Hardware
Mule-Arch-201rgMule-Arch-201ƥȥץ놖}
Posted at 1/17/2026 03:40:32
View227
Replies3
Mule-Arch-201Jȡä뤳Ȥ϶यˤˤȤäƺgǤϤʤȤ狼äƤޤ˥`Ǥ뤳ȤҤ˼ޤν̲Ĥϡ̕rgMule-Arch-201JȡäΤޤ Mule-Arch-201}ԔˤB餷ޤFؤʕrgMule-Arch-201ԇY|E˽ϤʤʧʤŤƤϤMule-Arch-201ȥ`˥ɤΥǥoϤǥ`ɤơ줿Ʒ|֪뤳ȤǤޤ
GoShikenO˽Mule-Arch-201ԇYYϤ˴Ҏģ˲ġYϡؔԴͶ뤷Ƥޤƽޤǡ˽g`ʤȫоYϤB餷\뤹٤ƤˡȤʿ֤äƤޤCϡˤgF뤿Υؤ֤äƤޤäơMule-Arch-201}ϡԇY˺ϸδ٤ȡΤޤޤlĤʾ֤AʤεiץȤ˷eOĤȡMߤޤ
Salesforce Mule-Arch-201JԇYY֤ΤSalesforce}ṩ륵Ȥ϶यʤäƤޤ顢ʤԇYʂ䤹ȤηːǤޤҡMule-Arch-201YϤϱΌTҤˤä_kơʤԇYؤκϸ뤳ȤǤޤˡMule-Arch-201}Ϥ⤦¤ޤΤǡYβ뤳ȤǤޤ
Salesforce Certified MuleSoft Platform Architect J Mule-Arch-201 ԇY} (Q136-Q141):| # 136
An organization has implemented a Customer Address API to retrieve customer address information. This API has been deployed to multiple environments and has been configured to enforce client IDs everywhere.
A developer is writing a client application to allow a user to update their address. The developer has found the Customer Address API in Anypoint Exchange and wants to use it in their client application.
What step of gaining access to the API can be performed automatically by Anypoint Platform?
- A. Request access to the appropriate API Instances deployed to multiple environments using the client application's credentials
- B. Create a new application in Anypoint Exchange for requesting access to the API
- C. Approve the client application request for the chosen SLA tier
- D. Modify the client application to call the API using the client application's credentials
⣺C
h
Correct Answe r: Approve the client application request for the chosen SLA tier
>> Only approving the client application request for the chosen SLA tier can be automated
>> Rest of the provided options are not valid
| # 137
When must an API implementation be deployed to an Anypoint VPC?
- A. When the API implementation must be deployed to a production AWS VPC using the Mule Maven plugin
- B. When the API Implementation must write to a persistent Object Store
- C. When the API Implementation must invoke publicly exposed services that are deployed outside of CloudHub in a customer- managed AWS instance
- D. When the API implementation must be accessible within a subnet of a restricted customer-hosted network that does not allow public access
⣺C
| # 138
Traffic is routed through an API proxy to an API implementation. The API proxy is managed by API Manager and the API implementation is deployed to a CloudHub VPC using Runtime Manager. API policies have been applied to this API. In this deployment scenario, at what point are the API policies enforced on incoming API client requests?
- A. At both the API proxy and the API implementation
- B. At a MuleSoft-hosted load balancer
- C. At the API implementation
- D. At the API proxy
⣺D
h
Correct Answe r: At the API proxy
>> API Policies can be enforced at two places in Mule platform.
>> One - As an Embedded Policy enforcement in the same Mule Runtime where API implementation is running.
>> Two - On an API Proxy sitting in front of the Mule Runtime where API implementation is running.
>> As the deployment scenario in the question has API Proxy involved, the policies will be enforced at the API Proxy.
| # 139
An API has been updated in Anypoint Exchange by its API producer from version 3.1.1 to 3.2.0 following accepted semantic versioning practices and the changes have been communicated via the API's public portal.
The API endpoint does NOT change in the new version.
How should the developer of an API client respond to this change?
- A. The update should be identified as a project risk and full regression testing of the functionality that uses this API should be run
- B. The API client code ONLY needs to be changed if it needs to take advantage of new features
- C. The API producer should be contacted to understand the change to existing functionality
- D. The API producer should be requested to run the old version in parallel with the new one
⣺B
| # 140
Which scenario is suited for MUnit tests instead of integration tests?
- A. For tests that are implemented using SoapUI
- B. For read-only interactions to any dependencies (such as other web APIs)
- C. When no mocking is permissible
- D. When testing does not require knowledge of implementation details
⣺B
h
MUnit is MuleSoft's testing framework for creating and running automated tests within Anypoint Studio. It is specifically designed for unit testing Mule applications and is best suited when testing doesn't require understanding the inner workings or implementation details of the components being tested.
Ideal Use Cases for MUnit:
MUnit is optimal when testing individual flows, functions, or components in isolation. This type of testing focuses on verifying the behavior of each unit without needing to understand the complete system.
Since unit tests do not require external integrations or dependencies to be live, mocking is commonly used in MUnit to simulate the behavior of external services and APIs.
Why Option B is Correct:
Option B aligns with the concept of unit testing, where the emphasis is on testing functionality rather than system integration. Integration tests, on the other hand, would require implementation knowledge and live endpoints, making them unsuitable for MUnit's scope.
of Incorrect Options:
Option A (read-only interactions) and Option C (no mocking) do not suit MUnit's typical testing environment as MUnit is designed with mocking capabilities to simulate dependencies.
Option D (SoapUI-based tests) suggests an external testing tool, while MUnit is specific to MuleSoft.
Reference
For more on MUnit best practices, refer to MuleSoft's MUnit documentation.
| # 141
ҡϤʤҡMule-Arch-201}ͨԇY˺ϸǤΤ^Ƥޤ⤷ҤǤʤԇYʧޤ顢ʤγɿΥäơҡȫ~ǤʤMule-Arch-201}ν~𤷤ơʤʧ뤿νUgpʧp٤ޤ
Mule-Arch-201ƥȥץ놖}: https://www.goshiken.com/Salesforce/Mule-Arch-201-mondaishu.html
Mule-Arch-201ƥȥץ놖} - Salesforce Certified MuleSoft Platform ArchitectԇYϸߤעBäƤl⤬֪äƤ褦ˡҪʆ}ѧMule-Arch-201ѧ}|Ǥ^ȥˤ錄äơΰˤΘIΌTҤᡢФʤۤɤy˷KĤȫѧuƷǤMule-Arch-201ƥȻشɤޤ˽uƷо̲ĤϡʤʹäMule-Arch-201ԇYߥ`Ф⌟TĤǤʤФʤʤȤԤ˼ޤաGoShiken Mule-Arch-201ƥȥץ놖}ЈǤθ^ȥΤɤΕr⼤ʤäƤޤһˡϡһWebMule-Arch-201ƥȥץ놖} - Salesforce Certified MuleSoft Platform ArchitectuƷُ뤷ᡢSMSڸƥީ`ƥːޤ뤳Ȥ褯ޤ
jѤԑʤǤǰ˽餷g˰פʚݳ֤˽Mule-Arch-201ϥ`Ȥƣ옔Dä ؤ`Υɥ_ƵͤԤ¤ϷäƤʤSalesforce Certified MuleSoft Platform ArchitectԇYϸߤעBäƤ
Salesforce Mule-Arch-201 Exam | Mule-Arch-201rg - 륦֥ Mule-Arch-201ƥȥץ놖}l⤬֪äƤ褦ˡҪʆ}ѧMule-Arch-201ѧ}|Ǥ^ȥˤ錄äơΰˤΘIΌTҤᡢФʤۤɤy˷KĤȫѧuƷǤMule-Arch-201ƥȻشɤޤ
˽uƷо̲ĤϡʤʹäMule-Arch-201ԇYߥ`Ф⌟TĤǤʤФʤʤȤԤ˼ޤաGoShikenЈǤθ^ȥΤɤΕr⼤ʤäƤޤ
- Mule-Arch-201Y 🚠 Mule-Arch-201ԇY 🏆 Mule-Arch-201YY 🐘 ▛ [url]www.passtest.jp ▟ƄӤ➥ Mule-Arch-201 🡄ơoϤǥ`ɿܤԇYYϤ̽ޤMule-Arch-201Y[/url]
- Mule-Arch-201rgSalesforce Certified MuleSoft Platform Architectޤ, ˺ϸ 🐵 [url]www.goshiken.com ➥ Mule-Arch-201 🡄ơoϤǥ`ɤƤMule-Arch-201ץ놖}[/url]
- -gĤMule-Arch-201rgԇY-ԇYΜʂ䷽Mule-Arch-201ƥȥץ놖} 🧶 [url]www.japancert.com _⏩ Mule-Arch-201 ⏪ơoϤǥ`ɤƤMule-Arch-201J[/url]
- gH-餷Mule-Arch-201rgԇY-ԇYΜʂ䷽Mule-Arch-201ƥȥץ놖} 🦃 ▷ [url]www.goshiken.com ◁ˤϟoϤΡ Mule-Arch-201 }ޤMule-Arch-201J^pdfY[/url]
- Mule-Arch-201ԇYΜʂ䷽¤Mule-Arch-201rgԇYΤSalesforce Certified MuleSoft Platform Architectƥȥץ놖} 🦂 ⏩ [url]www.shikenpass.com ⏪顸 Mule-Arch-201 ơԇYYϤoϤǥ`ɤƤMule-Arch-201J[/url]
- Mule-Arch-201ԇY} 🎁 Mule-Arch-201Y ☮ Mule-Arch-201J^pdfY 🏖 ▛ [url]www.goshiken.com ▟Ȥ▶ Mule-Arch-201 ◀}ʹMule-Arch-201J^pdfY[/url]
- Mule-Arch-201rgSalesforce Certified MuleSoft Platform Architect˺ϸ뤿txkˤʤޤ 🍒 [url]www.passtest.jp 麆gˣ Mule-Arch-201 oϤǥ`ɤǤޤMule-Arch-201ϸ[/url]
- Mule-Arch-201rgxkȡSalesforce Certified MuleSoft Platform Architect˺ϸȤζޤ ⏰ ⏩ [url]www.goshiken.com ⏪麆g➤ Mule-Arch-201 ⮘oϤǥ`ɤǤޤMule-Arch-201ձZ}[/url]
- Mule-Arch-201ԇY ⌨ Mule-Arch-201J^pdfY 🩱 Mule-Arch-201oԇY 🕐 ֥➤ [url]www.xhs1991.com ⮘_➥ Mule-Arch-201 🡄ƟoϤǥ`ɤƤMule-Arch-201YYϸ°[/url]
- Mule-Arch-201rgSalesforce Certified MuleSoft Platform Architect˺ϸ뤿txkˤʤޤ 🏬 rgoϤʹ롶 Mule-Arch-201 ԇY}➥ [url]www.goshiken.com 🡄ȤǗMule-Arch-201ץ놖}[/url]
- Mule-Arch-201ԇYh} 🛹 Mule-Arch-201ϸ 🍼 Mule-Arch-201ԇY 💁 ➽ [url]www.xhs1991.com 🢪⮆ Mule-Arch-201 ⮄ơoϤǥ`ɤƤMule-Arch-201YY[/url]
- www.stes.tyc.edu.tw, kemono.im, www.stes.tyc.edu.tw, elearning.eauqardho.edu.so, www.stes.tyc.edu.tw, www.thingstogetme.com, www.stes.tyc.edu.tw, building.lv, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
