Salesforce - PDII Authoritative Certification
Posted at 2/4/2026 11:01:40
What's more, part of that BraindumpsPrep PDII dumps now are free: https://drive.google.com/open?id=1oPV65VPyOjC6-6HYFkS8Ua0pMPgE9nmG
All Of Salesforce staff knows it is very difficult to get Salesforce certificate. But taking Salesforce certification exam and getting the certificate are a way to upgrade your ability and prove self-worth, so you have to choose to get the certificate. Isn't there an easy way to help all candidates pass their exam successfully? Of course there is. PDII Exam Dumps are the best way. BraindumpsPrep has everything you need and can absolutely satisfy your demands. You can visit BraindumpsPrep.com to know more details and find the exam materials you want to.
The PDII Exam covers a wide range of topics related to Salesforce development, including Apex programming, Visualforce development, Lightning Components, and integration with external systems. You will also be tested on your knowledge of best practices in designing and implementing complex solutions on the Salesforce platform.
Salesforce PDII Exam Materials & Valid Braindumps PDII EbookThe BraindumpsPrep is one of the leading platforms that has been offering real and valid Platform Developer II (PDII) exam practice test questions. These Platform Developer II (PDII) exam questions are designed and verified by Salesforce PDII subject matter experts. They work closely together and put all their expertise to check the Salesforce PDII exam questions one by one.
The PDII Exam covers a wide range of topics, including Apex, Visualforce, Lightning Components, and integration with other systems. Candidates are expected to have a deep understanding of Salesforce data modeling and security, as well as proficiency in designing and implementing complex business logic and user interfaces. Successful candidates will have demonstrated their ability to build custom applications that meet the unique needs of their organizations and can be easily maintained and scaled over time.
Salesforce Platform Developer II Sample Questions (Q77-Q82):NEW QUESTION # 77
A company has a custom object, Sales Demo Request, that has a lookup to an Opportunity. It is required that a Sales Demo Request record be created when an Opportunity's Probability is greater than 50%. What is the optimal way to automate this?
- A. Create a Workflow on Opportunity.
- B. Use an Apex Trigger on Opportunity.
- C. Build a Flow on Opportunity.
- D. Build a Process on Opportunity
NEW QUESTION # 78
A developer wrote a class named asccuntRisteryManager that relies on field history tracking. The class has a static method called getaccountHistory that Lakes in an Account as a parameter and returns a list of associated accountHistory object records.
The following test fails:
What should be done to make this test pass?
- A. Use @isTest (SeeAllData=true] to see historical data from the org and query for Accountdistory records.
- B. The tact method should he delated since this code cannat be tested
- C. Create Accountdistory records manually in the test setup and write a query to get them.
- D. Use Test. isRunningTest (] in getAccountHistory() to conditionally return fake AccountHistory records.
To make the test pass, @isTest(SeeAllData=true) should be used to allow the test to access historical data from the org. This is required because field history tracking data is not copied to a test context, so you need to allow the test to access live data to assert against it.
References: Apex Developer Guide - IsTest Annotation
NEW QUESTION # 79
Universal Containers wants to be able to bring up an Account detail page and view a table of containers currently being rented. The user wants to be able to dick on a container In the table and quickly edit and save the location of the container.
In addition to this, the page should have a section that shows the location of each container on a map.
Universal Containers wants the map to re-render whenever the location of a container is changed.
What can a developer use to accomplish this task?
- A. A single visualforce Page leveraging Platform Events
- B. Two Lightning Components leveraging Platform Events
- C. Two Visualforce Page Components leveraging Application Events
- D. Two Lightning Components leveraging Application Events
NEW QUESTION # 80
An Apex trigger creates an Order__c record every time an Opportunity is won by a Sales Rep. Recently the trigger is creating two orders. What is the optimal method for a developer to troubleshoot this?
- A. Turn off all Workflow Rules, then turn them on one at at time to see which one causes the error.
- B. Run the Apex Test Classes for the Apex trigger to ensure the code still has sufficient code coverage.
- C. Set up debug logging for every Sales Rep, then monitor the logs for errors and exceptions.
- D. add system.debug() statements to the code and use the Developer Console logs to trace the code.
NEW QUESTION # 81
A developer is writing a complex application involving triggers, workflow rules, Apex classes, and processes.
The developer needs to carefully consider the order of execution when developing the application.
1. Before Triggers
2. After Triggers
3. Post commit logic such as sending email
4. DML committed to the database
5. Workflow rules
6. Roll-up summary calculations
In what order do the following operations execute?
- A. 1, 2, 5, 6, 4, 3
- B. 1, 5, 6, 2, 4, 3
- C. 1, 2, 4, 5, 6, 3
- D. 1, 6, 5, 2, 4, 3
Explanation/Reference:
NEW QUESTION # 82
PDII Exam Materials: https://www.briandumpsprep.com/PDII-prep-exam-braindumps.html
- Certification PDII Exam Infor 🌮 PDII Simulations Pdf 🙂 PDII 100% Correct Answers 🧮 Enter ⮆ [url]www.vceengine.com ⮄ and search for ⇛ PDII ⇚ to download for free 🦹
DII Valid Test Simulator[/url] - Pass Guaranteed 2026 Salesforce PDII: Platform Developer II –High Pass-Rate Certification 🚣 Easily obtain free download of ⮆ PDII ⮄ by searching on ( [url]www.pdfvce.com ) 📂Valid PDII Test Question[/url]
- Quiz Useful PDII - Platform Developer II Certification 🚖 Search for 《 PDII 》 and obtain a free download on { [url]www.practicevce.com } 📷
DII Valid Exam Notes[/url] - Pass Guaranteed Quiz 2026 Salesforce High Pass-Rate PDII: Platform Developer II Certification 🐜 Search for ⮆ PDII ⮄ and download it for free on ➤ [url]www.pdfvce.com ⮘ website ⏪Valid PDII Test Question[/url]
- Pass Guaranteed 2026 Salesforce PDII: Platform Developer II –High Pass-Rate Certification 🔵 Go to website ➡ [url]www.prepawaypdf.com ️⬅️ open and search for ➥ PDII 🡄 to download for free 🏙Valid PDII Test Question[/url]
- Guaranteed PDII Questions Answers 🚡 Valid PDII Test Question 🐎 PDII Valid Test Simulator 📌 Search for ➡ PDII ️⬅️ and download it for free on ⮆ [url]www.pdfvce.com ⮄ website 🥬Valid PDII Test Duration[/url]
- Quiz Useful PDII - Platform Developer II Certification 💭 Search for [ PDII ] and download exam materials for free through ➤ [url]www.testkingpass.com ⮘ 😎
DII Valid Test Bootcamp[/url] - PDII Valid Exam Forum 🥓 PDII Latest Dump 📂 Latest PDII Test Fee 💸 Easily obtain free download of { PDII } by searching on ⏩ [url]www.pdfvce.com ⏪ 🗣
DII Valid Test Bootcamp[/url] - Pass Guaranteed 2026 Salesforce PDII: Platform Developer II –High Pass-Rate Certification 🧏 Enter ➥ [url]www.testkingpass.com 🡄 and search for ➤ PDII ⮘ to download for free ❎
DII Simulations Pdf[/url] - Quiz Salesforce - Useful PDII Certification 🦨 Enter ⮆ [url]www.pdfvce.com ⮄ and search for ▛ PDII ▟ to download for free 🌎Valid PDII Test Duration[/url]
- Pass Guaranteed Quiz 2026 Salesforce High Pass-Rate PDII: Platform Developer II Certification 🐀 Search for ▶ PDII ◀ and download it for free immediately on 「 [url]www.exam4labs.com 」 ⬇Reliable Test PDII Test[/url]
- faithlife.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest BraindumpsPrep PDII PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1oPV65VPyOjC6-6HYFkS8Ua0pMPgE9nmG
