Quick Solution to Convert ICS to TXT
Posted at 2/17/2026 15:08:53
I had archived calendar data from different platforms and needed a readable format for documentation, so I started looking for a way to convert ICS to TXT without losing event details. Initially, I tried doing it manually, but the process was slow, and there were chances of missing organizer info or time-zone settings when copying data. Later, I discovered the SysInfo ICS Converter Tool, which turned out to be much more practical. It supports bulk conversion, meaning you can import many ICS files together and export them into TXT in one go, which saves hours of manual work. The tool also supports multiple output formats like PDF, HTML, DOC, and PST, so it’s useful for different reporting needs beyond just TXT. I also liked that it works with calendar files from Outlook, Google Calendar, and other services, so there’s no compatibility headache. The conversion keeps all event descriptions, locations, and scheduling metadata properly structured in the output. For teams dealing with large calendar archives, this software really makes the task simple and accurate.
