[General] Cisco 350-801 Valid Exam Answers - 350-801 Certification Practice
94
【General】 Cisco 350-801 Valid Exam Answers - 350-801 Certification Practice
Posted at 2/14/2026 06:45:34      View:138 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of UpdateDumps 350-801 dumps from Cloud Storage: https://drive.google.com/open?id=1CX9T9x96urjcQEu2NM_C9x3qXNi6HQNs
Our website always checks the update of 350-801 test questions to ensure the accuracy of our study materials and keep the most up-to-dated exam requirements. There are 350-801 free demo in our exam page for your reference and one-year free update are waiting for you. Valid 350-801 Real Dumps will the guarantee of your success and make you more confident in your career.
Cisco 350-801 Exam is a comprehensive test that covers a wide range of topics related to Cisco Collaboration Core Technologies. 350-801 exam includes questions on topics such as Cisco Unified Communications Manager (CUCM), Cisco Unity Connection, Cisco Unified Contact Center Express (UCCX), Cisco Meeting Server, and Cisco Expressway. 350-801 exam also covers other critical topics, such as network infrastructure, security, and troubleshooting.
Understanding functional and technical aspects of Implementing Cisco Collaboration Core Technologies (350-801 CLCOR) Infrastructure and designThe following will be discussed in CISCO 350-801 exam dumps:
  • DNS (A/AAA, SRV, Reverse Pointer Record (PTR))
  • Sizing
  • Describe the different codecs and how they are used to transform analogue voice into digital streams
  • LDAP integration on Cisco Unified Communications Manager
  • NTP
  • LDAP
  • Configure calling privileges in Cisco Unified Communications Manager
  • Implement toll fraud prevention
  • Licensing (Smart, Flex)
  • SNMP
  • Disaster recovery
  • Implement Cisco Unified Communications Manager provisioning features
  • Describe a dial plan, and explain call routing in Cisco Unified Communications Manager
  • Troubleshoot these network components in a Cisco Collaboration solution
  • Dial plan
  • Configure these network components to support Cisco Collaboration solutions
  • Implement Public Switched Telephone Network (PSTN) access using MGCP gateways
  • Describe the key design elements of the following, pertaining to the Cisco Collaboration architecture as described in the SRND/PA
  • TFTP
  • Bandwidth
  • Security (certificates, SRTP, TLS)
  • Implement and troubleshoot media resources in Cisco Unified Communications Manager
350-801 Valid Exam Answers & Free PDF 2026 Cisco Implementing and Operating Cisco Collaboration Core Technologies Realistic Certification PracticeThe paper materials students buy on the market are often not able to reuse. After all the exercises have been done once, if you want to do it again you will need to buy it again. But with 350-801 test question, you will not have this problem. All customers who purchased 350-801 study tool can use the learning materials without restrictions, and there is no case of duplicate charges. For the PDF version of 350-801 test question, you can print multiple times, practice multiple times, and repeatedly reinforce your unfamiliar knowledge. For the online version, unlike other materials that limit one person online, 350-801 learning dumps does not limit the number of concurrent users and the number of online users. You can practice anytime, anywhere, practice repeatedly, practice with others, and even purchase together with others350-801 learning dumps make every effort to help you save money and effort, so that you can pass the exam with the least cost.
Cisco 350-801 exam is a combination of both theoretical and practical assessments that are aimed at evaluating the candidate's proficiency in implementing and operating Cisco collaboration core technologies. 350-801 exam consists of multiple-choice questions, simulations, and hands-on lab exercises that are designed to test the candidate's technical skills and problem-solving abilities. Successful completion of 350-801 Exam demonstrates a candidate's ability to design, implement, and troubleshoot complex Cisco collaboration solutions, making them a valuable asset to any organization that uses Cisco collaboration technologies.
Cisco Implementing and Operating Cisco Collaboration Core Technologies Sample Questions (Q383-Q388):NEW QUESTION # 383
Location-based call admission control is used in Cisco UCM to control the amount of bandwidth allowed between predefined locations. What must be considered when calculating the number of calls that can be made?
  • A. A limit of 900 kb is the total amount of bandwidth used for the sum of calls. The use of compression does not impact the amount of calls because only the codec definition is considered when calculating the CAC in Cisco UCM.
  • B. A limit of 900 kb Is the total amount of bandwidth used for the sum of calls of the defined codec including headers and media traffic.
  • C. A limit of 900 kb is the total amount of actual used RTP traffic so the oversubscription can be done for multiple calls adding Its maximum RTP stream requirements.
  • D. A limit of 900 kb is the total amount of bandwidth used for the sum of the media and signaling in the calls. The system allows for an actual of 20% overhead of IP packet headers. This is to compare the use of ISDN lines with no IP overhead.
NEW QUESTION # 384
What dialed number match this cisco UCM route pattern?
1[23]XX
  • A. 1230 through 1239 only
  • B. 1200 through 1300 only
  • C. 12300 through 12399 only
  • D. 1200 through 1399 only
NEW QUESTION # 385
A collaboration engineer is configuring the QoS trust boundary for Cisco UCM voice and video conferencing.
Which two trust boundary configurations are valid? (choose two)
  • A. QoS trust boundaries include all the devices directly attached to the access switch ports
  • B. QoS trust boundaries exclude Jabber softphone running on a PC
  • C. QoS trust boundaries can be extended to Jabber running on a PC
  • D. QoS trust boundaries can be extended to voice and video devices exclusively
  • E. QoS trust boundaries can be extended to voice and video devices if the connected PCs are included
Answer: B,E
NEW QUESTION # 386
Which DHCP option must be set up for new phones to obtain the TFTP server IP address?
  • A. Option 66
  • B. Option 120
  • C. Option 15
  • D. Option 6
https://blog.router-switch.com/2 ... 150-dhcp-option-66/
NEW QUESTION # 387
In an eleven-class queueing model following Realtime. Best effort, and scavenger queuing rules.
What recommended percentage of bandwidth must be allocated for interactive video?
  • A. 20%
  • B. 12%
  • C. 15%
  • D. 10%
NEW QUESTION # 388
350-801 Certification Practice: https://www.updatedumps.com/Cisco/350-801-updated-exam-dumps.html
P.S. Free & New 350-801 dumps are available on Google Drive shared by UpdateDumps: https://drive.google.com/open?id=1CX9T9x96urjcQEu2NM_C9x3qXNi6HQNs
Posted at 3/10/2026 23:40:28        Only Author  2#
PassTIP는 유일하게 여러분이 원하는Broadcom인증250-589시험관련자료를 해결해드릴 수 잇는 사이트입니다. 여러분이 다른 사이트에서도 관련덤프자료를 보셨을경우 페이지 아래를 보면 자료출처는 당연히 PassTIP 일 것입니다. PassTIP의 자료만의 제일 전면적이고 또 최신 업데이트일 것입니다.
