[General] 100% Pass NetSec-Pro - Palo Alto Networks Network Security Professional Updated
102
【General】 100% Pass NetSec-Pro - Palo Alto Networks Network Security Professional Updated
Posted at 2/21/2026 14:56:33      View:115 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ActualVCE NetSec-Pro dumps for free: https://drive.google.com/open?id=1H3oG862F8O6CGbF8PCU0tsmgW9bDMqse
Generally speaking, reviewing what you have learned is important, since it will help you have a good command of the knowledge points. NetSec-Pro Online test engine has testing history and performance review, so that you can have a general review of what you have learned before next learning. In addition, NetSec-Pro exam dumps is convenient and easy to study, it supports all web browsers and Android and iOS etc. You can also practice offline if you like. We provide you with free update for 365 days for NetSec-Pro Exam Materials, so that you can get the latest information for the exam timely. And the latest information for NetSec-Pro exam dumps will be auto sent to you.
Palo Alto Networks NetSec-Pro Exam Syllabus Topics:
  • NGFW and SASE Solution Functionality: This part assesses the knowledge of firewall administrators and network architects on the functions of various Palo Alto Networks firewalls including Cloud NGFWs, PA-Series, CN-Series, and VM-Series. It covers perimeter and core security, zone security and segmentation, high availability, security and NAT policy implementation, as well as monitoring and logging. Additionally, it includes the functionality of Prisma SD-WAN with WAN optimization, path and NAT policies, zone-based firewall, and monitoring, plus Prisma Access features such as remote user and network configuration, application access, policy enforcement, and logging. It also evaluates options for managing Strata and SASE solutions through Panorama and Strata Cloud Manager.
  • GFW and SASE Solution Maintenance and Configuration: This domain evaluates the skills of network security administrators in maintaining and configuring Palo Alto Networks hardware firewalls, VM-Series, CN-Series, and Cloud NGFWs. It includes managing security policies, profiles, updates, and upgrades. It also covers adding, configuring, and maintaining Prisma SD-WAN including initial setup, pathing, monitoring, and logging. Maintaining and configuring Prisma Access with security policies, profiles, updates, upgrades, and monitoring is also assessed.
  • Network Security Fundamentals: This section of the exam measures skills of network security engineers and covers key concepts such as application layer inspection for Strata and SASE products, differentiating between slow and fast path packet inspection, and the use of decryption methods including SSL Forward Proxy, SSL Inbound Inspection, SSH Proxy, and scenarios where no decryption is applied. It also includes applying network hardening techniques like Content-ID, Zero Trust principles, User-ID (including Cloud Identity Engine), Device-ID, and network zoning to enhance security on Strata and SASE platforms.
Quiz NetSec-Pro - Newest Exam Palo Alto Networks Network Security Professional Passing ScoreActualVCE wants to win the trust of Palo Alto Networks NetSec-Pro exam candidates at any cost. To achieve this objective ActualVCE is offering some top features with NetSec-Pro exam practice questions. These prominent features hold high demand and are specifically designed for quick and complete Palo Alto Networks Network Security Professional (NetSec-Pro) exam questions preparation.
Palo Alto Networks Network Security Professional Sample Questions (Q31-Q36):NEW QUESTION # 31
Which two SSH Proxy decryption profile settings should be configured to enhance the company's security posture? (Choose two.)
  • A. Allow sessions when decryption resources are unavailable.
  • B. Allow sessions with legacy SSH protocol versions.
  • C. Block sessions when certificate validation fails.
  • D. Block connections that use non-compliant SSH versions.
Blocking non-compliant SSH versionsandfailing certificate validationsare fundamental security measures:
"The SSH Proxy profile should block sessions that fail certificate validation to ensure that only trusted hosts are allowed." (Source: SSH Proxy Decryption Best Practices) Block connections using non-compliant SSH versions Older SSH versions may have vulnerabilities or lack modern encryption algorithms.
"To enforce stronger security, block SSH sessions that use older or deprecated versions of the SSH protocol that do not comply with your security posture." (Source: SSH Decryption and Best Practices) Together, these measuresminimize the risk of MITM attacksand secure SSH traffic.
NEW QUESTION # 32
Which GlobalProtect configuration is recommended for granular security enforcement of remote user device posture?
  • A. Applying log at session end to all GlobalProtect Security policies
  • B. Implementing multi-factor authentication (MFA) for all users attempting to access internal applications
  • C. Configuring a rule that blocks the ability of users to disable GlobalProtect while accessing internal applications
  • D. Configuring host information profile (HIP) checks for all mobile users
Host Information Profile (HIP) checksare used in GlobalProtect to collect and evaluate endpoint posture (OS, patch level, AV status) to enforce granular security policies for remote users.
"The HIP feature collects information about the host and can be used in security policies to enforce posture- based access control. This ensures only compliant endpoints can access sensitive resources." (Source: GlobalProtect HIP Checks) This enables fine-grained, context-aware access decisions beyond user identity alone.
NEW QUESTION # 33
When a firewall acts as an application-level gateway (ALG), what does it require in order to establish a connection?
  • A. Payload
  • B. Pinholes
  • C. Dynamic IP and Port (DIPP)
  • D. Session Initiation Protocol (SIP)
An ALG is designed toinspect and modify the payloadof application-layer protocols (like SIP, FTP, etc.) to manage dynamic port allocations and session information.
"Application Layer Gateways (ALGs) inspect the payload of certain protocols to dynamically manage sessions that use dynamic port assignments. By modifying payloads, the ALG ensures that NAT and security policies are correctly applied." (Source: ALG Support)
NEW QUESTION # 34
Which set of attributes is used by IoT Security to identify and classify appliances on a network when determining Device-ID?
  • A. MAC address, device manufacturer, and operating system
  • B. Hostname, application usage, and encryption method
  • C. IP address, network traffic patterns, and device type
  • D. Device model, firmware version, and user credential
IoT SecurityusesMAC address,device manufacturer, andOS informationtoidentify and classify devices via Device-ID.
"IoT Security uses passive network traffic analysis to fingerprint devices based on the MAC address, manufacturer, and operating system to ensure accurate classification." (Source: IoT Security Device-ID and Classification) These attributes provide a robust, manufacturer-agnostic method to fingerprint IoT devices.
NEW QUESTION # 35
Which functionality does an NGFW use to determine whether new session setups are legitimate or illegitimate?
  • A. SYN bit
  • B. SYN flood protection
  • C. Random Early Detection (RED)
  • D. SYN cookies
To preventSYN flood attacks, the NGFW usesSYN cookiesto validate legitimate session establishment.
"SYN cookies allow the firewall to verify the legitimacy of new session requests without allocating resources until the handshake is completed. This prevents SYN flood attacks from exhausting system resources." (Source: Flood Protection Best Practices) SYN cookies mitigate resource exhaustion by ensuring only legitimate connections are established.
NEW QUESTION # 36
For years our team has built a top-ranking brand with mighty and main which bears a high reputation both at home and abroad. The sales volume of the NetSec-Pro Study Materials we sell has far exceeded the same industry and favorable rate about our products is approximate to 100%. Why the clients speak highly of our NetSec-Pro study materials? Our dedicated service, high quality and passing rate and diversified functions contribute greatly to the high prestige of our products. We provide free trial service before the purchase, the consultation service online after the sale, free update service and the refund service in case the clients fail in the test.
New NetSec-Pro Real Exam: https://www.actualvce.com/Palo-Alto-Networks/NetSec-Pro-valid-vce-dumps.html
2026 Latest ActualVCE NetSec-Pro PDF Dumps and NetSec-Pro Exam Engine Free Share: https://drive.google.com/open?id=1H3oG862F8O6CGbF8PCU0tsmgW9bDMqse
