[General] Three Easy-to-Use and Compatible Formats of XSOAR-Engineer Exam Questions
98
General Three Easy-to-Use and Compatible Formats of XSOAR-Engineer Exam Questions
Posted at 1/28/2026 14:31:03      View174 | Replies1        Print      Only Author   [Copy Link] 1#
Our company is a well-known multinational company, has its own complete sales system and after-sales service worldwide. In the same trade at the same time, our XSOAR-Engineer real study dumps have become a critically acclaimed enterprise, so, if you are preparing for the exam qualification and obtain the corresponding certificate, so our company launched XSOAR-Engineer exam questions are the most reliable choice of you. The service tenet of our company and all the staff work mission is: through constant innovation and providing the best quality service, make the XSOAR-Engineer question guide become the best customers electronic test study materials. No matter where you are, as long as you buy the XSOAR-Engineer real study dumps, we will provide you with the most useful and efficient learning materials. As you can see, the advantages of our research materials are as follows.
Palo Alto Networks XSOAR-Engineer Exam Syllabus Topics:
  • Planning, Installation, and Maintenance: This domain covers system setup and administration including authentication configuration, engine deployment, dev
  • prod environment planning, Marketplace pack management, integration instance configuration, and system maintenance.
  • Threat Intelligence Management: This domain focuses on threat intelligence operations including indicator creation and configuration, indicator relationships, enrichment with source reliability, external intelligence sharing, and exclusion list management.
  • Incident Interactions and Reporting: This domain covers incident operations including states and actions, War Room activities, incident relationships, and dashboard and report configuration for metrics and visualization.
  • Use Case Planning and Development: This domain focuses on designing security use cases through incident and indicator lifecycle management, field and layout customization, classifier and mapper configuration, incident creation methods, pre
  • post-processing, and incident type configuration with playbooks, layouts, SLAs, and lists.
Topic 5
  • Playbook Development: This domain addresses automation through playbook creation including task configuration, context data manipulation, various task types, sub-playbooks with looping, filters and transformers, debugger usage, built-ins and scripts, automation script creation, and job management.
Palo Alto Networks XSOAR-Engineer Valid Torrent - XSOAR-Engineer Latest Exam TipsAuthorized test Palo Alto Networks XSOAR Engineer dumps Premium Files Test Engine pdf. Updated XSOAR-Engineer training topics with question explanations. Free practice Palo Alto Networks study demo with reasonable exam price. Guaranteed XSOAR-Engineer Questions Answers 365 days free updates. pass XSOAR-Engineer exam with excellect pass rate. Positive feedback fromReal4test's customwrs. XSOAR-Engineer sample questions answers has regualer updates.
Palo Alto Networks XSOAR Engineer Sample Questions (Q177-Q182):NEW QUESTION # 177
What is the primary effect on a new file hash when it is added to the indicator exclusion list?.
  • A. It is extracted and stored, but an "exclusion" tag is added, requiring manual review before it can affect any incidents.
  • B. It is not extracted, enriched, or given a new verdict.
  • C. It is excluded from intelligence feeds that have a reliability score lower than "B - Usually reliable.".
  • D. It is processed normally by enrichment automations, but the verdict is set to "benign.".
The Indicator Exclusion List feature in XSOAR is designed to prevent certain IOCs (file hashes, IPs, domains, etc.) from being processed by the platform. The Admin Guide explains that once an indicator is added to the exclusion list, XSOARdoes not extract, enrich, score, or apply verdictsto that indicator during ingestion or field-change extraction. This ensures that benign internal hashes, test indicators, or noisy artifacts do not trigger incidents, enrichments, or correlation rules.
Option B does not reflect platform behavior-XSOAR does not create exclusion tags requiring manual review; instead, itcompletely bypasses extraction and enrichment. Option C is incorrect because excluded indicators do not undergo enrichment or verdict assignment at all. Option D incorrectly suggests that exclusion depends on feed reliability; the exclusion list applies globally and unconditionally.
Therefore, the correct interpretation per the documentation is thatexcluded indicators are never extracted or processed, aligning precisely with optionA.
NEW QUESTION # 178
The code snippet below is from the fetch command of an integration instance configured to run on the server.
demisto.debug(f"(len(incidents)} events fetched")
Where is the output from the snippet located when the instance runs an automatic fetch?.
  • A. Platform Log bundle.
  • B. War Room entry.
  • C. Incident label.
  • D. Integration Logs table.
Integration debug messages (generated using demisto.debug) are stored in the Integration Logs table, not in the War Room or incident labels.
The Admin Guide states that all logs generated by integration code are visible through the Integration Logs section for troubleshooting.
NEW QUESTION # 179
Given the following context data, what would be the expected output of the expression?
  • A. 1E56733826E5035233A097FCEA2046AF96EC616C
  • B. 8D193FA162A305E4859BA8C45F5121F7265E3ABB
  • C. E6EF5142E2553C1E442A0FFAC07636EAC61E6EDD
  • D. e6ef5142e2553c1e442a0ffac07636eac61e6edd
NEW QUESTION # 180
An incident has been created in the following state:
There is no playbook attached.
The War Room is available, but no commands have been run yet.
What is the status of the incident?.
  • A. Waiting.
  • B. In-progress.
  • C. Active.
  • D. Pending.
The XSOAR Incident State Model defines several system statuses: Pending, Active, In-Progress, Done, and Closed. When an incident is newly created and has not yet had a playbook assigned or started-and no analyst actions (such as commands or work plan steps) have been taken-it remains in the Pending state.
Pending indicates that the incident exists in the system but has not yet begun active investigation or automated processing. The Admin Guide clarifies that an incident becomes Active only when a playbook starts or an analyst interacts with it. In-Progress is a manually applied user state indicating active human processing.
Waiting is used for blocked or paused tasks but does not apply at initial creation.
Because the War Room is available but unused, and no automation has begun, the incident fits the definition of Pending exactly. Once a playbook were attached or a command were executed, the state would transition to Active.
Therefore, the documented correct answer is B: Pending.
NEW QUESTION # 181
What is the function of timer SLA fields in Cortex XSOAR?
  • A. To track SLA breaches per playbook
  • B. To automatically alert the analyst on SLA breach
  • C. To count the time between one or more tasks
  • D. To run a script that executes on SLA assignment
Reference: https://docs-cortex.paloaltonetw ... ar-admin/work-with- slas/create-an-sla-field
NEW QUESTION # 182
With pass rate reaching 98.75%, XSOAR-Engineer exam torrent has received great popularity among candidates, and they think highly of the exam dumps. In addition, XSOAR-Engineer exam braindumps are high-quality and accuracy, because we have professionals to verify the answers to ensure the accuracy. XSOAR-Engineer exam dumps have most of knowledge points for the exam, and you can mater the major points through practicing. In addition, we have online and offline chat service for XSOAR-Engineer Exam Dumps, and they posse the professional knowledge for the exam. If you have any questions about XSOAR-Engineer exam materials, you can have a conversation with us.
XSOAR-Engineer Valid Torrent: https://www.real4test.com/XSOAR-Engineer_real-exam.html
Posted at 2/23/2026 03:11:09        Only Author  2#
It offered a wealth of insights I hadnt considered before. 312-97 exam sims provides free, abundant content, designed to help you succeed.
