[General] VMware New 2V0-21.23 Exam Testking Exam Pass Certify | 2V0-21.23: VMware vSphere
137
【General】 VMware New 2V0-21.23 Exam Testking Exam Pass Certify | 2V0-21.23: VMware vSphere
Posted at 1/11/2026 11:05:02      View:122 | Replies:2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ActualtestPDF 2V0-21.23 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1fo9PYWjKHT1ZKiXQG2Z8fI8BUL3mgzjP
Passing the 2V0-21.23 exam requires many abilities of you: personal ability, efficient practice materials, as well as a small touch of luck. So your personal effort is brilliant but insufficient to pass exam, and our 2V0-21.23 exam materials can facilitate the process smoothly and successfully. Our 2V0-21.23 Study Dumps are suitable for you whichever level you are in right now. Whether you are in entry-level position or experienced exam candidates who have tried the exam before, this is the perfect chance to give a shot.
VMware 2V0-21.23 Exam covers a wide range of topics related to vSphere 8.x, including installation and configuration, managing vSphere resources, storage and networking, virtual machines, security, and troubleshooting. Successful candidates will have a deep understanding of vSphere 8.x and the ability to apply that knowledge in real-world scenarios.
High Pass-Rate VMware New 2V0-21.23 Exam Testking & Trustable ActualtestPDF - Leading Provider in Qualification ExamsBecause they are immensely useful and help you gain success in a 2V0-21.23 certification exam. More than ever, the professionals are now facing a highly competitive world to get their talent recognized enhancing their positions in their work environment. Such a milieu demands them to enrich their candidature more seriously. So the professionals work hard to maintain their quality and never fail in doing so. ActualtestPDF 2V0-21.23 Certification exams are the best option for any ambitious and ardent professional to make his continuation in his area of work intact.
VMware vSphere 8.x Professional Sample Questions (Q46-Q51):NEW QUESTION # 46
An administrator is working with VMware Support and Is asked to provide log bundles for the ESXI hosts in an environment.
h three options Joes the administrator have? (Choose three.)
  • A. Generate a combined log bundle for all ESXI hosts using the vSphere Client.
  • B. Generate a combined log bundle for all ESXI hosts using the vCenter Management Interface.
  • C. Generate a combined log bundle for all ESXi hosts using the vSphere Host Client.
  • D. Generate a separate log bundle for each ESXI host using the vSphere Host Client.
  • E. Generate a separate log bundle for each ESXI host using the vCenter Management Interface.
  • F. Generate a separate log bundle for each ESXI host using the vSphere Client.
Answer: A,D,F
Option B, C and D are correct because they are valid methods to generate log bundles for individual or multiple ESXi hosts using different interfaces. Option A and E are incorrect because they are not possible options to generate log bundles for all ESXi hosts using the vCenter Management Interface. Option F is incorrect because it is not possible to generate a combined log bundle for all ESXi hosts using the vSphere Host Client. Reference: https://docs.vmware.com/en/VMwar ... 7-8CDBE8D6D988.html
NEW QUESTION # 47
An administrator notices a performance issue in VMvvare vCenter To try and understand more about the performance issue, the administrator needs to gather more information about the vCenter database to eliminate a potential disk space issue.
Which two tools can the administrator use? (Choose two.)
  • A. esxtop
  • B. Perfmon
  • C. vSphere Client
  • D. df
  • E. vCenter Management Interface (VAMI)
Answer: D,E
https://kb.vmware.com/s/article/76563
NEW QUESTION # 48
Which feature would allow for the non-disruptive migration of a virtual machine between two clusters in a single VMware vCenter instance?
  • A. Cross vCenter Migration
  • B. vSphere Fault Tolerance
  • C. vSphere vMotion
  • D. vSphere Storage vMotion
vSphere vMotion allows for the non-disruptive migration of a virtual machine between two clusters in a single vCenter instance, as long as there is shared storage and network connectivity between the clusters.
https://docs.vmware.com/en/VMwar ... /GUID-3B41119A-1276 vMotion is used to move the VM to a different cluster within the same vCenter. This only works if both clusters share the same storage. If they don't you also need to perform a Storage vMotion. Cross vCenter Migration is only used to migrate to a different vCenter.
NEW QUESTION # 49
An administrator is tasked with looking into the disaster recovery (DR) options for a software-defined data center (SDDC).
The following requirements must be met:
*All virtual machines (VMs) must be protected to a secondary site.
*The source VMs must remain online until the failover.
*When failing over to the secondary site, application downtime is allowed
*The DR failover must be managed from the vSphere Client.
*Costs must remain as low as possible.
How can the administrator accomplish this task?
  • A. Configure VMware Cloud Disaster Recovery (VCDR) and combine it with array-based storage replication
  • B. Configure VMware a Site Recovery Manager and combine it with vSphere Replication.
  • C. Configure VMware Site Recovery Manager and combine it with array-based storage replication.
  • D. Configure a subscribed content library on the secondary site.
https://blogs.vmware.com/virtual ... -technicaloverview/
NEW QUESTION # 50
An administrator is tasked with configuring vSphere Trust Authority. The administrator has completed the following steps:
* Set up the workstation
* Enabled the Trust Authority Administrator
* Enabled the Trust Authority State
* Collected information about the ESXi hosts and vCenter to be trusted
Which step does the administrator need to complete next?
  • A. Import the Trusted Cluster information to the Trusted Hosts
  • B. Import the Trusted Host information to the Trust Authority Cluster
  • C. Import the Trusted Host information to the Trusted Cluster
  • D. Create the Key Provider on the Trusted Cluster
https://docs.vmware.com/en/VMwar ... ages/GUID-D205B3C1-
https://docs.vmware.com/en/VMwar ... AD45-4B0A-8FB0-7A1D
NEW QUESTION # 51
ActualtestPDF's VMware 2V0-21.23 Exam Training materials is no other sites in the world can match. Of course, this is not only the problem of quality, it goes without saying that our quality is certainly the best. More important is that ActualtestPDF's exam training materials is applicable to all the IT exam. So the website of ActualtestPDF can get the attention of a lot of candidates. They believe and rely on us. It is also embodied the strength of our ActualtestPDF site. The strength of ActualtestPDF is embodied in it. Our exam training materials could make you not help recommend to your friends after you buy it. Because it's really a great help to you.
2V0-21.23 Valid Exam Sample: https://www.actualtestpdf.com/VMware/2V0-21.23-practice-exam-dumps.html
2026 Latest ActualtestPDF 2V0-21.23 PDF Dumps and 2V0-21.23 Exam Engine Free Share: https://drive.google.com/open?id=1fo9PYWjKHT1ZKiXQG2Z8fI8BUL3mgzjP
Posted at 1/11/2026 17:50:20        Only Author  2#
Thank you for your article; it really opened my eyes. 156-836 test pdf provides free, rich resources aimed at helping you achieve your goals.
Posted at before yesterday 11:41        Only Author  3#
Thank you for sharing this incredible article, it’s truly breathtaking! Enhance your IT expertise and download Latest exam camp Sales-Con-201 questions for free. Good luck to all!
