[Hardware] Free PDF 350-801 - Updated Implementing and Operating Cisco Collaboration Core T
117
Hardware Free PDF 350-801 - Updated Implementing and Operating Cisco Collaboration Core T
Posted at 2/22/2026 14:11:37      View130 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4Leader 350-801 dumps from Cloud Storage: https://drive.google.com/open?id=1PfWrPZ5JQ5gS_nRPe2F8CJvHduz90ykv
Free demo is available for Cisco 350-801 training materials, so that you can have a better understanding of what you are going to buy. Free demo will represent you what the complete version is like. We suggest you try free domo before buying. In addition, Implementing and Operating Cisco Collaboration Core Technologies 350-801 Training Materials are high quality and accuracy, since we have a professional team to collect the latest information of the exam.
Cisco 350-801 Certification Exam is an essential credential for professionals seeking to advance their careers in the collaboration technology field. Implementing and Operating Cisco Collaboration Core Technologies certification validates the candidates expertise in implementing and operating Cisco collaboration core technologies and is a valuable asset for individuals seeking to stand out in the job market. With the right preparation and hard work, candidates can achieve this certification and unlock new opportunities for career growth and success.
Use the Latest Cisco 350-801 Questions to pass your Certification ExamDo you want to pass the Cisco 350-801 exam on the first attempt but do not know where to start the preparation? Then Pass4Leader has a solution to all your problems. Pass4Leader is among the greatest resources for preparing for Cisco 350-801 Certification test. With real 350-801 PDF Questions of Pass4Leader you can simply prepare for your 350-801 exam from home, the office, or your place of work.
Cisco Implementing and Operating Cisco Collaboration Core Technologies Sample Questions (Q345-Q350):NEW QUESTION # 345
In Cisco UCM, an engineer must create a new SIP route pattern to allow ccnp.cisco com for all internal callers The internal callers have a calling search space named CSSJNTERNAL that includes the partition named PTJNTERNAL If allowed, the calls must be routed to a SIP trunk named SIP_CISCO_TRK. Drag and drop the values from the left onto the corresponding fields on the right.
NEW QUESTION # 346
User A Calls user. The call gets connected, but the quality is bed. What are two reasons for this issue? (Choose two)
CD
NEW QUESTION # 347
Refer to the exhibit A user takes a phone from San Francisco to New York for a short reassignment. The phone was set up to use the San Francisco device pool, and device mobility is enabled on the Cisco UCM. The user makes a call that matches a route pattern in a route list that contains the Standard Local Route Group. To where does the call retreat?
  • A. The call egresses in San Francisco because the user uses device mobility and is allowed to roam while still keeping the number and resources assigned in San Francisco
  • B. The call fails because device mobility is turned on. and the phone is not configured in New York The engineer must configure which sites the device should be roaming to
  • C. The call egresses in New York because the device automatically is assigned a New York device pool and uses the local gateway
  • D. The call fails because the Standard Local Route Group is being used only if no configuration is set for the device pools
NEW QUESTION # 348
An engineer verifies the configured of an MGCP gateway. The commands are already configured. Which command is necessary to enable MGCP?
  • A. Device(config)# mgcp enable
  • B. Device (config)# mgcp
  • C. Device(config)# ccm-manager enable
  • D. Device (config) # com-manager active
NEW QUESTION # 349
An engineer is setting up a system with voice and video endpoints using auto-QoS policy on the switches.
Which DSCP values are expected for interactive voice and video?
  • A. EF AND CS3
  • B. EF AND AF21
  • C. EF AND AF41
  • D. EF AND CS6
NEW QUESTION # 350
By using the 350-801 desktop practice exam software, you can sit in real exam like scenario. This 350-801 practice exam simulates the complete environment of the actual test so you can overcome your fear about appearing in the Cisco 350-801 Exam. Pass4Leader has designed this software for your Windows laptops and computers.
Free 350-801 Practice Exams: https://www.pass4leader.com/Cisco/350-801-exam.html
What's more, part of that Pass4Leader 350-801 dumps now are free: https://drive.google.com/open?id=1PfWrPZ5JQ5gS_nRPe2F8CJvHduz90ykv
