[Hardware] Free Salesforce AP-202 Practice | AP-202 Valid Dumps Free
103
【Hardware】 Free Salesforce AP-202 Practice | AP-202 Valid Dumps Free
Posted at 2/16/2026 07:59:27      View:96 | Replies:2        Print      Only Author   [Copy Link] 1#
To make sure your possibility of passing the certificate, we hired first-rank experts to make our AP-202 exam materials. So the proficiency of our team is unquestionable. They help you to review and stay on track without wasting your precious time on useless things. By handpicking what the AP-202 study questions usually tested in exam and compile them into our AP-202 practice guide, they win wide acceptance with first-rank praise.
People always feel fear of the unknown thing and cannot handle themselves with a sudden change. However, our AP-202 exam questions can stand by your side. And we are determined to devote ourselves to serving you with the superior AP-202 Study Materials in this career. Here are some features of our AP-202 learning guide in our free demos which you can free download, you can understand in detail and make a choice.
AP-202 Valid Dumps Free | AP-202 Test Objectives PdfFirst of all, you are able to make full use of our AP-202 study torrent through three different versions: PDF, PC and APP online version of our AP-202 training guide. For each version, there is no limit and access permission if you want to download our study materials, and at the same time the number of people is not limited. After you purchase AP-202 Study Materials, we guarantee that your AP-202 study material is tailor-made. The last but not least, we can provide you with a free trial service on the AP-202 exam questions.
Salesforce B2B Commerce for Developers Accredited Professional Sample Questions (Q19-Q24):NEW QUESTION # 19
What tool can a developer use to investigate errors during development?
  • A. Checkout Flow Log
  • B. Browser dev tools
  • C. Commerce Diagnostics Event Logging
  • D. Support cases
Browser dev tools are a set of web authoring and debugging tools built into most modern browsers. They allow developers to inspect, edit, and debug the HTML, CSS, JavaScript, and network activity of a web page. They can also provide useful information about errors, warnings, performance, and accessibility issues. Browser dev tools are especially helpful for developing and testing Lightning web components, as they can display the component hierarchy, attributes, events, and slots.
The other options are not correct because:
A) Commerce Diagnostics Event Logging is a feature that enables developers to capture and analyze events that occur during the execution of B2C Commerce code. It can help identify performance bottlenecks, memory leaks, and unexpected behavior. However, it is not a tool that can be used directly by the developer, but rather a service that requires a support request to enable and access.
B) Checkout Flow Log is a log file that shows the details of the checkout flow execution, such as the input and output parameters, the pipeline steps, and the errors and warnings. It can help troubleshoot issues related to the checkout process, such as payment, shipping, or tax calculation. However, it is not a tool that can be used during development, but rather a log file that can be accessed after the checkout flow has run.
C) Support cases are requests for assistance from the Salesforce support team. They can help resolve technical issues, provide guidance, or escalate bugs. However, they are not a tool that can be used to investigate errors during development, but rather a communication channel that can be used after the developer has exhausted other resources.
Browser Dev Tools
Debug Your Lightning Web Components
[Checkout Flow Log]
NEW QUESTION # 20
Inwhich three different ways can a theme be enabled in
Salesforce B2B Commerce? (3 answers)
  • A. Dynamically through a hook
  • B. An Account Group field value
  • C. A Storefront setting
  • D. A per user setting
  • E. Account
Answer: A,B,C
A theme can be enabled in Salesforce B2B Commerce in three different ways:
A Storefront setting: The theme can be specified in the Storefront Configuration settings in CCAdmin. This will apply the theme to all users who access the storefront.
An Account Group field value: The theme can be specified in the Theme field of an Account Group record in Salesforce. This will apply the theme to all users who belong to that account group.
Dynamically through a hook: The theme can be specified dynamically by extending the cc_hk_theme hook. This hook allows changing the theme based on various factors, such as the user, cart, product, or storefront. For example, the hook can apply a different theme for a specific product category or for a specific user segment.
NEW QUESTION # 21
Which two are considered discrete units of work (code units) within a transaction in the debug logs?
  • A. Lightning component load
  • B. Validation rule
  • C. Apex class
  • D. Web service invocation
Two data types that are considered discrete units of work (code units) within a transaction in the debug logs are web service invocation and Apex class. A discrete unit of work (code unit) is a segment of executable code that runs as part of a transaction in Salesforce. A transaction is a sequence of operations that are treated as a single unit of work and are executed under certain isolation and consistency rules. A transaction can consist of one or more discrete units of work (code units) that are executed sequentially or concurrently depending on various factors such as triggers, asynchronous calls, or limits. A debug log is a record of database operations, system processes, and errors that occur when executing a transaction or running unit tests in Salesforce. A debug log can capture information about each discrete unit of work (code unit) within a transaction, such as its start time, end time, duration, events, variables, and limits. A web service invocation is a type of discrete unit of work (code unit) that involves calling an external web service from Apex code using SOAP or REST protocols. A web service invocation can be synchronous or asynchronous depending on the method used to make the callout. A web service invocation can be captured in a debug log with its details and results. An Apex class is another type of discrete unit of work (code unit) that involves executing Apex code that defines a class with properties and methods. An Apex class can be invoked from various sources such as triggers, Visualforce pages, Lightning components, or API calls. An Apex class can be captured in a debug log with its details and results. A validation rule is not a type of discrete unit of work (code unit) within a transaction in the debug logs, as it is not a segment of executable code but rather a formula expression that defines a business rule for a field or object. A validation rule can be evaluated during a transaction and cause an error if the rule condition is not met, but it cannot be captured as a separate code unit in a debug log. A Lightning component load is not a type of discrete unit of work (code unit) within a transaction in the debug logs either, as it is not a segment of executable code but rather an event that occurs when a Lightning component is rendered on a web page or application. A Lightning component load can be measured by various performance tools such as Lightning Inspector or Lighthouse, but it cannot be captured as a separate code unit in a debug log. Salesforce [Salesforce Developer Blog: Transactions and Request Processing], [Salesforce Help: Debug Logs], [Salesforce Developer Guide: Invoking Callouts Using Apex], [Salesforce Developer Guide: Apex Classes], [Salesforce Help: Validation Rules], [Salesforce Developer Blog: Measuring Lightning Component Performance]
NEW QUESTION # 22
How can the display of CC Menu Items be customized for different users?
  • A. cc_hk_Category extension to post-process any cached menu items
  • B. cc_hk_Menu extension to pre-process which menu items are cached
  • C. cc_hk_Menu extension to post-process any cached menu items
  • D. cc_hk_Category extension to pre-process which category items are cached as menu items
The display of CC Menu Items can be customized for different users by using the cc_hk_Menu extension to post-process any cached menu items. This extension allows modifying the menu items based on the user context, such as the user role, account, or cart. For example, the extension can hide or show certain menu items based on the user's permissions or preferences.
NEW QUESTION # 23
Which three decorators can be used in Lightning Web Components?
  • A. @import
  • B. @wire
  • C. @class
  • D. @track
  • E. @api
Answer: B,D,E
In Lightning Web Components, the decorators @api, @track, and @wire play crucial roles. The @api decorator is used to expose public properties and methods, making them accessible to other components. The @track decorator is used to mark private properties as reactive, so the UI updates when their values change. The @wire decorator is used to wire Apex methods or Salesforce data to the component. Salesforce documentation on LWC development extensively covers these decorators, explaining their usage and best practices.
NEW QUESTION # 24
I would like to inform you that you are coming to a professional site engaging in providing valid AP-202 dumps torrent materials. We are working on R & D for IT certification many years, so that most candidates can clear exam certainly with our AP-202 dumps torrent. Some of them can score more than 90%. Some candidates reflect our dumps torrent is even totally same with their real test. If you want to try to know more about our AP-202 Dumps Torrent, our free demo will be the first step for you to download.
AP-202 Valid Dumps Free: https://www.braindumpsvce.com/AP-202_exam-dumps-torrent.html
Salesforce Free AP-202 Practice If you have had the confidence in yourself so that you have won the first step on the road to success, Educationists and experts highly acknowledge this tool created by BraindumpsVCE AP-202 Valid Dumps Free, In a word, you can try our free AP-202 study guide demo before purchasing, Salesforce Free AP-202 Practice There has no delay reaction of our website.
Because of this fact, there are specific elements woven throughout the US cyberspace AP-202 strategy that are critical enablers allowing smaller partners to contribute effectively to evolve, protect, and leverage the cyberspace we have in common.
Hot Free AP-202 Practice Pass Certify | Pass-Sure AP-202 Valid Dumps Free: B2B Commerce for Developers Accredited ProfessionalEach topic is supported with a complete sample app, which demonstrates Free AP-202 Practice real security problems and solutions, If you have had the confidence in yourself so that you have won the first step on the road to success.
Educationists and experts highly acknowledge this tool created by BraindumpsVCE, In a word, you can try our free AP-202 Study Guide demo before purchasing, There has no delay reaction of our website.
We want all of customers to become independent, Free AP-202 Practice talented, confident professionals in their chosen IT field.
Posted at 2/17/2026 16:32:18        Only Author  2#
Your article has left a significant mark on me, thank you for it. Best of luck with your exam preparations! C_P2W62_2023 valid test answers questions available for free!
Posted at 3/8/2026 08:15:16        Only Author  3#
Liking it because this content is awesome. Getting ready for the Intereactive Mule-Dev-202 testing engine exam – wish me luck!
