[General] Exam XDR-Analyst questions and answers
128
【General】 Exam XDR-Analyst questions and answers
Posted at 1/17/2026 11:37:54      View:111 | Replies:7        Print      Only Author   [Copy Link] 1#
Our experts are researchers who have been engaged in professional qualification XDR-Analyst exams for many years and they have a keen sense of smell in the direction of the examination. Therefore, with our XDR-Analyst study materials, you can easily find the key content of the exam and review it in a targeted manner so that you can successfully pass the XDR-Analyst Exam. We have free demos of the XDR-Analyst exam materials that you can try before payment.
Palo Alto Networks XDR-Analyst Exam Syllabus Topics:
  • Data Analysis: This domain encompasses querying data with XQL language, utilizing query templates and libraries, working with lookup tables, hunting for IOCs, using Cortex XDR dashboards, and understanding data retention and Host Insights.
  • Incident Handling and Response: This domain focuses on investigating alerts using forensics, causality chains and timelines, analyzing security incidents, executing response actions including automated remediation, and managing exclusions.
  • Endpoint Security Management: This domain addresses managing endpoint prevention profiles and policies, validating agent operational states, and assessing the impact of agent versions and content updates.
  • Alerting and Detection Processes: This domain covers identifying alert types and sources, prioritizing alerts through scoring and custom configurations, creating incidents, and grouping alerts with data stitching techniques.
Pass Guaranteed 2026 Palo Alto Networks Accurate XDR-Analyst Actual ExamsXDR-Analyst learning materials have a variety of self-learning and self-assessment functions to test learning outcomes. XDR-Analyst study guide is like a tutor, not only gives you a lot of knowledge, but also gives you a new set of learning methods. XDR-Analyst Exam Practice is also equipped with a simulated examination system that simulates the real exam environment so that you can check your progress at any time.
Palo Alto Networks XDR Analyst Sample Questions (Q53-Q58):NEW QUESTION # 53
Which of the following is NOT a precanned script provided by Palo Alto Networks?
  • A. quarantine_file
  • B. process_kill_name
  • C. list_directories
  • D. delete_file
Palo Alto Networks provides a set of precanned scripts that you can use to perform various actions on your endpoints, such as deleting files, killing processes, or quarantining malware. The precanned scripts are written in Python and are available in the Agent Script Library in the Cortex XDR console. You can use the precanned scripts as they are, or you can customize them to suit your needs. The precanned scripts are:
delete_file: Deletes a specific file from a local or removable drive.
quarantine_file: Moves a specific file from its location on a local or removable drive to a protected folder and prevents it from being executed.
process_kill_name: Kills a process by its name on the endpoint.
process_kill_pid: Kills a process by its process ID (PID) on the endpoint.
process_kill_tree: Kills a process and all its child processes by its name on the endpoint.
process_kill_tree_pid: Kills a process and all its child processes by its PID on the endpoint.
process_list: Lists all the processes running on the endpoint, along with their names, PIDs, and command lines.
process_list_tree: Lists all the processes running on the endpoint, along with their names, PIDs, command lines, and parent processes.
process_start: Starts a process on the endpoint by its name or path.
registry_delete_key: Deletes a registry key and all its subkeys and values from the Windows registry.
registry_delete_value: Deletes a registry value from the Windows registry.
registry_list_key: Lists all the subkeys and values under a registry key in the Windows registry.
registry_list_value: Lists the value and data of a registry value in the Windows registry.
registry_set_value: Sets the value and data of a registry value in the Windows registry.
The script list_directories is not a precanned script provided by Palo Alto Networks. It is a custom script that you can write yourself using Python commands.
Run Scripts on an Endpoint
Precanned Scripts
NEW QUESTION # 54
How can you pivot within a row to Causality view and Timeline views for further investigate?
  • A. Using the Open Card Only
  • B. You can't pivot within a row to Causality view and Timeline views
  • C. Using Open Timeline Actions Only
  • D. Using the Open Card and Open Timeline actions respectively
To pivot within a row to Causality view and Timeline views for further investigation, you can use the Open Card and Open Timeline actions respectively. The Open Card action will open a new tab with the Causality view of the selected row, showing the causal chain of events that led to the alert. The Open Timeline action will open a new tab with the Timeline view of the selected row, showing the chronological sequence of events that occurred on the affected endpoint. These actions allow you to drill down into the details of each alert and understand the root cause and impact of the incident. Reference:
Cortex XDR User Guide, Chapter 9: Investigate Alerts, Section: Pivot to Causality View and Timeline View PCDRA Study Guide, Section 3: Investigate and Respond to Alerts, Objective 3.1: Investigate alerts using the Causality view and Timeline view
NEW QUESTION # 55
What kind of malware uses encryption, data theft, denial of service, and possibly harassment to take advantage of a victim?
  • A. Ransomware
  • B. Rootkit
  • C. Keylogger
  • D. Worm
The kind of malware that uses encryption, data theft, denial of service, and possibly harassment to take advantage of a victim is ransomware. Ransomware is a type of malware that encrypts the victim's files or blocks access to their system, and then demands a ransom for the decryption key or the restoration of access. Ransomware can also threaten to expose or delete the victim's data if the ransom is not paid. Ransomware can cause significant damage and disruption to individuals, businesses, and organizations, and can be difficult to remove or recover from. Some examples of ransomware are CryptoLocker, WannaCry, Ryuk, and REvil.
12 Types of Malware + Examples That You Should Know - CrowdStrike
What is Malware? Malware Definition, Types and Protection
12+ Types of Malware Explained with Examples (Complete List)
NEW QUESTION # 56
Which of the following policy exceptions applies to the following description?
'An exception allowing specific PHP files'
  • A. Process exception
  • B. Support exception
  • C. Behavioral threat protection rule exception
  • D. Local file threat examination exception
The policy exception that applies to the following description is B, local file threat examination exception. A local file threat examination exception is an exception that allows you to exclude specific files or folders from being scanned by the Cortex XDR agent for malware or threats. You can use this exception to prevent false positives, performance issues, or compatibility problems with legitimate files or applications. You can define the local file threat examination exception by file name, file path, file hash, or digital signer. For example, you can create a local file threat examination exception for specific PHP files by entering their file names or paths in the exception configuration. Reference:
Local File Threat Examination Exceptions
Create a Local File Threat Examination Exception
NEW QUESTION # 57
To create a BIOC rule with XQL query you must at a minimum filter on which field in order for it to be a valid BIOC rule?
  • A. causality_chain
  • B. event_type
  • C. threat_event
  • D. endpoint_name
To create a BIOC rule with XQL query, you must at a minimum filter on the event_type field in order for it to be a valid BIOC rule. The event_type field indicates the type of event that triggered the alert, such as PROCESS, FILE, REGISTRY, NETWORK, or USER_ACCOUNT. Filtering on this field helps you narrow down the scope of your query and focus on the relevant events for your use case. Other fields, such as causality_chain, endpoint_name, threat_event, are optional and can be used to further refine your query or display additional information in the alert. Reference:
Palo Alto Networks Certified Detection and Remediation Analyst (PCDRA) Study Guide, page 9 Palo Alto Networks Cortex XDR Documentation, BIOC Rule Query Syntax
NEW QUESTION # 58
The secret of success is constancy to purpose. If your purpose is passing exams and getting a certification. XDR-Analyst exam cram PDF will be the right shortcut for your exam. You shouldn't miss any possible chance or method to achieve your goal, especially our XDR-Analyst Exam Cram Pdf always has 100% passing rate. Mostly choice is greater than effort. Well-pointed preparation for your test will help you save a lot of time. Palo Alto Networks XDR-Analyst exam cram PDF will be great helper for your coming exam definitely.
Braindump XDR-Analyst Pdf: https://www.2pass4sure.com/Security-Operations/XDR-Analyst-actual-exam-braindumps.html
Posted at 1/18/2026 05:19:03        Only Author  2#
I appreciate your article, it was so refreshing and insightful. The NSE5_SSE_AD-7.6 reliable test prep test was a key factor in my professional growth, and now I’m sharing it with you for free!
Posted at 1/19/2026 19:32:48        Only Author  3#
The article provided me with a wealth of knowledge. I’m sharing the 220-1202 pass test questions that helped me get promoted and earn more—grab them for free!
Posted at 1/25/2026 04:57:51        Only Author  4#
The content is impressive, definitely worthy of a like. The Study C_ARCIG_2508 Notes study guide is free for everyone—good luck!
Posted at 2/3/2026 14:16:46        Only Author  5#
This article is mind-blowing, thank you for sharing! Explore the valuable content in Llatest exam collection 300-715 sheet, provided for free to assist you.
Posted at 2/17/2026 15:17:36        Only Author  6#
AZ-900-JPN試験には多くの利点があり、Microsoft購入する価値があります。購入前にAZ-900-JPNガイドの質問デモをダウンロードして試用し、支払いが完了したらすぐに使用できます。支払いが完了したら、5〜10分以内に送信します。その後、あなたはそれを学び、実践することができます。Microsoft Azure Fundamentals (AZ-900日本語版)試験に合格するための最新のAZ-900-JPN試験問題があることを確認するために、AZ-900-JPNトレント質問を頻繁に更新します。 AZ-900-JPN試験に合格すると、大企業に入社して賃金を2倍にすることができます。
Posted at 6 day before        Only Author  7#
Die Zuverlässigkeit basiert sich auf die hohe Qualität, deshalb ist unsere Microsoft DP-300 vertrauenswürdig. Allein die mit einer Höhe von fast 100% Bestehensquote überzeugen Sie vielleicht nicht. Dann laden Sie bitte die kostenlose Demos der Microsoft DP-300 herunter und probieren! Um verschiedene Gewohnheiten der Prüfungsteilnehmer anzupassen, bieten wir insgesamt 3 Versionen von Microsoft DP-300. Nach den Informationenen über die Ermäßigung u.a. können Sie auf unserer Webseite online erkundigen.
Posted at yesterday 14:53        Only Author  8#
The article is absolutely magnificent, thank you for sharing it with us. The New C-S4CPB-2508 test simulator online exam is coming up fast. Wish me the best!
