[General] Test C_TS422_2023 Question & New C_TS422_2023 Exam Sample
90
General Test C_TS422_2023 Question & New C_TS422_2023 Exam Sample
Posted at 1/13/2026 19:20:54      View185 | Replies3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Exam4Tests C_TS422_2023 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1clZMDDM6p60l9W3DF5c_oEcL0iYATIlF
As the most famous and popular C_TS422_2023 exam questions on the market, we have built a strict quality control system. The whole compilation process of the C_TS422_2023 study materials is normative. We have proof-readers to check all the contents. Usually, the C_TS422_2023 Actual Exam will go through many times careful proofreading. Please trust us. We always attach great importance to quality of the C_TS422_2023practice braindumps.
SAP C_TS422_2023 Exam Syllabus Topics:
  • Process Orders in SAP S
  • 4HANA: This section covers an introduction to process order components, processing, and relevant master data objects. Overview of Good Manufacturing Practices (GMP) features.
  • Lean Manufacturing in SAP S
  • 4HANA: This section covers repetitive manufacturing master data, line load planning, and Kanban systems.
  • Master Data in SAP S
  • 4HANA: This section covers the exploration of crucial production-related master data elements, with emphasis on bill of material, routing, and production version.
  • Capacity Planning in SAP S
  • 4HANA: This section covers a discussion of SAP S
  • 4HANA best practices, SAP HANA database concept, SAP Fiori user experience, and embedded analytics capabilities.
Topic 5
  • Introduction to SAP S
  • 4HANA Supply Chain Planning: This part covers the background and motivation for SAP S
  • 4HANA, its main components, business applications, and user experience strategy.
Topic 6
  • 4HANA Production Planning: This section covers an overview of production planning components, functions, and planning approaches. Exploration of emerging trends.
Topic 7
  • Material Requirements Planning in SAP S
  • 4HANA: This part of the exam covers an examination of planning strategies, tools, and long-term planning concepts. Overview of MRP fundamentals and lot size procedures.
Topic 8
  • Production Orders in SAP S
  • 4HANA: This section covers BOM item categorization, order status management, availability checks, routing selection, order type setup, and material handling processes.
C_TS422_2023 exams questions and answers & dumps PDF for SAP S/4HANA Cloud Private Edition - Production Planning and ManufacturingAfter you purchase C_TS422_2023 exam questions, you should always pay attention to your email address. Once there is a new version, we will send updated information to your email address. As we all know, the authority of a product matches its hit rate. How high the authority of C_TS422_2023 Real Exam is, I don't need to say any more. You just know what you will know. You can't really find a product that has a higher hit rate than our C_TS422_2023 study materials!
SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing Sample Questions (Q56-Q61):NEW QUESTION # 56
You want to use capacity availability checks for production orders.
Which settings have to be made for this?
  • A. A checking rule must be assigned to the work centers.
  • B. An overall profile must be assigned in the checking control.
  • C. The Relevant for Finite Scheduling indicator must be set.
  • D. The scope of check must be defined in Customizing.
NEW QUESTION # 57
What data can you maintain in the subitems of a bill of material (BOM)?
  • A. Installation point
  • B. Quantity
  • C. Status
  • D. Scrap percentage
NEW QUESTION # 58
Where do you maintain the work center that represents the production line for repetitive manufacturing?
  • A. Production cost collector
  • B. Production version
  • C. Repetitive manufacturing profile
  • D. Routing
The work center that represents the production line for repetitive manufacturing is maintained in two places: the repetitive manufacturing profile and the production version. The repetitive manufacturing profile is a control parameter that defines the basic settings for repetitive manufacturing, such as the planning type, the backflushing method, the confirmation type, and the production line determination. The production version is a combination of a bill of material (BOM) and a routing or a rate routing that specifies how a material is produced. The production version also contains the work center that represents the production line for the material. The production version is assigned to the material master and is used in the planning and execution of repetitive manufacturing. Reference: Repetitive Manufacturing Profile | SAP Help Portal, Production Version | SAP Help Portal, Make-to-Stock Repetitive Manufacturing | SAP Help Portal.
NEW QUESTION # 59
  • A. Quantity
  • B. Installation point
  • C. Scrap percentage
  • D. Item type
The subitems of a bill of material (BOM) are the components that make up the product or assembly. You can maintain the following data for each subitem:
Quantity: This is the number of units of the component that are required for one unit of the product or assembly. You can specify the quantity in different units of measure, such as base unit, order unit, or alternative unit. You can also use variable quantities, such as percentages or formulas, to calculate the quantity dynamically based on the product or assembly characteristics.
Scrap percentage: This is the percentage of the component that is expected to be wasted or lost during the production or assembly process. You can specify the scrap percentage for each component to adjust the quantity accordingly. For example, if the quantity of a component is 10 and the scrap percentage is 5%, the system will increase the quantity by 0.5 to account for the scrap.
The installation point (A) and the item type (B) are not data that you can maintain in the subitems of a BOM. The installation point is a field in the equipment master record that indicates where the equipment is installed. The item type is a field in the sales document item that determines the processing and pricing of the item. These fields are not relevant for the BOM subitems. Reference:
https://sapstack.com/pp/bom-in-sap-bill-of-material/
https://skillstek.com/bill-of-material-in-sap/
NEW QUESTION # 60
In your plant MRP is activated. Which options do you have to exclude a material from the MRP run? Note:
  • A. Use a specific material status.
  • B. Use a specific material group.
  • C. Use a specific MRP list.
  • D. Use a specific MRP type.
Answer: A,D
In SAP S/4HANA, MRP can be configured to exclude certain materials from planning runs to optimize processing or reflect specific business needs. One method is to use aspecific material status(B), maintained in the material master (e.g., under the MRP view). A status such as "Blockedfor Procurement/Production" (configured in Customizing under Logistics - General > Material Master > Settings for Key Fields > Define Material Statuses) prevents the material from being planned in MRP, effectively excluding it from the run.
Another method is to assign aspecific MRP type(D), such as "ND" (No Planning), in the material master (MRP 1 view). This MRP type instructs the system not to generate requirements or planned orders for the material, excluding it from MRP processing.Using a specific MRP list(A) is not a valid exclusion method, as the MRP list is an output of the MRP run, not a control mechanism. Similarly,using a specific material group (C) does not inherently exclude materials from MRP, as material groups are for classification and reporting, not MRP control. These options align with SAP's standard MRP configuration settings.
NEW QUESTION # 61
SAP provides the most reliable and authentic SAP C_TS422_2023 Exam prep material there is. The 3 kinds of SAP C_TS422_2023 Preparation formats ensure that there are no lacking points in a student when he attempts the actual C_TS422_2023 exam.
New C_TS422_2023 Exam Sample: https://www.exam4tests.com/C_TS422_2023-valid-braindumps.html
BTW, DOWNLOAD part of Exam4Tests C_TS422_2023 dumps from Cloud Storage: https://drive.google.com/open?id=1clZMDDM6p60l9W3DF5c_oEcL0iYATIlF
Posted at 1/16/2026 14:24:30        Only Author  2#
Without thinking, Im liking this amazing content. Free Interactive Generative-AI-Leader eBook questions are shared. Good luck with your exam preparation!
Posted at 1/25/2026 15:11:08        Only Author  3#
ҡṩJuniperJN0-460ԇYYϤΤɤΥЩ`ǤԤΥåȤ֤äƤޤPDFϥѥǤ⥹ޥۤǤäǤɤǤiޤͥåȤС饤ϤɤƷǤʹäǤޤեȰgJuniperJN0-460ԇYέhģơʤJuniperJN0-460ԇYαθҙФ뤳ȤǤĤΥѥǤäǤޤ
Posted at 2/21/2026 09:27:03        Only Author  4#
The article is full of motivational insights, thank you for sharing! Free access to H19-427_V1.0-ENU exam fee materialsgood luck!
