[General] Sharing-and-Visibility-Architect試題,Sharing-and-Visibility-Architect考題免費下載
【General】 Sharing-and-Visibility-Architect試題,Sharing-and-Visibility-Architect考題免費下載
Posted at 1/9/2026 02:36:11      View:206 | Replies:6        Print      Only Author   [Copy Link] 1#
P.S. NewDumps在Google Drive上分享了免費的、最新的Sharing-and-Visibility-Architect考試題庫:https://drive.google.com/open?id=1UFUidD9OfwE_NgGlf9unTeqzOE-t79Ez
Salesforce的Sharing-and-Visibility-Architect考試認證肯定會導致你有更好的職業前景,通過Salesforce的Sharing-and-Visibility-Architect考試認證不僅驗證你的技能,也證明你的證書和專業知識,NewDumps Salesforce的Sharing-and-Visibility-Architect考試培訓資料是實踐檢驗的軟體,有了它你會得到的理解理論比以前任何時候都要好,將是和你最配備知識。在你決定購買之前,你可以嘗試一個免費的使用版本,這樣一來你就知道NewDumps Salesforce的Sharing-and-Visibility-Architect考試培訓資料的品質,也是你最佳的選擇。
Salesforce Sharing-and-Visibility-Architect是一個認證考試,驗證專業人士在Salesforce共享和可見性架構領域的技能和知識。該認證是為那些在Salesforce中設計和實施複雜的共享和可見性解決方案的個人而設計的。
Sharing-and-Visibility-Architect試題將是您最好的助力Salesforce Certified Sharing and Visibility Architect我們NewDumps的Salesforce的Sharing-and-Visibility-Architect考試培訓資料是以PDF和軟體格式提供,它包含NewDumps的Salesforce的Sharing-and-Visibility-Architect考試的試題及答案,你可能會遇到真實的Sharing-and-Visibility-Architect考試,這些問題堪稱完美,和可行之的有效的方法,在任何Salesforce的Sharing-and-Visibility-Architect考試中獲得成功,NewDumps Salesforce的Sharing-and-Visibility-Architect 全面涵蓋所有教學大綱及複雜問題,NewDumps的Salesforce的Sharing-and-Visibility-Architect 考試的問題及答案是真正的考試挑戰,你必須要擦亮你的技能和思維定勢。
Salesforce Sharing-and-Visibility-Architect Certification Exam是Salesforce生態系統中最負盛名的認證之一。其旨在測試Salesforce專業人員在共享和可見性領域的技能和知識。該認證非常適合與Salesforce數據合作並需要確保適當人員在適當時間獲得適當信息的專業人士。
最新的 Salesforce Architect Sharing-and-Visibility-Architect 免費考試真題 (Q41-Q46):問題 #41
A sales coach at Universal Containers wants to create and share a report folder with other sales coaches.
Which two permissions are required to accomplish this?
  • A. Create Report Folders and manage Reports in Public Folders
  • B. Manage Reports in Public Folders and edit My Reports
  • C. Create and customize Reports and Report Folders
答案:C
解題說明:
To create and share a report folder, users need specific permissions. The "Create and Customize Reports" permission allows creating reports and folders, while folder management permissions are required to share the folder with others.
* Option A: "Manage Reports in Public Folders" is for administering public folders, not creating or sharing a personal folder.
* Option B (Correct): "Create and Customize Reports and Report Folders" ensures that users can create and share folders effectively.
* Option C: "Edit My Reports" is only for editing personal reports, not for creating or sharing report folders.
* Report Folder Permissions
* Salesforce Report and Dashboard Permissions
問題 #42
Universal Containers (UC) uses a custom lightning component with an Apex class to display shipment information (custom object, private OWD). UC sales managers are complaining about two important points:
Shipment records that belong to their teams can be seen by other users.
Shipment amount should be visible only by managers, but sales reps are able to view it. Which two features did the development team miss that is causing the problems?
Choose 2 answers.
  • A. Use run as in test class to enforce user permissions and field-level permissions.
  • B. Use is Sharable keyword in Apex classes to assure record visibility.
  • C. Use with Sharing keyword in Apex classes to enforce sharing rules evaluation.
  • D. Use isAccessible() method in Apex classes to check field accessibility
答案:C,D
解題說明:
The development team missed using the with Sharing keyword in Apex classes to enforce sharing rules evaluation, and the isAccessible() method in Apex classes to check field accessibility. The with Sharing keyword ensures that the Apex code respects the sharing rules defined for the current user, while the isAccessible() method checks if the user has read access to a specific field1. The run as method in test class is used to test whether a user can perform certain actions, not to enforce permissions2. The isSharable keyword in Apex classes does not exist.
問題 #43
Which two options are available to share a Report or Dashboard folder with other users in the Organization?
Choose 2 answers
  • A. Public Groups
  • B. Profiles
  • C. Roles
  • D. Teams
答案:A,C
解題說明:
To share a report or dashboard folder with other users in the organization, you can use Public Groups or Roles4. Profiles and Teams are not available options for sharing folders.
問題 #44
Which users have access to Opportunity records owned by an external user, assuming no other changes to the sharing model have been implemented?
  • A. The record owner and any user below the external user in the role hierarchy.
  • B. The record owner only.
  • C. The record owner and any user above the external user in the role hierarchy.
  • D. The record owner and all internal users.
答案:C
解題說明:
The record owner and any user above the external user in the role hierarchy have access to opportunity records owned by an external user. This is because external users are always at the bottom of the role hierarchy and do not grant access to users below them. The record owner and all internal users do not have access to opportunity records owned by an external user unless they have other sharing mechanisms such as sharing rules or manual sharing
問題 #45
Sales Reps at Universal Containers sometimes create large files as a part of the Sales process that are too large to share over email. They would like users to be able to share files with customers, but the CISO has requested that any file links shared must be protected by a password.
How can this be accomplished?
  • A. Utilize an AppExchange product for delivering password-protected files to their customers,
  • B. Set up an experience cloud site for customers to access files. Share the file with customers via chatter.
    Customers can then log into the site to access the content.
  • C. Sales reps can create a content delivery. During creation, the user should select the option to require a password to access content.
答案:C
解題說明:
Content delivery is a feature that allows users to share files with customers and protect them with a password.
Setting up an experience cloud site would require additional configuration and licensing. Utilizing an AppExchange product would introduce a dependency on a third-party solution.
問題 #46
Sharing-and-Visibility-Architect考題免費下載: https://www.newdumpspdf.com/Sharing-and-Visibility-Architect-exam-new-dumps.html
BONUS!!! 免費下載NewDumps Sharing-and-Visibility-Architect考試題庫的完整版:https://drive.google.com/open?id=1UFUidD9OfwE_NgGlf9unTeqzOE-t79Ez
Posted at 1/14/2026 02:30:06        Only Author  2#
This article is phenomenal, I’m grateful for your sharing. Free Reliable test L5M8 dumps free to help you enhance your IT skills. Wishing you good luck!
Posted at 1/24/2026 17:25:56        Only Author  3#
I am genuinely inspired by this article, thank you for sharing! You can freely access C-THR89-2505 test voucher, which is full of valuable content, hoping it proves useful.
Posted at 1/26/2026 17:29:24        Only Author  4#
I’m simply in awe of your article, thank you for sharing such brilliance! Free New PR2F test sample online resources for exam success. Wishing you the best!
Posted at 2/4/2026 02:02:06        Only Author  5#
So much wisdom in this article, thank you for sharing it! The Test XDR-Analyst passing score content is of high quality and available for free.
Posted at 2/16/2026 13:51:05        Only Author  6#
I’m really thankful for your article, it was truly eye-opening. About to take the New CSPAI test tips exam! Let’s hope everything goes smoothly!
Posted at 2/20/2026 06:06:18        Only Author  7#
このラインで優秀なエリートになりたい場合は、FCSS_SASE_AD-24認定を取得する必要があります。したがって、資格試験の重要性を通してそれを確認できます。資格試験を通じてのみ、対応する資格証明書を取得しているため、関連作業に従事することができます。そのため、FCSS_SASE_AD-24テストの急流は、比較的短期間で人々が資格試験に合格するための非常に重要なツールです。 FCSS_SASE_AD-24学習ツールを選択すると、ユーザーが困難な点をすばやく分析し、FCSS_SASE_AD-24試験に合格するのに役立ちます。
