[General] Desktop PCEP-30-02 Practice Test Software - Get Python Institute Actual Exam Env
【General】 Desktop PCEP-30-02 Practice Test Software - Get Python Institute Actual Exam Env
Posted at yesterday 15:16      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest VCE4Plus PCEP-30-02 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1iMxaV715nUCm7hv-orJ6gr3EZfnKJwyt
With the help of VCE4Plus’s marvelous brain dumps, you make sure your success in PCEP-30-02 certification exam with money back guarantee. VCE4Plus serves a huge network of its clientele with the state of the art and exam-oriented short-term study content that requires as little as a two-week time to get ready the entire PCEP-30-02 Certification syllabus.
Selecting VCE4Plus can 100% help you pass the exam. According to Python Institute PCEP-30-02 test subjects' changing, we will continue to update our training materials and will provide the latest exam content. VCE4Plus can provide a free 24-hour online customer service for you. If you do not pass Python Institute Certification PCEP-30-02 Exam, we will full refund to you.
New PCEP-30-02 Test Price, PCEP-30-02 Mock ExamAs for the PCEP-30-02 study materials themselves, they boost multiple functions to assist the learners to learn the study materials efficiently from different angles. For example, the function to stimulate the PCEP-30-02 exam can help the exam candidates be familiar with the atmosphere and the pace of the Real PCEP-30-02 Exam and avoid some unexpected problem occur such as the clients answer the questions in a slow speed and with a very anxious mood which is caused by the reason of lacking confidence.
Python Institute PCEP-30-02 Exam Syllabus Topics:
  • Control Flow: This section covers conditional statements such as if, if-else, if-elif, if-elif-else
  • Computer Programming Fundamentals: This section of the exam covers fundamental concepts such as interpreters, compilers, syntax, and semantics. It covers Python basics: keywords, instructions, indentation, comments in addition to Booleans, integers, floats, strings, and Variables, and naming conventions. Finally, it covers arithmetic, string, assignment, bitwise, Boolean, relational, and Input
  • output operations.
  • parameters, arguments, and scopes. It also covers Recursion, Exception hierarchy, Exception handling, etc.
  • Loops: while, for, range(), loops control, and nesting of loops.
Python Institute PCEP - Certified Entry-Level Python Programmer Sample Questions (Q31-Q36):NEW QUESTION # 31
Assuming that the phone_dir dictionary contains name:number pairs, arrange the code boxes to create a valid line of code which adds Oliver Twist's phone number (5551122333) to the directory.
phone_dir["Oliver Twist"] = ["5551122333"]
To correctly add Oliver Twist's phone number to the phone_dir dictionary, the code must follow this phone_dir["Oliver Twist"] = ["5551122333"] Now, let's match that with your code boxes and arrange them:
* phone_dir
* "Oliver Twist"
* "5551122333"
Final Order:phone_dir # [ # "Oliver Twist" # ] # = # [ # "5551122333" # ]
NEW QUESTION # 32
Python Is an example of which programming language category?
  • A. assembly
  • B. compiled
  • C. machine
  • D. interpreted
Python is an interpreted programming language, which means that the source code is translated into executable code by an interpreter at runtime, rather than by a compiler beforehand. Interpreted languages are more flexible and portable than compiled languages, but they are also slower and less efficient. Assembly and machine languages are low-level languages that are directly executed by the hardware, while compiled languages are high-level languages that are translated into machine code by a compiler before execution.
NEW QUESTION # 33
What happens when the user runs the following code?
  • A. The code enters an infinite loop.
  • B. The code outputs 1.
  • C. The code outputs 2.
  • D. The code outputs 3.
The code snippet that you have sent is calculating the value of a variable "total" based on the values in the range of 0 to 3. The code is as follows:
total = 0 for i in range(0, 3): if i % 2 == 0: total = total + 1 else: total = total + 2 print(total) The code starts with assigning the value 0 to the variable "total". Then, it enters a for loop that iterates over the values 0, 1, and 2 (the range function excludes the upper bound). Inside the loop, the code checks if the current value of "i" is even or odd using the modulo operator (%). If "i" is even, the code adds 1 to the value of
"total". If "i" is odd, the code adds 2 to the value of "total". The loop ends when "i" reaches 3, and the code prints the final value of "total" to the screen.
The code outputs 2 to the screen, because the value of "total" changes as follows:
When i = 0, total = 0 + 1 = 1
When i = 1, total = 1 + 2 = 3
When i = 2, total = 3 + 1 = 4
When i = 3, the loop ends and total = 4 is printed
Therefore, the correct answer is B. The code outputs 2.
NEW QUESTION # 34
Insert the code boxes in the correct positions in order to build a line of code which asks the user for an integer value and assigns it to the depth variable.
(Note: some code boxes will not be used.)
One possible way to insert the code boxes in the correct positions in order to build a line of code which asks the user for an integer value and assigns it to the depth variable is:
depth = int(input("Enter the immersion depth: "))
This line of code uses the input function to prompt the user for a string value, and then uses the int function to convert that string value into an integer number. The result is then assigned to the variable depth.
You can find more information about the input and int functions in Python in the following references:
* [Python input() Function]
* [Python int() Function]
NEW QUESTION # 35
What is the expected output of the following code?
  • A. False
  • B. 0
  • C. The code raises an unhandled exception.
  • D. ('Fermi ', '2021', 'False')
The code snippet that you have sent is defining and calling a function in Python. The code is as follows:
def runner(brand, model, year): return (brand, model, year)
print(runner("Fermi"))
The code starts with defining a function called "runner" with three parameters: "brand", "model", and "year".
The function returns a tuple with the values of the parameters. A tuple is a data type in Python that can store multiple values in an ordered and immutable way. A tuple is created by using parentheses and separating the values with commas. For example, (1, 2, 3) is a tuple with three values.
Then, the code calls the function "runner" with the value "Fermi" for the "brand" parameter and prints the result. However, the function expects three arguments, but only one is given. This will cause a TypeError exception, which is an error that occurs when a function or operation receives an argument that has the wrong type or number. The code does not handle the exception, and therefore it will terminate with an error message.
However, if the code had handled the exception, or if the function had used default values for the missing parameters, the expected output of the code would be ('Fermi ', '2021', 'False'). This is because the function returns a tuple with the values of the parameters, and the print function displays the tuple to the screen.
Therefore, the correct answer is D. ('Fermi ', '2021', 'False').
NEW QUESTION # 36
All of these prep formats pack numerous benefits necessary for optimal preparation. This PCEP - Certified Entry-Level Python Programmer (PCEP-30-02) practice material contains actual Python Institute PCEP - Certified Entry-Level Python Programmer Questions that invoke conceptual thinking. VCE4Plus provides you with free-of-cost demo versions of the product so that you may check the validity and actuality of the Python Institute PCEP-30-02 Dumps PDF before even buying it.
New PCEP-30-02 Test Price: https://www.vce4plus.com/Python-Institute/PCEP-30-02-valid-vce-dumps.html
BTW, DOWNLOAD part of VCE4Plus PCEP-30-02 dumps from Cloud Storage: https://drive.google.com/open?id=1iMxaV715nUCm7hv-orJ6gr3EZfnKJwyt
