100% Pass Quiz Fantastic Appian - ACD-301 - Appian Certified Lead Developer Brai
Posted at 3/7/2026 04:53:23
View179
Replies0
DOWNLOAD the newest ActualVCE ACD-301 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=196_AmX43I6VfVC5EGFkYmqg3unQB4fUs
The updated Appian ACD-301 exam questions are available in three different but high-in-demand formats. With the aid of practice questions for the Appian ACD-301 exam, you may now take the exam at home. You can understand the fundamental ideas behind the Appian ACD-301 Test Dumps using the goods. The Appian ACD-301 exam questions are affordable and updated, and you can use them without any guidance.
The modern world is becoming more and more competitive and if you are not ready for it then you will be not more valuable for job providers. Be smart in your career decision and enroll in Appian Certified Lead Developer ACD-301 Certification Exam and learn new and in demands skills. ActualVCE with Appian Certified Lead Developer ACD-301 exam questions and answers.
100% Pass 2026 High-quality Appian ACD-301: Appian Certified Lead Developer Brain ExamPracticing the ACD-301 exam questions, you actually learn to answer the real ACD-301 exam questions. Additionally, you also study time management to solve paper in the given time. Above all, you overcome the fear of the real exam and doing ACD-301 Exam Dumps, you gain enough confidence and examination ability that is necessary to pass the tough ACD-301 certifications.
Appian Certified Lead Developer Sample Questions (Q35-Q40):NEW QUESTION # 35
For each requirement, match the most appropriate approach to creating or utilizing plug-ins Each approach will be used once.
Note: To change your responses, you may deselect your response by clicking the blank space at the top of the selection list.
NEW QUESTION # 36
As part of your implementation workflow, users need to retrieve data stored in a third-party Oracle database on an interface. You need to design a way to query this information.
How should you set up this connection and query the data?
- A. Configure a Query Database node within the process model. Then, type in the connection information, as well as a SQL query to execute and return the data in process variables.
- B. Configure an expression-backed record type, calling an API to retrieve the data from the third-party database. Then, use a!queryRecordType to retrieve the data.
- C. In the Administration Console, configure the third-party database as a "New Data Source." Then, use a!queryEntity to retrieve the data.
- D. Configure a timed utility process that queries data from the third-party database daily, and stores it in the Appian business database. Then use a!queryEntity using the Appian data source to retrieve the data.
As an Appian Lead Developer, designing a solution to query data from a third-party Oracle database for display on an interface requires secure, efficient, and maintainable integration. The scenario focuses on real-time retrieval for users, so the design must leverage Appian's data connectivity features. Let's evaluate each option:
A . Configure a Query Database node within the process model. Then, type in the connection information, as well as a SQL query to execute and return the data in process variables:
The Query Database node (part of the Smart Services) allows direct SQL execution against a database, but it requires manual connection details (e.g., JDBC URL, credentials), which isn't scalable or secure for Production. Appian's documentation discourages using Query Database for ongoing integrations due to maintenance overhead, security risks (e.g., hardcoding credentials), and lack of governance. This is better for one-off tasks, not real-time interface queries, making it unsuitable.
B . Configure a timed utility process that queries data from the third-party database daily, and stores it in the Appian business database. Then use a!queryEntity using the Appian data source to retrieve the data:
This approach syncs data daily into Appian's business database (e.g., via a timer event and Query Database node), then queries it with a!queryEntity. While it works for stale data, it introduces latency (up to 24 hours) for users, which doesn't meet real-time needs on an interface. Appian's best practices recommend direct data source connections for up-to-date data, not periodic caching, unless latency is acceptable-making this inefficient here.
C . Configure an expression-backed record type, calling an API to retrieve the data from the third-party database. Then, use a!queryRecordType to retrieve the data:
Expression-backed record types use expressions (e.g., a!httpQuery()) to fetch data, but they're designed for external APIs, not direct database queries. The scenario specifies an Oracle database, not an API, so this requires building a custom REST service on the Oracle side, adding complexity and latency. Appian's documentation favors Data Sources for database queries over API calls when direct access is available, making this less optimal and over-engineered.
D . In the Administration Console, configure the third-party database as a "New Data Source." Then, use a!queryEntity to retrieve the data:
This is the best choice. In the Appian Administration Console, you can configure a JDBC Data Source for the Oracle database, providing connection details (e.g., URL, driver, credentials). This creates a secure, managed connection for querying via a!queryEntity, which is Appian's standard function for Data Store Entities. Users can then retrieve data on interfaces using expression-backed records or queries, ensuring real-time access with minimal latency. Appian's documentation recommends Data Sources for database integrations, offering scalability, security, and governance-perfect for this requirement.
Conclusion: Configuring the third-party database as a New Data Source and using a!queryEntity (D) is the recommended approach. It provides direct, real-time access to Oracle data for interface display, leveraging Appian's native data connectivity features and aligning with Lead Developer best practices for third-party database integration.
Appian Documentation: "Configuring Data Sources" (JDBC Connections and a!queryEntity).
Appian Lead Developer Certification: Data Integration Module (Database Query Design).
Appian Best Practices: "Retrieving External Data in Interfaces" (Data Source vs. API Approaches).
NEW QUESTION # 37
Your Agile Scrum project requires you to manage two teams, with three developers per team. Both teams are to work on the same application in parallel. How should the work be divided between the teams, avoiding issues caused by cross-dependency?
- A. Group epics and stories by technical difficulty, and allocate one team the more challenging stories.
- B. Allocate stories to each team based on the cumulative years of experience of the team members.
- C. Have each team choose the stories they would like to work on based on personal preference.
- D. Group epics and stories by feature, and allocate work between each team by feature.
In an Agile Scrum environment with two teams working on the same application in parallel, effective work division is critical to avoid cross-dependency, which can lead to delays, conflicts, and inefficiencies. Appian's Agile Development Best Practices emphasize team autonomy and minimizing dependencies to ensure smooth progress.
Option B (Group epics and stories by feature, and allocate work between each team by feature):
This is the recommended approach. By dividing the application's functionality into distinct features (e.g., Team 1 handles customer management, Team 2 handles campaign tracking), each team can work independently on a specific domain. This reduces cross-dependency because teams are not reliant on each other's deliverables within a sprint. Appian's guidance on multi-team projects suggests feature-based partitioning as a best practice, allowing teams to own their backlog items, design, and testing without frequent coordination. For example, Team 1 can develop and test customer-related interfaces while Team 2 works on campaign processes, merging their work during integration phases.
Option A (Group epics and stories by technical difficulty, and allocate one team the more challenging stories):
This creates an imbalance, potentially overloading one team and underutilizing the other, which can lead to morale issues and uneven progress. It also doesn't address cross-dependency, as challenging stories might still require input from both teams (e.g., shared data models), increasing coordination needs.
Option C (Allocate stories to each team based on the cumulative years of experience of the team members):
Experience-based allocation ignores the project's functional structure and can result in mismatched skills for specific features. It also risks dependencies if experienced team members are needed across teams, complicating parallel work.
Option D (Have each team choose the stories they would like to work on based on personal preference):
This lacks structure and could lead to overlap, duplication, or neglect of critical features. It increases the risk of cross-dependency as teams might select interdependent stories without coordination, undermining parallel development.
Feature-based division aligns with Scrum principles of self-organization and minimizes dependencies, making it the most effective strategy for this scenario.
NEW QUESTION # 38
What are two advantages of having High Availability (HA) for Appian Cloud applications?
- A. In the event of a system failure, your Appian instance will be restored and available to your users in less than 15 minutes, having lost no more than the last 1 minute worth of data.
- B. An Appian Cloud HA instance is composed of multiple active nodes running in different availability zones in different regions.
- C. A typical Appian Cloud HA instance is composed of two active nodes.
- D. Data and transactions are continuously replicated across the active nodes to achieve redundancy and avoid single points of failure.
Answer: A,D
High Availability (HA) in Appian Cloud is designed to ensure that applications remain operational and data integrity is maintained even in the face of hardware failures, network issues, or other disruptions. Appian's Cloud Architecture and HA documentation outline the benefits, focusing on redundancy, minimal downtime, and data protection. The question asks for two advantages, and the options must align with these core principles.
Option B (Data and transactions are continuously replicated across the active nodes to achieve redundancy and avoid single points of failure):
This is a key advantage of HA. Appian Cloud HA instances use multiple active nodes to replicate data and transactions in real-time across the cluster. This redundancy ensures that if one node fails, others can take over without data loss, eliminating single points of failure. This is a fundamental feature of Appian's HA setup, leveraging distributed architecture to enhance reliability, as detailed in the Appian Cloud High Availability Guide.
Option D (In the event of a system failure, your Appian instance will be restored and available to your users in less than 15 minutes, having lost no more than the last 1 minute worth of data):
This is another significant advantage. Appian Cloud HA is engineered to provide rapid recovery and minimal data loss. The Service Level Agreement (SLA) and HA documentation specify that in the case of a failure, the system failover is designed to complete within a short timeframe (typically under 15 minutes), with data loss limited to the last minute due to synchronous replication. This ensures business continuity and meets stringent uptime and data integrity requirements.
Option A (An Appian Cloud HA instance is composed of multiple active nodes running in different availability zones in different regions):
This is a description of the HA architecture rather than an advantage. While running nodes across different availability zones and regions enhances fault tolerance, the benefit is the resulting redundancy and availability, which are captured in Options B and D. This option is more about implementation than a direct user or operational advantage.
Option C (A typical Appian Cloud HA instance is composed of two active nodes):
This is a factual statement about the architecture but not an advantage. The number of nodes (typically two or more, depending on configuration) is a design detail, not a benefit. The advantage lies in what this setup enables (e.g., redundancy and quick recovery), as covered by B and D.
The two advantages-continuous replication for redundancy (B) and fast recovery with minimal data loss (D)-reflect the primary value propositions of Appian Cloud HA, ensuring both operational resilience and data integrity for users.
The two advantages of having High Availability (HA) for Appian Cloud applications are:
B . Data and transactions are continuously replicated across the active nodes to achieve redundancy and avoid single points of failure. This is an advantage of having HA, as it ensures that there is always a backup copy of data and transactions in case one of the nodes fails or becomes unavailable. This also improves data integrity and consistency across the nodes, as any changes made to one node are automatically propagated to the other node.
D). In the event of a system failure, your Appian instance will be restored and available to your users in less than 15 minutes, having lost no more than the last 1 minute worth of data. This is an advantage of having HA, as it guarantees a high level of service availability and reliability for your Appian instance. If one of the nodes fails or becomes unavailable, the other node will take over and continue to serve requests without any noticeable downtime or data loss for your users.
NEW QUESTION # 39
You are developing a case management application to manage support cases for a large set of sites. One of the tabs in this application s site Is a record grid of cases, along with Information about the site corresponding to that case. Users must be able to filter cases by priority level and status.
You decide to create a view as the source of your entity-backed record, which joins the separate case/site tables (as depicted in the following Image).
Which three column should be indexed?
- A. case_id
- B. priority
- C. name
- D. site_id
- E. modified_date
- F. status
Answer: B,D,F
Indexing columns can improve the performance of queries that use those columns in filters, joins, or order by clauses. In this case, the columns that should be indexed are site_id, status, and priority, because they are used for filtering or joining the tables. Site_id is used to join the case and site tables, so indexing it will speed up the join operation. Status and priority are used to filter the cases by the user's input, so indexing them will reduce the number of rows that need to be scanned. Name, modified_date, and case_id do not need to be indexed, because they are not used for filtering or joining. Name and modified_date are only used for displaying information in the record grid, and case_id is only used as a unique identifier for each record. Verified Appian Records Tutorial,Appian Best Practices As an Appian Lead Developer, optimizing a database view for an entity-backed record grid requires indexing columns frequently used in queries, particularly for filtering and joining. The scenario involves a record grid displaying cases with site information, filtered by "priority level" and "status," and joined via the site_id foreign key. The image shows two tables (site and case) with a relationship via site_id. Let's evaluate each column based on Appian's performance best practices and query patterns:
A . site_id:This is a primary key in the site table and a foreign key in the case table, used for joining the tables in the view. Indexing site_id in the case table (and ensuring it's indexed in site as a PK) optimizes JOIN operations, reducing query execution time for the record grid. Appian's documentation recommends indexing foreign keys in large datasets to improve query performance, especially for entity-backed records. This is critical for the join and must be included.
B . status:Users filter cases by "status" (a varchar column in the case table). Indexing status speeds up filtering queries (e.g., WHERE status = 'Open') in the record grid, particularly with large datasets. Appian emphasizes indexing columns used in WHERE clauses or filters to enhance performance, making this a key column for optimization. Since status is a common filter, it's essential.
C . name:This is a varchar column in the site table, likely used for display (e.g., site name in the grid). However, the scenario doesn't mention filtering or sorting by name, and it's not part of the join or required filters. Indexing name could improve searches if used, but it's not a priority given the focus on priority and status filters. Appian advises indexing only frequently queried or filtered columns to avoid unnecessary overhead, so this isn't necessary here.
D . modified_date:This is a date column in the case table, tracking when cases were last updated. While useful for sorting or historical queries, the scenario doesn't specify filtering or sorting by modified_date in the record grid. Indexing it could help if used, but it's not critical for the current requirements. Appian's performance guidelines prioritize indexing columns in active filters, making this lower priority than site_id, status, and priority.
E . priority:Users filter cases by "priority level" (a varchar column in the case table). Indexing priority optimizes filtering queries (e.g., WHERE priority = 'High') in the record grid, similar to status. Appian's documentation highlights indexing columns used in WHERE clauses for entity-backed records, especially with large datasets. Since priority is a specified filter, it's essential to include.
F . case_id:This is the primary key in the case table, already indexed by default (as PKs are automatically indexed in most databases). Indexing it again is redundant and unnecessary, as Appian's Data Store configuration relies on PKs for unique identification but doesn't require additional indexing for performance in this context. The focus is on join and filter columns, not the PK itself.
Conclusion: The three columns to index are A (site_id), B (status), and E (priority). These optimize the JOIN (site_id) and filter performance (status, priority) for the record grid, aligning with Appian's recommendations for entity-backed records and large datasets. Indexing these columns ensures efficient querying for user filters, critical for the application's performance.
Appian Documentation: "Performance Best Practices for Data Stores" (Indexing Strategies).
Appian Lead Developer Certification: Data Management Module (Optimizing Entity-Backed Records).
Appian Best Practices: "Working with Large Data Volumes" (Indexing for Query Performance).
NEW QUESTION # 40
More about ACD-301 Exams Dumps: If you want to know more about our test preparations materials, you should explore the related ACD-301 exam Page. You may go over our ACD-301 brain dumps product formats and choose the one that suits you best. You can also avail of the free demo so that you will have an idea how convenient and effective our ACD-301 exam dumps are for ACD-301 Certification. Rather we offer a wide selection of braindumps for all other exams under the ACD-301 certification. This ensures that you will cover more topics thus increasing your chances of success. With the multiple learning modes in ACD-301 practice exam software, you will surely find your pace and find your way to success.
ACD-301 Exam Experience: https://www.actualvce.com/Appian/ACD-301-valid-vce-dumps.html
An international ACD-301 certificate means that you can get more job opportunities, Appian ACD-301 Brain Exam My Product had before a lot of questions but their number has decreased a lot after this update, Appian ACD-301 Brain Exam So many bosses treat the certificates as extensions of your working ability, Appian ACD-301 Brain Exam It works based on browser.
Upon tapping on the Reply with Message button, five additional command buttons ACD-301 are displayed under the Can't talk right now, The basics are similar, but the cloud application lacks many of PowerPoint's advanced features.
100% Pass Appian - ACD-301 - Perfect Appian Certified Lead Developer Brain ExamAn international ACD-301 certificate means that you can get more job opportunities, My Product had before a lot of questions but their number has decreased a lot after this update.
So many bosses treat the certificates as extensions of your working ability, It works based ACD-301 Brain Exam on browser, We are committed to let all of the candidates pass Appian exam and gain the IT certification successfully, but if you unfortunately failed the exam even with thehelp of ACD-301 Exam Questions: Appian Certified Lead Developer, we will promise a full refund for you, but you need to show your report card to us, and as soon as we confirm it we will give you a full refund, so just do not worry about your money of buying the ACD-301 study materials.
- Free 1 year Appian ACD-301 Dumps Updates: a Full Refund Guarantee By [url]www.practicevce.com 🔂 The page for free download of ✔ ACD-301 ️✔️ on ✔ www.practicevce.com ️✔️ will open immediately 🏧ACD-301 Reliable Braindumps Book[/url]
- Free 1 year Appian ACD-301 Dumps Updates: a Full Refund Guarantee By Pdfvce 🐾 Download ▛ ACD-301 ▟ for free by simply searching on ⮆ [url]www.pdfvce.com ⮄ 👟Valid ACD-301 Exam Camp Pdf[/url]
- New ACD-301 Exam Price 🛺 ACD-301 Detail Explanation 🤖 Valid ACD-301 Exam Camp Pdf 🥶 Search for [ ACD-301 ] and download exam materials for free through [url]www.exam4labs.com 🐪ACD-301 Reliable Test Blueprint[/url]
- High-quality ACD-301 Brain Exam Offer You The Best Exam Experience | Appian Appian Certified Lead Developer 🍻 Open [url]www.pdfvce.com enter ▷ ACD-301 ◁ and obtain a free download 💁ACD-301 Torrent[/url]
- ACD-301 Reliable Test Blueprint 🤹 ACD-301 Test Question 🔏 New ACD-301 Test Online 🍛 Download ⮆ ACD-301 ⮄ for free by simply searching on [url]www.torrentvce.com ⛵Exam ACD-301 Question[/url]
- Professional ACD-301 Brain Exam - Perfect ACD-301 Exam Experience: Appian Certified Lead Developer 🐉 [ [url]www.pdfvce.com ] is best website to obtain ➤ ACD-301 ⮘ for free download 🤎ACD-301 Reliable Exam Pattern[/url]
- 100% Pass Appian ACD-301 - First-grade Appian Certified Lead Developer Brain Exam 🌁 Download ACD-301 for free by simply entering ⏩ [url]www.practicevce.com ⏪ website 🌸ACD-301 Reliable Exam Pattern[/url]
- New ACD-301 Exam Price 🐭 New ACD-301 Practice Questions 📱 ACD-301 Reliable Test Blueprint 🥻 ▶ [url]www.pdfvce.com ◀ is best website to obtain ▛ ACD-301 ▟ for free download 😹ACD-301 Exam Preparation[/url]
- ACD-301 Reliable Test Blueprint 🦡 ACD-301 Minimum Pass Score 🍌 New ACD-301 Practice Questions 🕡 The page for free download of { ACD-301 } on ➽ [url]www.examcollectionpass.com 🢪 will open immediately 🎊New ACD-301 Practice Questions[/url]
- Smashing ACD-301 Guide Materials: Appian Certified Lead Developer supply you high-efficient Exam Brain Dumps - Pdfvce 😭 Simply search for ✔ ACD-301 ️✔️ for free download on ▷ [url]www.pdfvce.com ◁ 🎐New ACD-301 Practice Questions[/url]
- Free 1 year Appian ACD-301 Dumps Updates: a Full Refund Guarantee By [url]www.prep4away.com 👒 Search for ACD-301 and download it for free immediately on ⏩ www.prep4away.com ⏪ 🌀ACD-301 Exam Simulator Fee[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, 911marketing.tech, excelelearn.com, urstudio.sec.sg, blogfreely.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that ActualVCE ACD-301 dumps now are free: https://drive.google.com/open?id=196_AmX43I6VfVC5EGFkYmqg3unQB4fUs
