
Locate the "Audit Configuration" or "Security Configuration" option and click on it.
Look for the settings related to audit logs and API requests. Enable the audit logging feature and select the top 4 severity levels to be logged.
Save the audit configuration.
Enable Audit Logs for Replication Capabilities:
Look for the settings related to audit logs and replication capabilities. Enable the audit logging feature and select the top 4 severity levels to be logged.
After completing these steps, the Nutanix clusters will be configured to enable audit logs for API Requests and replication capabilities. The logs will be sent to the specified syslog system with the highest reliability possible.
ncli
<ncli> rsyslog-config set-status enable=false
<ncli> rsyslog-config add-server name=Corp_Syslog ip-address=34.69.43.123 port=514 network-protocol=tdp relp-enabled=false
<ncli> rsyslog-config add-module server-name= Corp_Syslog module-name=APLOS level=INFO
<ncli> rsyslog-config add-module server-name= Corp_Syslog module-name=CEREBRO level=INFO
<ncli> rsyslog-config set-status enable=true
https://portal.nutanix.com/page/ ... =kA00e0000009CEECA2
NEW QUESTION # 12
Task1
A newly created Windows VM "SQL02" is experiencing poor storage performance when compared to "SQL01" running within the same cluster, on the same storage container.
The cluster is in a healthy state.
Create a new session named Monitor SQL02 with meaningful metrics. Right click on the session page and click Select All then paste this into Notepad and save it as Task 1.txt on the desktop.
Also, save the analysis as a report named "MonitorSQL02" and send the report as a PDF on a daily basis to perf_group@ACME.org. Reports should not be retained. If any new objects need to be created, use monitorvm2 in the name.
Finally, correct the issue within "SQL02"
Notes:
Do not power on the VMs.
While you will be creating a session, you will need to examine the VM configurations to determine the issue.
Do not delete the VM to resolve the issue, any other destructive change is acceptable
See the Explanation
This is a classic Nutanix performance troubleshooting scenario. The issue is almost certainly that the VM was created using the wrong Disk Bus Type (IDE or SATA instead of SCSI).
Here is the step-by-step solution to complete Task 1.
Part 1: Analysis and Reporting
Create the Session
Log in to Prism Central (or Prism Element, depending on the exam environment, but Analysis is usually a PC feature).
Navigate to Operations -> Analysis.
Click New Session.
Entity: Search for and select the VM named SQL02.
Metrics: Since the issue is storage performance, search for and add these specific metrics:
Hypervisor IOPS (or Controller IOPS)
Hypervisor IO Latency (or Controller IO Latency)
Hypervisor IO Bandwidth
Click Save.
Save Session Data (Task 1.txt)
Open the "Monitor SQL02" session you just created.
(Per instructions): Right-click anywhere on the chart/data area -> Click Select All.
Copy the selected text (Ctrl+C).
Open Notepad on the provided desktop.
Paste the data.
Save the file as Task 1.txt on the Desktop.
Create and Schedule the Report
While still in the Analysis session, click the Create Report (or "Add to Report") button.
Report Name: MonitorSQL02
Report Settings:
Format: PDF
Frequency: Daily
Email Recipient: perf_group@ACME.org
Retention: 0 (or "Do not retain", as requested).
Note: If the system forces you to create a new Report object and MonitorSQL02 is rejected, use monitorvm2 as the name per the instructions.
Save/Schedule the report.
Part 2: Diagnose and Fix the Issue
The Issue:
VM SQL02 was likely created with its data disks set to IDE or SATA.
Why this causes poor performance: IDE/SATA are emulated hardware with high CPU overhead and low queue depths (single-threaded).
The Standard: SQL01 (the healthy VM) is using SCSI, which is multithreaded and optimized for virtualization.
The Fix (Steps):
Navigate to the VM list in Prism.
Select SQL02 and click Update (or Edit).
Scroll down to the Disks section.
Identify the data disk(s). You will see the Bus Type listed as IDE or SATA.
Do not delete the VM. instead, perform a disk conversion (destructive change to the disk is allowed, but we want to keep the data).
Method to Convert (Clone to SCSI):
Hover over the IDE/SATA disk to see the path/filename of the vDisk (or write it down).
Click Add New Disk.
Operation: select Clone from ADSF file.
Path: Browse to the storage container and select the file associated with the current IDE disk.
Bus Type: Select SCSI (This is the critical fix).
Index: Ensure it doesn't conflict with existing disks (usually index 1 or higher for data).
Click Add.
Once the new SCSI disk is added, find the original IDE/SATA disk and click the X to remove it.
Click Save.
Note: You do not need to power on the VM to verify. The change from IDE to SCSI allows the VM to use the Nutanix VirtIO drivers for maximum storage performance.
NEW QUESTION # 13
Task 3
An administrator needs to assess performance gains provided by AHV Turbo at the guest level. To perform the test the administrator created a Windows 10 VM named Turbo with the following configuration.
1 vCPU
8 GB RAM
SATA Controller
40 GB vDisk
The stress test application is multi-threaded capable, but the performance is not as expected with AHV Turbo enabled. Configure the VM to better leverage AHV Turbo.
Note: Do not power on the VM. Configure or prepare the VM for configuration as best you can without powering it on.
To configure the VM to better leverage AHV Turbo, you can follow these steps:
Log in to Prism Element of cluster A using the credentials provided.
Go to VM > Table and select the VM named Turbo.
Click on Update and go to Hardware tab.
Increase the number of vCPUs to match the number of multiqueues that you want to enable. For example, if you want to enable 8 multiqueues, set the vCPUs to 8. This will improve the performance of multi-threaded workloads by allowing them to use multiple processors.
Change the SCSI Controller type from SATA to VirtIO. This will enable the use of VirtIO drivers, which are required for AHV Turbo.
Click Save to apply the changes.
Power off the VM if it is running and mount the Nutanix VirtIO ISO image as a CD-ROM device. You can download the ISO image from Nutanix Portal.
Power on the VM and install the latest Nutanix VirtIO drivers for Windows 10. You can follow the instructions from Nutanix Support Portal.
After installing the drivers, power off the VM and unmount the Nutanix VirtIO ISO image.
Power on the VM and log in to Windows 10.
Open a command prompt as administrator and run the following command to enable multiqueue for the VirtIO NIC:
ethtool -L eth0 combined 8
Replace eth0 with the name of your network interface and 8 with the number of multiqueues that you want to enable. You can use ipconfig /all to find out your network interface name.
Restart the VM for the changes to take effect.
You have now configured the VM to better leverage AHV Turbo. You can run your stress test application again and observe the performance gains.
https://portal.nutanix.com/page/ ... =kA00e000000LKPdCAO change vCPU to 2/4 ?
Change SATA Controller to SCSI:
acli vm.get Turbo
Output Example:
Turbo {
config {
agent_vm: False
allow_live_migrate: True
boot {
boot_device_order: "kCdrom"
boot_device_order: "kDisk"
boot_device_order: "kNetwork"
uefi_boot: False
cpu_passthrough: False
disable_branding: False
disk_list {
addr {
bus: "ide"
index: 0
cdrom: True
device_uuid: "994b7840-dc7b-463e-a9bb-1950d7138671"
empty: True
disk_list {
addr {
bus: "sata"
index: 0
container_id: 4
container_uuid: "49b3e1a4-4201-4a3a-8abc-447c663a2a3e"
device_uuid: "622550e4-fb91-49dd-8fc7-9e90e89a7b0e"
naa_id: "naa.6506b8dcda1de6e9ce911de7d3a22111"
storage_vdisk_uuid: "7e98a626-4cb3-47df-a1e2-8627cf90eae6"
vmdisk_size: 10737418240
vmdisk_uuid: "17e0413b-9326-4572-942f-68101f2bc716"
flash_mode: False
hwclock_timezone: "UTC"
machine_type: "pc"
memory_mb: 2048
nic_list {
connected: True
mac_addr: "50:6b:8d:b2:a5:e4"
network_name: "network"
network_type: "kNativeNetwork"
network_uuid: "86a0d7ca-acfd-48db-b15c-5d654ff39096"
type: "kNormalNic"
uuid: "b9e3e127-966c-43f3-b33c-13608154c8bf"
vlan_mode: "kAccess"
num_cores_per_vcpu: 2
num_threads_per_core: 1
num_vcpus: 2
num_vnuma_nodes: 0
vga_console: True
vm_type: "kGuestVM"
is_rf1_vm: False
logical_timestamp: 2
state: "Off"
uuid: "9670901f-8c5b-4586-a699-41f0c9ab26c3"
acli vm.disk_create Turbo clone_from_vmdisk=17e0413b-9326-4572-942f-68101f2bc716 bus=scsi remove the old disk acli vm.disk_delete 17e0413b-9326-4572-942f-68101f2bc716 disk_addr=sata.0
NEW QUESTION # 14
Task 16
Running NCC on a cluster prior to an upgrade results in the following output FAIL: CVM System Partition /home usage at 93% (greater than threshold, 90%) Identify the CVM with the issue, remove the fil causing the storage bloat, and check the health again by running the individual disk usage health check only on the problematic CVM do not run NCC health check Note: Make sure only the individual health check is executed from the affected node
To identify the CVM with the issue, remove the file causing the storage bloat, and check the health again, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and find the NCC health check output file from the list. You can use the date and time information to locate the file. The file name should be something like ncc-output-YYYY-MM-DD-HH-MM-SS.log.
Open the file and look for the line that says FAIL: CVM System Partition /home usage at 93% (greater than threshold, 90%). Note down the IP address of the CVM that has this issue. It should be something like X.X.X.X.
Log in to the CVM using SSH or console with the username and password provided.
Run the command du -sh /home/* to see the disk usage of each file and directory under /home. Identify the file that is taking up most of the space. It could be a log file, a backup file, or a temporary file. Make sure it is not a system file or a configuration file that is needed by the CVM.
Run the command rm -f /home/<filename> to remove the file causing the storage bloat. Replace <filename> with the actual name of the file.
Run the command ncc health_checks hardware_checks disk_checks disk_usage_check --cvm_list=X.X.X.X to check the health again by running the individual disk usage health check only on the problematic CVM. Replace X.X.X.X with the IP address of the CVM that you noted down earlier.
Verify that the output shows PASS: CVM System Partition /home usage at XX% (less than threshold, 90%). This means that the issue has been resolved.
#access to CVM IP by Putty
allssh df -h #look for the path /dev/sdb3 and select the IP of the CVM
ssh CVM_IP
ls
cd software_downloads
ls
cd nos
ls -l -h
rm files_name
df -h
NEW QUESTION # 15
Task 15
An administrator found a CentOS VM, Cent_Down, on the cluster with a corrupted network stack. To correct the issue, the VM will need to be restored from a previous snapshot to become reachable on the network again.
VM credentials:
Username: root
Password: nutanix/4u
Restore the VM and ensure it is reachable on the network by pinging 172.31.0.1 from the VM.
Power off the VM before proceeding.
To restore the VM and ensure it is reachable on the network, you can follow these steps:
Log in to the Web Console of the cluster where the VM is running.
Click on Virtual Machines on the left menu and find Cent_Down from the list. Click on the power icon to power off the VM.
Click on the snapshot icon next to the power icon to open the Snapshot Management window.
Select a snapshot from the list that was taken before the network stack was corrupted. You can use the date and time information to choose a suitable snapshot.
Click on Restore VM and confirm the action in the dialog box. Wait for the restore process to complete.
Click on the power icon again to power on the VM.
Log in to the VM using SSH or console with the username and password provided.
Run the command ping 172.31.0.1 to verify that the VM is reachable on the network. You should see a reply from the destination IP address.
Go to VMS from the prism central gui
Select the VMand go to More -> Guest Shutdown
Go to Snapshots tab and revert to latest snapshot available
power on vm and verify if ping is working
NEW QUESTION # 16
We offer you free demo for NCM-MCI pdf dumps. You can check out the questions quality and usability of our training material before you buy. Nutanix NCM-MCI questions are written to the highest standards of technical accuracy with accurate answers. If you prepare for your exams using CertkingdomPDF NCM-MCI practice torrent, it is easy to succeed for your certification in the first attempt. Besides, we offer the money refund policy, in case of failure, you can ask for full refund.
NCM-MCI Exam Topics: https://www.certkingdompdf.com/NCM-MCI-latest-certkingdom-dumps.html
- Test NCM-MCI Dump ⏩ NCM-MCI Latest Exam 🌴 New NCM-MCI Test Syllabus 🔳 Enter ➽ [url]www.vce4dumps.com 🢪 and search for ( NCM-MCI ) to download for free ✏NCM-MCI Exam Vce[/url]
- NCM-MCI Latest Exam Test 🥘 NCM-MCI Reliable Exam Price 🌈 New NCM-MCI Exam Test 🛅 Search for ⇛ NCM-MCI ⇚ on 《 [url]www.pdfvce.com 》 immediately to obtain a free download 💝NCM-MCI Unlimited Exam Practice[/url]
- Cost Effective NCM-MCI Dumps 🕥 NCM-MCI Test Questions Answers 🎵 NCM-MCI Related Content ⛪ Search for ➥ NCM-MCI 🡄 and download it for free on 《 [url]www.troytecdumps.com 》 website 👯NCM-MCI Related Content[/url]
- NCM-MCI Exam Vce 🔴 NCM-MCI Test Questions Answers 🕢 NCM-MCI Pass4sure Pass Guide 🧿 Open website [ [url]www.pdfvce.com ] and search for ⏩ NCM-MCI ⏪ for free download 🌑Test NCM-MCI Dump[/url]
- 2026 Practice NCM-MCI Exam Pdf 100% Pass | The Best Nutanix Certified Master - Multicloud Infrastructure v6.10 Exam Topics Pass for sure 🧥 Search on “ [url]www.examcollectionpass.com ” for ▶ NCM-MCI ◀ to obtain exam materials for free download 🤖NCM-MCI Latest Exam[/url]
- NCM-MCI Unlimited Exam Practice 🔟 NCM-MCI Unlimited Exam Practice 🧚 NCM-MCI Reliable Braindumps Free 🍦 Go to website ➥ [url]www.pdfvce.com 🡄 open and search for [ NCM-MCI ] to download for free 🎽NCM-MCI Online Version[/url]
- Valid NCM-MCI Test Dumps 📗 NCM-MCI Test Questions Answers 💧 New NCM-MCI Exam Pattern 📔 Copy URL ➥ [url]www.exam4labs.com 🡄 open and search for ⇛ NCM-MCI ⇚ to download for free 🥍NCM-MCI Pass4sure Pass Guide[/url]
- Cost Effective NCM-MCI Dumps 🦚 Pdf NCM-MCI Pass Leader 🚝 NCM-MCI Latest Exam 🏞 Immediately open ✔ [url]www.pdfvce.com ️✔️ and search for { NCM-MCI } to obtain a free download 💧NCM-MCI Online Version[/url]
- 100% Pass Nutanix - NCM-MCI - Useful Practice Nutanix Certified Master - Multicloud Infrastructure v6.10 Exam Pdf 🌺 Search for ☀ NCM-MCI ️☀️ and easily obtain a free download on 「 [url]www.troytecdumps.com 」 👌
df NCM-MCI Pass Leader[/url] - Get Success in Nutanix NCM-MCI Certification Exam on First Attempt 🤦 Go to website ⮆ [url]www.pdfvce.com ⮄ open and search for 「 NCM-MCI 」 to download for free 🥏New NCM-MCI Exam Test[/url]
- Test NCM-MCI Dump 🤡 NCM-MCI Exam Vce 📳 NCM-MCI Reliable Exam Price 🚝 Simply search for ➤ NCM-MCI ⮘ for free download on ✔ [url]www.examdiscuss.com ️✔️ 🤿Test NCM-MCI Dump[/url]
- www.so0912.com, issuu.com, www.stes.tyc.edu.tw, ycs.instructure.com, github.com, ummalife.com, lms.terasdigital.co.id, www.spatial.io, www.du71l.cn, rasmir.com, Disposable vapes
What's more, part of that CertkingdomPDF NCM-MCI dumps now are free: https://drive.google.com/open?id=1NOmN-DGAt_WduP4xG724-cqH4JOCCurb
