[General] EDGE-Expert Reliable Test Price - EDGE-Expert Exam Quiz
140
【General】 EDGE-Expert Reliable Test Price - EDGE-Expert Exam Quiz
Posted at before yesterday 16:43      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest PracticeTorrent EDGE-Expert PDF Dumps and EDGE-Expert Exam Engine Free Share: https://drive.google.com/open?id=1Qc2QBW6FcQg7KetVWKXKdPlM_obxLTNh
Our company can provide the anecdote for you--our EDGE-Expert study materials. Under the guidance of our EDGE-Expert exam practice, you can definitely pass the exam as well as getting the related certification with the minimum time and efforts. We would like to extend our sincere appreciation for you to browse our website, and we will never let you down. The advantages of our EDGE-Expert Guide materials are too many to count and you can free download the demos to have a check before purchase.
EDGE-Expert exam questions have a very high hit rate, of course, will have a very high pass rate. Before you select a product, you must have made a comparison of your own pass rates. Our EDGE-Expert study materials must appear at the top of your list. And our EDGE-Expert learning quiz has a 99% pass rate. This is the result of our efforts and the best gift to the user. And it is also proved and tested the quality of our EDGE-Expert training engine is excellent.
EDGE-Expert Exam Quiz, EDGE-Expert Accurate TestThe solution is closer to you than you can imagine, just contact the support team and continue enjoying your study with the Excellence in Design for Greater Efficiencies (EDGE Expert) Exam preparation material. PracticeTorrent offers affordable Excellence in Design for Greater Efficiencies (EDGE Expert) Exam exam preparation material. You don’t have to go beyond your budget to buy updated EDGE EDGE-Expert Dumps. To make your EDGE-Expert exam preparation material smooth, a bundle pack is also available that includes all the 3 formats of dumps questions.
EDGE Excellence in Design for Greater Efficiencies (EDGE Expert) Exam Sample Questions (Q65-Q70):NEW QUESTION # 65
Which of the following parameters can be found in the EDGE App Results Bar?
  • A. Incremental cost
  • B. Occupant use
  • C. Building type
  • D. Climate conditions
The EDGE App Results Bar displays key outputs of the software analysis after a project is modeled. The EDGE User Guide details the contents of the Results Bar: "The EDGE App Results Bar provides a summary of the project's performance, including percentage savings in energy, water, and embodied energy in materials, as well as the incremental cost, payback period, and carbon emissions reduction" (EDGE User Guide, Section 2.4: Interpreting EDGE Results). Option C, incremental cost, is explicitly mentioned as part of the Results Bar, representing the additional cost of implementing green measures. Option A (building type) and Option B (occupant use) are inputs specified by the user during project setup, not outputs in the Results Bar, as noted: "Building type and occupant use are input parameters, not displayed in the Results Bar" (EDGE User Guide, Section 2.2: Project Setup). Option D (climate conditions) is also an input parameter (selected via location), not an output: "Climate conditions are derived from the selected location and are not shown in the Results Bar" (EDGE Methodology Report Version 2.0, Section 3.2: Climate Data Inputs). Thus, incremental cost (Option C) is the correct parameter found in the Results Bar.
Reference: EDGE User Guide Version 2.1, Section 2.4: Interpreting EDGE Results, Section 2.2: Project Setup; EDGE Methodology Report Version 2.0, Section 3.2: Climate Data Inputs.
NEW QUESTION # 66
In the EDGE software, what is the unit of the embodied carbon of the material?
  • A. kWh
  • B. kgCO2
  • C. BTU
  • D. MJ
Embodied carbon in EDGE refers to the carbon emissions associated with the production, transportation, and installation of building materials, a key metric for materials efficiency. The EDGE User Guide specifies how this is measured: "In the EDGE software, the embodied carbon of materials is quantified in kilograms of carbon dioxide equivalent (kgCO2), reflecting the total greenhouse gas emissions associated with the material' s lifecycle, from extraction to installation"(EDGE User Guide, Section 7.2: Materials Efficiency Measures).
Option A, kgCO2, directly matches this unit, as EDGE uses kgCO2 to standardize carbon emissions across materials, allowing for comparison and aggregation in the software's results. Option B (MJ) is incorrect, as MJ (megajoules) measures embodied energy, not carbon: "Embodied energy in EDGE is measured in MJ, representing the energy consumed in material production, while embodied carbon is separately calculated in kgCO2 to assess environmental impact" (EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials). Option C (BTU) is also incorrect, as BTU (British Thermal Units) is an energy unit not used in EDGE for carbon calculations: "EDGE uses metric units like MJ for energy and kgCO2 for carbon; BTU is not a standard unit in the software" (EDGE User Guide, Section 2.3: Using the EDGE App). Option D (kWh) is another energy unit, typically used for operational energy, not embodied carbon: "kWh is used in EDGE to measure operational energy consumption, such as electricity use, but not for embodied carbon, which is always in kgCO2" (EDGE Methodology Report Version 2.0, Section 5.2: Energy Calculation Methods). The EDGE User Guide further clarifies: "The software displays embodied carbon in kgCO2 to align with global carbon accounting standards, enabling users to understand the environmental footprint of their material choices" (EDGE User Guide, Section 7.2: Materials Efficiency Measures). The EDGE Methodology Report adds: "For example, concrete might have an embodied carbon of 0.15 kgCO2 per kg, allowing users to compare materials like fly ash concrete versus standard concrete in terms of carbon impact" (EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials). Thus, the unit of embodied carbon in EDGE is kgCO2 (Option A).
Reference:EDGE User Guide Version 2.1, Section 7.2: Materials Efficiency Measures, Section 2.3: Using the EDGE App; EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials, Section
5.2: Energy Calculation Methods.
NEW QUESTION # 67
EDGE was created for new buildings to promote:
  • A. Simple and scalable platform for green buildings.
  • B. Few exemplary high-performance buildings.
  • C. Revenue for green building champions.
  • D. Highly accurate prediction of resource consumption.
The purpose of EDGE, as defined by the International Finance Corporation (IFC), is to make green building accessible and scalable, particularly in emerging markets. The EDGE User Guide states: "EDGE was created by IFC to promote a simple and scalable platform for green buildings, enabling developers to achieve resource efficiency in new constructions through a user-friendly tool that focuses on energy, water, and materials savings" (EDGE User Guide, Section 1.1: Introduction to EDGE). Option C, a simple and scalable platform for green buildings, directly aligns with this mission. Option A (revenue for green building champions) is incorrect, as EDGE's goal is not financial gain for individuals but broader market transformation: "EDGE aims to transform the building sector, not to generate revenue for specific stakeholders" (EDGE Certification Protocol, Section 1.1: Overview). Option B (few exemplary high- performance buildings) contradicts EDGE's scalability focus: "EDGE is not about creating a few high- performance buildings but enabling widespread adoption of green practices" (EDGE User Guide, Section 1.1:
Introduction to EDGE). Option D (highly accurate prediction of resource consumption) is also incorrect, as EDGE prioritizes simplicity over precision: "EDGE uses simplified calculations for resource consumption, not highly accurate predictions, to ensure accessibility" (EDGE Methodology Report Version 2.0, Section 2.1:
Calculation Approach). Thus, EDGE promotes a simple and scalable platform (OptionC).
Reference:EDGE User Guide Version 2.1, Section 1.1: Introduction to EDGE; EDGE Certification Protocol, Section 1.1: Overview; EDGE Methodology Report Version 2.0, Section 2.1: Calculation Approach.
NEW QUESTION # 68
In the EDGE software, the Base Case selection of external wall materials in hotels relies on information derived from:
  • A. Local building material suppliers who subscribe to EDGE certification for their materials, or are nationally accredited by the local standards authority.
  • B. Typical building practices as well as national building performance codes, where they are in existence.
  • C. Hotel developers' corporate standard specifications, or materials which have been accredited by the hotel industry.
  • D. Global building practices as well as international building performance codes, where they are in existence.
The EDGE software uses a Base Case to establish a benchmark for resource consumption, tailored to local conditions. The EDGE Methodology Report explains how the Base Case is constructed: "The Base Case for external wall materials in hotels is determined using data from market surveys of typical building practices in the project's country, supplemented by national building performance codes where available. This ensures the baseline reflects local construction norms and regulatory standards" (EDGE Methodology Report Version 2.0, Section 3.1: Base Case Determination). Option A matches this description by referencing typical building practices and national codes. Option B incorrectly refers to global practices and international codes, which EDGE does not use, as the software prioritizes local context. Option C, focusing on corporate specifications, is not part of the Base Case methodology, as the Base Case is standardized, not project-specific. Option D, involving local suppliers or accreditation, is irrelevant to how EDGE determines the Base Case, which relies on broader market data rather than supplier-specificinformation.
Reference:EDGE Methodology Report Version 2.0, Section 3.1: Base Case Determination; EDGE User Guide Version 2.1, Section 2.3: Using the EDGE App.
NEW QUESTION # 69
The Client has sent a copy of the local occupancy permit for a project being audited. This permit:
  • A. Replaces the need to audit all EDGE measures.
  • B. Does not replace the need to audit all EDGE measures.
  • C. Does not replace the need for desktop studies.
  • D. Replaces the need to audit EDGE Materials measures.
An occupancy permit indicates that a building meets local regulatory requirements for occupancy,but it does not address the specific green building measures required for EDGE certification. The EDGE Certification Protocol clearly outlines the role of such permits in the audit process: "A local occupancy permit provided by the Client confirms that the building complies with local building codes and is ready for use. However, it does not replace the need to audit all EDGE measures, as EDGE certification requires verification of specific energy, water, and materials efficiency measures that are not typically covered by local permits" (EDGE Certification Protocol, Section 3.4: Post-Construction Requirements). Option A, does not replace the need to audit all EDGE measures, directly aligns with this guidance, as the Auditor must still verify each claimed measure (e.g., insulation, low-flow fixtures, fly ash concrete) against EDGE standards. Option B (replaces the need to audit all EDGE measures) is incorrect, as the permit does not address EDGE-specific requirements:
"Local permits do not verify EDGE measures like energy savings or embodied energy reductions, so a full audit is still required" (EDGE Expert and Auditor Protocols, Section 4.4: Site Audit Procedures). Option C (does not replace the need for desktop studies) is partially correct but less comprehensive, as desktop studies are only one part of the audit process: "Desktop studies are part of the audit, but the occupancy permit does not exempt any aspect of the EDGE audit, including site visits and measure verification" (EDGE Certification Protocol, Section 3.2: Audit Requirements). Option D (replaces the need to audit EDGE Materials measures) is also incorrect, as materials measures (e.g., use of fly ash concrete) require specific evidence like manufacturer's data sheets, not covered by an occupancy permit: "Materials measures require detailed documentation of embodied energy reductions, which local permits do not address" (EDGE User Guide, Section 7.2: Materials Efficiency Measures). The EDGE User Guide further reinforces: "The Auditor must verify all EDGE measures through appropriate documentation and site visits, regardless of local permits, to ensure compliance with the EDGE standard" (EDGE User Guide, Section 6.3: Post-Construction Certification). Thus, the occupancy permit does not replace the need to audit all EDGE measures (Option A).
Reference:EDGE Certification Protocol, Section 3.4: Post-Construction Requirements, Section 3.2: Audit Requirements; EDGE Expert and Auditor Protocols, Section 4.4: Site Audit Procedures; EDGE User Guide Version 2.1, Section 6.3: Post-Construction Certification, Section 7.2: Materials Efficiency Measures.
NEW QUESTION # 70
EDGE EDGE-Expert questions are available in PDF format. Our EDGE EDGE-Expert PDF is embedded with questions relevant to the actual exam content only. EDGE EDGE-Expert PDF is printable and portable, so you can learn with ease and share it on multiple devices. You can use this EDGE EDGE-Expert PDF on your mobile and tablet anywhere, anytime, without the internet and installation process.
EDGE-Expert Exam Quiz: https://www.practicetorrent.com/EDGE-Expert-practice-exam-torrent.html
With the rapid development of information, some candidates might have the worry that our EDGE-Expert practice test questions will be devalued, It is very safe, With the latest version of our EDGE-Expert updated torrent, you can not only get the new key points as well as the latest question types which will be tested in the exam but also can keep pace with the times through reading the latest events compiled in our Excellence in Design for Greater Efficiencies (EDGE Expert) Exam latest torrent, EDGE EDGE-Expert Reliable Test Price Are you worried about how to choose the learning product that is suitable for you?
This turned out to be a very active community with members who are passionate about events and event innovation, The team updates the EDGE EDGE-Expert tests regularly and is available 24/7 to address any issues.
2026 Valid EDGE-Expert: Excellence in Design for Greater Efficiencies (EDGE Expert) Exam Reliable Test PriceWith the rapid development of information, some candidates might have the worry that our EDGE-Expert Practice Test questions will be devalued, It is very safe, With the latest version of our EDGE-Expert updated torrent, youcan not only get the new key points as well as the latest question types Best EDGE-Expert Practice which will be tested in the exam but also can keep pace with the times through reading the latest events compiled in our Excellence in Design for Greater Efficiencies (EDGE Expert) Exam latest torrent.
Are you worried about how to choose the learning product that is suitable EDGE-Expert for you, For example, our IT department staff work on revising and updating every day in case something important has been ignored.
BONUS!!! Download part of PracticeTorrent EDGE-Expert dumps for free: https://drive.google.com/open?id=1Qc2QBW6FcQg7KetVWKXKdPlM_obxLTNh
