[Hardware] HP HPE6-A78 Reliable Exam Answers | Reliable HPE6-A78 Cram Materials
【Hardware】 HP HPE6-A78 Reliable Exam Answers | Reliable HPE6-A78 Cram Materials
Posted at 1/16/2026 10:23:04      View:111 | Replies:4        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Dumpleader HPE6-A78 dumps from Cloud Storage: https://drive.google.com/open?id=1bM8tNoq0i0pkB2jPDu8fFMj0cBC3I7L4
In order to meet all demands of all customers, our company has employed a lot of excellent experts and professors in the field to design and compile the HPE6-A78 study materials with a high quality. It has been a generally accepted fact that the HPE6-A78 Study Materials from our company are more useful and helpful for all people who want to pass exam and gain the related exam. We believe this resulted from our constant practice, hard work and our strong team spirit.
Working in IT field, you definitely want to prove your ability by passing IT certification test. Moreover, the colleagues and the friends with IT certificate have been growing. In this case, if you have none, you will not be able to catch up with the others. For example like HP HPE6-A78 Certification Exam, it is a very valuable examination, which must help you realize your wishes.
Latest HPE6-A78 Study Question Give You 100% Valid Exam Reference GuideSometimes a small step is possible to be a big step in life. HPE6-A78 exam seems just a small exam, but to get the HPE6-A78 certification exam is to be reckoned in your career. Such an international certification is recognition of your IT skills. In addition, except HPE6-A78, many other certification exams are also useful. The latest information of these tests can be found in our Dumpleader.
HP Aruba Certified Network Security Associate Exam Sample Questions (Q99-Q104):NEW QUESTION # 99
You have an Aruba Mobility Controller (MC) that is locked in a closet. What is another step that Aruba recommends to protect the MC from unauthorized access?
  • A. Set the local admin password to a long random value that is unknown or locked up securely.
  • B. Use local authentication rather than external authentication to authenticate admins.
  • C. Disable local authentication of administrators entirely.
  • D. Change the password recovery password.
Protecting an Aruba Mobility Controller from unauthorized access involves several layers of security. One recommendation is to change the password recovery password, which is a special type of password used to recover access to the device in the event the admin password is lost. Changing this to something complex and unique adds an additional layer of security in the event the physical security of the device is compromised.
NEW QUESTION # 100
What is a guideline for deploying Aruba ClearPass Device Insight?
  • A. Deploy a Device Insight Collector at every site in the corporate WAN to reduce the impact on WAN links.
  • B. For companies with multiple sites, deploy a pair of Device Insight Collectors at the HQ or the central data center.
  • C. Configure remote mirroring on access layer Aruba switches, using Device Insight Analyzer as the destination IP.
  • D. Make sure that Aruba devices trust the root CA certificate for the ClearPass Device Insight Analyzer's HTTPS certificate.
For deploying Aruba ClearPass Device Insight effectively, especially in environments with multiple sites, it is recommended to deploy a pair of Device Insight Collectors at the headquarters or the central data center.
This deployment strategy helps in centralizing the data collection and analysis, which simplifies management and enhances performance by reducing the data load on the WAN links connecting different sites.
Centralizing the collectors at a major site or data center allows for better scalability and reliability of the network management system. This configuration also aids in achieving a more consistent and comprehensive monitoring and analysis of the devices across the network, ensuring that the security and management policies are uniformly applied. This recommendation is based on best practices for network architecture design, particularly those discussed in Aruba's deployment guides and network management strategies.
NEW QUESTION # 101
An ArubaOS-CX switch enforces 802.1X on a port. No fan-through options or port-access roles are configured on the port The 802 1X supplicant on a connected client has not yet completed authentication Which type of traffic does the authenticator accept from the client?
  • A. DHCP, DNS and RADIUS only
  • B. RADIUS only
  • C. DHCP, DNS, and EAP only
  • D. EAP only
NEW QUESTION # 102
You are configuring ArubaOS-CX switches to tunnel client traffic to an Aruba Mobility Controller (MC).
What should you do to enhance security for control channel communications between the switches and the MC?
  • A. Configure a long, random PAPI security key that matches on the switches and the MC.
  • B. Create one UBT zone for control traffic and a second UBT zone for clients.
  • C. Make sure that the UBT client vlan is assigned to the interface on which the switches reach the MC and only that interface.
  • D. install certificates on the switches, and make sure that CPsec is enabled on the MC
When configuring ArubaOS-CX switches to tunnel client traffic to an Aruba Mobility Controller (MC), securing the control channel communications is crucial to prevent unauthorized access and ensure data integrity. Option B is the correct answer as it involves configuring a long, random PAPI security key that matches on both the switches and the MC. The PAPI (Policy Access Point Interface) protocol is used for secure communication between Aruba devices, and employing a robust, randomized security key significantly enhances the security of the control channel. This setup prevents potential interception or manipulation of the control traffic between the devices.
ArubaOS-CX Security Configuration Guide
Aruba Networks Official Documentation
NEW QUESTION # 103
What is a difference between passive and active endpoint classification?
  • A. Passive classification is only suitable for profiling endpoints in small business environments, while enterprises should use active classification exclusively.
  • B. Passive classification classifies endpoints based on entries in dictionaries, while active classification uses admin-defined rules to classify endpoints.
  • C. Passive classification analyzes traffic that endpoints send as part of their normal functions; active classification involves sending requests to endpoints.
  • D. Passive classification refers exclusively to MAC OUI-based classification, while active classification refers to any other classification method.
HPE Aruba Networking ClearPass Policy Manager (CPPM) uses endpoint classification (profiling) to identify and categorize devices on the network, enabling policy enforcement based on device type, OS, or other attributes. CPPM supports two primary profiling methods: passive and active classification.
Passive Classification: This method involves observing network traffic that endpoints send as part of their normal operation, without CPPM sending any requests to the device. Examples include DHCP fingerprinting (analyzing DHCP Option 55), HTTP User-Agent string analysis, and TCP fingerprinting (analyzing TTL and window size). Passive classification is non-intrusive and does not generate additional network traffic.
Active Classification: This method involves CPPM sending requests to the endpoint to gather information. Examples include SNMP scans (to query device details), WMI scans (for Windows devices), and SSH scans (to gather system information). Active classification is more intrusive and may require credentials or network access to the device.
Option A, "assive classification refers exclusively to MAC OUI-based classification, while active classification refers to any other classification method," is incorrect. Passive classification includes more than just MAC OUI-based classification (e.g., DHCP fingerprinting, TCP fingerprinting). MAC OUI (Organizationally Unique Identifier) analysis is one passive method, but not the only one. Active classification specifically involves sending requests, not just "any other method." Option B, "assive classification classifies endpoints based on entries in dictionaries, while active classification uses admin-defined rules to classify endpoints," is incorrect. Both passive and active classification use CPPM's fingerprint database (not "dictionaries") to match device attributes. Admin-defined rules are used for policy enforcement, not classification, and apply to both methods.
Option C, "assive classification is only suitable for profiling endpoints in small business environments, while enterprises should use active classification exclusively," is incorrect. Passive classification is widely used in enterprises because it is non-intrusive and scalable. Active classification is often used in conjunction with passive methods to gather more detailed information, but enterprises do not use it exclusively.
Option D, "assive classification analyzes traffic that endpoints send as part of their normal functions; active classification involves sending requests to endpoints," is correct. This accurately describes the fundamental difference between the two methods: passive classification observes existing traffic, while active classification actively queries the device.
The HPE Aruba Networking ClearPass Policy Manager 6.11 User Guide states:
"assive classification analyzes traffic that endpoints send as part of their normal functions, such as DHCP requests, HTTP traffic, or TCP packets, without ClearPass sending any requests to the device. Examples include DHCP fingerprinting and TCP fingerprinting. Active classification involves ClearPass sending requests to the endpoint to gather information, such as SNMP scans, WMI scans, or SSH scans, which may require credentials or network access." (Page 246, Passive vs. Active Profiling Section) Additionally, the ClearPass Device Insight Data Sheet notes:
"assive classification observes network traffic generated by endpoints during normal operation, such as DHCP or HTTP traffic, to identify devices without generating additional traffic. Active classification, in contrast, sends requests to endpoints (e.g., SNMP or WMI scans) to gather detailed information, which can be more intrusive but provides deeper insights." (Page 3, Profiling Methods Section)
HPE Aruba Networking ClearPass Policy Manager 6.11 User Guide, Passive vs. Active Profiling Section, Page 246.
ClearPass Device Insight Data Sheet, Profiling Methods Section, Page 3.
NEW QUESTION # 104
If you buy HPE6-A78 study materials, you will get more than just a question bank. You will also get our meticulous after-sales service. The purpose of the HPE6-A78 study materials’ team is not to sell the materials, but to allow all customers who have purchased HPE6-A78 study materials to pass the exam smoothly. The trust and praise of the customers is what we most want. We will accompany you throughout the review process from the moment you buy HPE6-A78 Study Materials. We will provide you with 24 hours of free online services.
Reliable HPE6-A78 Cram Materials: https://www.dumpleader.com/HPE6-A78_exam.html
So with our HPE6-A78 exam questions, not only you can pass the exam with ease with 100% pass guarantee, but also you can learn the most professional and specilized knowledge in this field, HP HPE6-A78 Reliable Exam Answers Besides, we offer considerate aftersales services 24/7 and our staff treasures all your constructive opinions to be better of our services in all respects, Here our HPE6-A78 exam braindumps are tailor-designed for you.
Strengthening content protection through dynamic watermarking and Reliable HPE6-A78 Cram Materials dynamic obfuscation, This is a good thing, as some numbering systems such as asterisks) are designed to restart every page.
Pass HP HPE6-A78 Exam and Get Certified with EaseSo with our HPE6-A78 exam questions, not only you can pass the exam with ease with 100% pass guarantee, but also you can learn the most professional and specilized knowledge in this field!
Besides, we offer considerate aftersales services 24/7 and our staff treasures all your constructive opinions to be better of our services in all respects, Here our HPE6-A78 Exam Braindumps are tailor-designed for you.
Our HPE6-A78 test prep is compiled elaborately and will help the client a lot, It is universally acknowledged that everyone would like to receive the goods he orshe bought as soon as possible after payment, especially HPE6-A78 for those who are preparing for the exam, just like the old saying goes "Wasting time is robbing oneself".
BONUS!!! Download part of Dumpleader HPE6-A78 dumps for free: https://drive.google.com/open?id=1bM8tNoq0i0pkB2jPDu8fFMj0cBC3I7L4
Posted at 1/18/2026 23:59:15        Only Author  2#
What a great article, I’m so thankful for your sharing. Exam Arch-301 details offers great content that I hope helps you, and it's entirely free.
Posted at 1/30/2026 00:58:22        Only Author  3#
SAP인증 C-P2WBW-2505시험을 패스하여 자격증을 취득하는게 꿈이라구요? ITDumpsKR에서 고객님의SAP인증 C-P2WBW-2505시험패스꿈을 이루어지게 지켜드립니다. ITDumpsKR의 SAP인증 C-P2WBW-2505덤프는 가장 최신시험에 대비하여 만들어진 공부자료로서 시험패스는 한방에 끝내줍니다.
Posted at 6 day before        Only Author  4#
This article is absolutely extraordinary, thank you for your share! I’m sharing Reliable ICF-ACC exam pdf resources for free. Wishing you all the best!
Posted at 4 day before        Only Author  5#
我們Fast2test網站完全具備資源和NBCC的NCE-ABE考試的問題,它也包含了 NBCC的NCE-ABE考試的實踐檢驗,測試轉儲,它可以幫助候選人為準備考試、通過考試的,為你的訓練提出了許多方便,你可以下載部分試用考題及答案作為嘗試,Fast2test NBCC的NCE-ABE考試時間內沒有絕對的方式來傳遞,Fast2test提供真實、全面的考試試題及答案,隨著我們獨家線上的NBCC的NCE-ABE考試培訓資料,你會很容易的通過NBCC的NCE-ABE考試,本站保證通過率100%
