[General] WGU Cloud-Deployment-and-Operations Pdf Questions - Exceptional Practice To WGU
96
General WGU Cloud-Deployment-and-Operations Pdf Questions - Exceptional Practice To WGU
Posted at 1/11/2026 01:08:24      View230 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest Itcertmaster Cloud-Deployment-and-Operations PDF Dumps and Cloud-Deployment-and-Operations Exam Engine Free Share: https://drive.google.com/open?id=1LM8SEtwD-K7TvsBwdaeS5gMT9J1vGfsh
The page of our Cloud-Deployment-and-Operations simulating materials provides demo which are sample questions. The purpose of providing demo is to let customers understand our part of the topic and what is the form of our Cloud-Deployment-and-Operations study materials when it is opened. In our minds, these two things are that customers who care about the Cloud-Deployment-and-Operations Exam may be concerned about most. And you can click all three formats of our Cloud-Deployment-and-Operations exam dumps to see.
WGU Cloud-Deployment-and-Operations Exam Syllabus Topics:
  • Ensuring Scalability, Elasticity, and Backup Readiness: This section of the exam measures skills of Cloud Operations Specialists and covers implementing AWS features that support scalability, elasticity, and backup readiness. It focuses on enabling cloud systems to handle fluctuating workloads while maintaining continuity and ensuring critical data remains recoverable.
  • Optimizing Cost and Performance Baselines: This section of the exam measures skills of Cloud Operations engineers and covers determining the best balance between cost and performance using AWS services. It involves selecting suitable configurations and resource types to maintain efficient operations while avoiding unnecessary spending.
  • Cloud Service Deployment and Management: This section of the exam measures skills of Cloud Engineers and covers the technical knowledge required to deploy, manage, and operate cloud services. It focuses on understanding stability, scalability, backup processes, recovery methods, and general deployment practices. Candidates are expected to show they can handle provisioning, monitoring, and connectivity tasks needed to support cloud environments.
  • Automating Cloud Provisioning and Maintenance: This section of the exam measures skills of Cloud Operations engineers and covers the ability to automate provisioning tasks and ongoing maintenance activities. It emphasizes using automation tools to streamline cloud resource creation and lifecycle management. Students must demonstrate they can apply automation to maintain efficient cloud operations.
100% Pass WGU Cloud-Deployment-and-Operations - First-grade Reliable WGU Cloud Deployment and Operations Test CramGod always helps those who help themselves. It is impossible to make great fortune overnight. Enough preparation and efforts are needed when you come across an opportunity. So we suggest that you learn our Cloud-Deployment-and-Operations latest training material, which can help broaden your knowledge. Nowadays, lifelong learning has got wide attention. The much knowledge you learn, the better chance you will have. Our Cloud-Deployment-and-Operations practice material suits you best. You can elevate your ability in a short time. Then you can apply what you have learned on our Cloud-Deployment-and-Operations test engine into practice. We warmly welcome you to purchase our study guide.
WGU Cloud Deployment and Operations Sample Questions (Q32-Q37):NEW QUESTION # 32
(An administrator successfully accesses an EC2 instance via SSH from a local computer then stops it and starts it. Following the restart, the EC2 instance is no longer accessible. Which solution should be used to resolve the issue?)
  • A. Change the port used to connect to EC2 instance
  • B. Add a route to the route table associated with the EC2 instance subnet
  • C. Change the IP address used to connect to the EC2 instance
  • D. Add a rule to the security group associated with the NIC of the EC2 instance
After stopping and starting an EC2 instance, the public IP address may change (unless an Elastic IP is attached), but the security group rules remain intact. If the instance is no longer accessible via SSH, it's likely due to an inbound rule (e.g., for port 22) not being correctly configured or applied. Adding or verifying a rule in the security group associated with the network interface (NIC) to allow SSH (port 22) from the administrator's IP resolves this. The WGU Cloud Deployment and Operations Study Guide (Section 3.2, Security Groups) states, "Stopping and starting an EC2 instance may require verifying or adding an inbound SSH rule (port 22) in the security group if connectivity is lost due to IP or rule misconfiguration." Route table or IP changes are not the primary issue here.
NEW QUESTION # 33
(Which type of support plan provides a technical account manager and full use of Trusted Advisor?)
  • A. Standard
  • B. Enterprise
  • C. Developer
  • D. Business
The Enterprise support plan provides a technical account manager (TAM) and full use of Trusted Advisor, offering proactive guidance and comprehensive access to all checks. This plan is designed for large-scale, mission-critical workloads. The WGU Cloud Deployment and Operations Study Guide (Section 6.4, AWS Support Plans) states, "The Enterprise support plan includes a dedicated Technical Account Manager and full Trusted Advisor access, providing 24/7 support and proactive optimization recommendations." Developer, Standard, and Business plans offer limited or no TAM support and partial Trusted Advisor access.
NEW QUESTION # 34
(Which AWS service is used to provide remote workers with secure access to AWS resources?)
  • A. Client VPN
  • B. NAT instance
  • C. Network Firewall
  • D. Transit Gateway
AWS Client VPN is used to provide remote workers with secure access to AWS resources by establishing a VPN connection to the VPC, ensuring encrypted access to private networks. The WGU Cloud Deployment and Operations Study Guide (Section 3.2, Client VPN) states, "Client VPN enables secure remote access to AWS resources within a VPC, using mutual authentication and encryption to protect data for remote workers." Transit Gateway manages inter-VPC routing, Network Firewall filters traffic, and NAT instances handle outbound internet access, none of which are designed for remote worker access.
NEW QUESTION # 35
(An administrator needs to deploy a NAT gateway in an existing VPC subnet. Which two tasks should this administrator perform during deployment? Choose 2 answers.)
  • A. Configure the route table associated with the subnet
  • B. Configure the access control list associated with the subnet
  • C. Assign an elastic IP address to the NAT gateway
  • D. Assign a private IP address to the NAT gateway
To deploy a NAT gateway in an existing VPC subnet, the administrator must assign an elastic IP address to the NAT gateway for public internet access and configure the route table associated with the subnet to route traffic through the NAT gateway. The WGU Cloud Deployment and Operations Study Guide (Section 3.2, NAT Gateway) states, "Deployment of a NAT gateway requires an elastic IP address for outbound internet connectivity and a route table update to direct private subnet traffic to the NAT gateway (e.g., 0.0.0.0/0 via NAT)." Private IP assignment and ACL configuration are not required steps.
NEW QUESTION # 36
(A company has the following disaster recovery requirements: The loss of up to three hours of data is acceptable. Services must be restored within one hour of failure. Which recovery characteristics will allow the company to meet the requirements?)
  • A. RPO 1 hour, RTO 2 hours
  • B. RPO 4 hours, RTO 1 hour
  • C. RPO 2 hours, RTO 1 hour
  • D. RPO 1 hour, RTO 4 hours
Recovery Point Objective (RPO) measures the maximum acceptable data loss, while Recovery Time Objective (RTO) measures the maximum acceptable downtime. The company requires an RPO of up to 3 hours (acceptable data loss) and an RTO of 1 hour (service restoration time). The correct option is RPO 4 hours, RTO 1 hour, as it meets the RPO requirement (allowing up to 3 hours of data loss is within 4 hours) and satisfies the RTO of 1 hour. The WGU Cloud Deployment and Operations Study Guide (Section 8.1, Disaster Recovery) states, "RPO defines the maximum data loss tolerance (e.g., 3 hours), and RTO defines the maximum downtime (e.g., 1 hour); a configuration of RPO 4 hours and RTO 1 hour aligns with these thresholds." Other options fail to meet both criteria simultaneously.
NEW QUESTION # 37
Wrong topic tend to be complex and no regularity, and the Cloud-Deployment-and-Operations torrent prep can help the users to form a good logical structure of the wrong question, this database to each user in the simulation in the practice of all kinds of wrong topic all induction and collation, and the Cloud-Deployment-and-Operations study question then to the next step in-depth analysis of the wrong topic, allowing users in which exist in the knowledge module, tell users of our Cloud-Deployment-and-Operations Exam Question how to make up for their own knowledge loophole, summarizes the method to deal with such questions for, to prevent such mistakes from happening again.
Cloud-Deployment-and-Operations Reliable Practice Questions: https://www.itcertmaster.com/Cloud-Deployment-and-Operations.html
What's more, part of that Itcertmaster Cloud-Deployment-and-Operations dumps now are free: https://drive.google.com/open?id=1LM8SEtwD-K7TvsBwdaeS5gMT9J1vGfsh
Posted at 2/20/2026 22:29:04        Only Author  2#
Your article was truly remarkable, Im so grateful for it. Free Workday-Pro-HCM-Core valid study plan exam materials available for all. Good luck on your test!
Posted at 2/22/2026 15:35:36        Only Author  3#
I found the article to be incredibly enlightening. Free access to Valid exam C-S4CPR-2508 simulator fees extensive content is offered, with the aim of supporting you.
