[General] Browser-based Fortinet FCP_FSM_AN-7.2 Practice Test Software
139
【General】 Browser-based Fortinet FCP_FSM_AN-7.2 Practice Test Software
Posted at 2/23/2026 00:47:12      View:107 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest TestkingPass FCP_FSM_AN-7.2 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1TSLIOFKJ6nr6kpOMdpNzbW4bCXg_pPZH
If the user fails in the FCP_FSM_AN-7.2 exam questions for any reason, we will refund the money after this process. In addition, we provide free updates to users for one year long. If the user finds anything unclear in the FCP_FSM_AN-7.2 practice materials exam, we will send email to fix it, and our team will answer all of your questions related to the FCP_FSM_AN-7.2 Guide prep. What is more, we provide the free demows of our FCP_FSM_AN-7.2 study prep for our customers to download before purchase.
Fortinet FCP_FSM_AN-7.2 Exam Syllabus Topics:
  • Analytics: This section of the exam measures the skills of Security Analysts and covers the foundational techniques for building and refining queries. It focuses on creating searches from events, applying grouping and aggregation methods, and performing various lookup operations, including CMDB and nested queries to effectively analyze and correlate data.
  • Incidents, notifications, and remediation: This section of the exam measures the skills of Incident Responders and encompasses the entire incident management lifecycle. This includes the skills required to manage and prioritize security incidents, configure policies for alert notifications, and set up automated remediation actions to contain and resolve threats.
  • Machine learning, UEBA, and ZTNA: This section of the exam measures the skills of Advanced Security Architects and covers the integration of modern security technologies. It involves performing configuration tasks for machine learning models, incorporating UEBA (User and Entity Behavior Analytics) data into rules and dashboards for enhanced threat detection, and understanding how to integrate ZTNA (Zero Trust Network Access) principles into security operations.
  • Rules and subpatterns: This section of the exam measures the skills of SOC Engineers and focuses on the construction and implementation of analytics rules. It involves identifying the different components that make up a rule, utilizing advanced features like subpatterns and aggregation, and practically configuring these rules within the FortiSIEM platform to detect security events.
Here's the Right Way to Pass Fortinet FCP_FSM_AN-7.2 ExamOur society needs all kinds of comprehensive talents, the FCP_FSM_AN-7.2 latest preparation materials can give you what you want, but not just some boring book knowledge, but flexible use of combination with the social practice. Therefore, it is necessary for us to pass the qualification FCP_FSM_AN-7.2 examinations, the FCP_FSM_AN-7.2 study practice question can bring you high quality learning platform. If you want to progress and achieve their ideal life, if you still use the traditional methods by exam, so would you please choose the FCP_FSM_AN-7.2 test materials, it will surely make you shine at the moment.
Fortinet FCP - FortiSIEM 7.2 Analyst Sample Questions (Q12-Q17):NEW QUESTION # 12
A FortiSIEM device is receiving syslog events from a FortiGate firewall. The FortiSIEM analyst is trying to search the raw event logs for the last two hours that contain the keyword "udp". However, they are getting no results from the search, which they know should be available. Based on the filter shown in the exhibit, why are there no search results?
  • A. The analyst selected AND in the Next column. This is the wrong Boolean operator.
  • B. The Time Range value should be set to Real-Time.
  • C. The keyword is case sensitive. Instead of typing udp in the Value field, the analyst should type UDP.
  • D. The analyst selected = in the Operator column. That is the wrong operator.
The operator is set to "=", which performs an exact match on the entire raw event log, not a substring search. To find logs that contain the keyword "udp", the analyst should use the CONTAIN operator instead. This will return all logs where "udp" appears anywhere in the raw log message.
NEW QUESTION # 13
Which statement about thresholds is true?
  • A. FortiSIEM uses only device thresholds for security metrics.
  • B. FortiSIEM uses fixed, hardcoded global and device thresholds for all performance metrics.
  • C. FortiSIEM uses global and per device thresholds for performance metrics.
  • D. FortiSIEM uses only global thresholds for performance metrics.
FortiSIEM evaluates performance metrics against both global thresholds, which apply system-wide, and per-device thresholds, which can be customized for individual devices. This dual approach allows flexibility in monitoring while ensuring consistent baseline alerting.
NEW QUESTION # 14
If a rule containing the automation policy shown in the exhibit triggers, what will happen?
  • A. Associated source IP addresses will be blocked on devices in the Network CMDB group.
  • B. Associated source IP addresses will be blocked on all FortiGate firewalls.
  • C. Associated source IP addresses will be blocked on two FortiGate firewalls.
  • D. Associated source IP addresses will be blocked on devices in the Aviation organization.
The automation policy is configured to run a remediation script named "Fortinet FortiOS - Block Source IP FortiOS via API". It specifies enforcement on two FortiGate devices: FortiGate508 and FortiGate90D. Therefore, associated source IP addresses will be blocked on those two FortiGate firewalls only.
NEW QUESTION # 15
If you group the events by User and Count attributes, how many results will FortiSIEM display?
  • A. Six
  • B. Two
  • C. Three
  • D. One
  • E. Five
Answer: E
Grouping by User and Count yields five unique pairs: (Mike,4), (Bob,3), (Alice,2), (Bob,6), (Mike,5).
NEW QUESTION # 16
What happens when an analyst clears an incident generated by a rule containing the automation policy shown in the exhibit?
  • A. The remediation script is run.
  • B. No notification is sent.
  • C. An email is sent to the SOC manager.
  • D. A notification is sent to the SOC manager dashboard.
The automation policy has the option "Do not notify when an incident is cleared manually" enabled. Therefore, when an analyst manually clears an incident, no notification or automation action is triggered.
NEW QUESTION # 17
Good news comes that our company has successfully launched the new version of the FCP_FSM_AN-7.2 guide tests. Perhaps you are deeply bothered by preparing the exam; perhaps you have wanted to give it up. Now, you can totally feel relaxed with the assistance of our FCP_FSM_AN-7.2 actual test. Our products are definitely more reliable and excellent than other exam tool. What is more, the passing rate of our study materials is the highest in the market. There are thousands of customers have passed their exam and get the related certification. After that, all of their FCP_FSM_AN-7.2 Exam torrents were purchase on our website.
FCP_FSM_AN-7.2 Downloadable PDF: https://www.testkingpass.com/FCP_FSM_AN-7.2-testking-dumps.html
BTW, DOWNLOAD part of TestkingPass FCP_FSM_AN-7.2 dumps from Cloud Storage: https://drive.google.com/open?id=1TSLIOFKJ6nr6kpOMdpNzbW4bCXg_pPZH
