[General] HPE7-A01 Exam Bible | HPE7-A01 Reliable Exam Pass4sure
26
General HPE7-A01 Exam Bible | HPE7-A01 Reliable Exam Pass4sure
Posted at 5/16/2026 14:34:09      View75 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that DumpsMaterials HPE7-A01 dumps now are free: https://drive.google.com/open?id=1kZii70d1-95fpNiW9WlfnYQMvpZe6XQV
First and foremost, in order to cater to the different needs of people from different countries in the international market, we have prepared three kinds of versions of our HPE7-A01 learning questions in this website. Second, we can assure you that you will get the latest version of our HPE7-A01 training materials for free from our company in the whole year after payment on HPE7-A01 practice materials. Last but not least, we will provide the most considerate after sale service for our customers in twenty four hours a day seven days a week on our HPE7-A01 exam questions.
HP HPE7-A01 certification exam is a vendor-neutral certification that is recognized globally. It is designed to test the abilities of IT professionals in terms of the deployment, management, and troubleshooting of Aruba's wireless network solutions. Aruba Certified Campus Access Professional Exam certification exam is comprised of 60 multiple-choice questions, and candidates have 90 minutes to complete the exam. Aruba Certified Campus Access Professional Exam certification is valid for three years, and candidates must recertify to maintain their certification status. Overall, the HPE7-A01 Certification Exam is an excellent choice for IT professionals who want to prove their proficiency in Aruba's wireless networking solutions and enhance their career prospects in the IT industry.
HPE7-A01 Reliable Exam Pass4sure - HPE7-A01 Exam Quick PrepThere are many advantages of our HPE7-A01 pdf torrent: latest real questions, accurate answers, instantly download and high passing rate. You can totally trust our HPE7-A01 practice test because all questions are created based on the requirements of the certification center. Latest HPE7-A01 Test Questions are verified and tested several times by our colleagues to ensure the high pass rate of our HPE7-A01 study guide.
HP HPE7-A01 exam is a challenging and comprehensive exam that requires a solid understanding of Aruba WLANs and related technologies. To prepare for HPE7-A01 exam, candidates can take advantage of various resources, including online courses, study guides, and practice exams. With the right preparation and dedication, IT professionals can successfully pass the HP HPE7-A01 Exam and earn the Aruba Certified Campus Access Professional certification.
HP Aruba Certified Campus Access Professional Exam Sample Questions (Q94-Q99):NEW QUESTION # 94
Refer to Exhibit. With Access-1, what needs to be identically configured With MSTP to load- balance VLANS?
  • A. spanning-tree Cist mapping
  • B. Spanning-tree instance vlan mapppjng
  • C. Spanning-tree bpdu-guard setting
  • D. Spanning-tree root-guard setting
To load-balance VLANs with MSTP, you need to configure the same VLAN-to-instance mapping on all switches in the same MST region. This means that you need to assign different VLANs to different MST instances, and then adjust the spanning tree parameters (such as priority, cost, or port role) for each instance to achieve the desired load balancing. For example, you can make one switch the root for instance 1 and another switch the root for instance 2, and then map half of the VLANs to instance 1 and the other half to instance 2.
NEW QUESTION # 95
Refer to the exhibit. In the Core-2 configuration of spanning-tree instance 2 priority 0, what needs to be configured to enable the root for VLAN 20 while VLAN 10 remains root on Core-1?
  • A. Spanning-tree priority 0 VLAN 20
  • B. Spanning-tree priority root VLAN 20
  • C. Spanning-tree instance 2 VLAN 20
  • D. Spanning-tree VLAN 20
To configure Core-2 as the root bridge for VLAN 20 while VLAN 10 remains on Core-1, you must associate VLAN 20 with instance 2 by using the command spanning-tree instance 2 vlan 20.
This binds VLAN 20 to MSTP instance 2, allowing Core-2 (configured with priority 0) to become the root for that VLAN without affecting other VLANs like VLAN 10, which can be mapped to another instance with a different root.
NEW QUESTION # 96
You are are doing tests in your lab and with the following equipment specifications:
* AP1 has a radio that generates a 16 dBm signal.
* AP2 has a radio that generates a 13 dBm signal.
* AP1 has an antenna with a gain of 8 dBi.
* AP2 has an antenna with a gain of 12 dBi. The antenna cable for AP1 has a 4 dB loss. The antenna cable for AP2 has a 3 dB loss.
What would be the calculated Equivalent Isotropic Radiated Power (EIRP) for AP1?
  • A. 20 dBm
  • B. 40 dBm
  • C. -9 dBm
  • D. 15 dBm
The Equivalent Isotropic Radiated Power (EIRP) is the measured radiated power of an antenna in a specific direction. It is also called Equivalent Isotropic Radiated Power. It is the output power when a signal is concentrated into a smaller area by the Antenna. The EIRP can take into accountthe losses in transmission line, connectors and includes the gain of the antenna.It is represented in dB2. The formula for EIRP is:
EIRP=PTLc+Ga
where PT is the output power of the transmitter in dBm, Lc is the cable and connector loss in dB, and Ga is the antenna gain in dBi.
For AP1, the EIRP can be calculated as:
EIRP=164+8=20 dBm
Therefore, the answer B is correct.
References:1: Aruba Campus Access documents and learning resources2: EIRP Calculator - Effective Isotropic Radiated Power
NEW QUESTION # 97
Using HPE Aruba Networking best practices, what should be enabled for visitor networks where encryption is needed but authentication is not required?
  • A. Open Authentication mode
  • B. Wi-Fi Protected Access 3 Enterprise
  • C. Opportunistic Wireless Encryption
  • D. Wired Equivalent Privacy
Opportunistic Wireless Encryption (OWE) is a feature that provides encryption for open wireless networks without requiring authentication. OWE uses an enhanced version of the 4-way handshake to establish a pairwise key between the client and the AP, which is then used to encrypt the wireless traffic using WPA2 or WPA3 protocols. OWE can be used for visitor networks where encryption is needed but authentication is not required.
NEW QUESTION # 98
You are configuring an SVI on an Aruba CX switch that needs to have the following characteristics:
* VLANID = 25
* IPv4 address 10 105 43 1 with mask 255.255.255.0
* IPv6 address fd00:5708::f02d:4df6 with a 64 bit prefix length
* member of VRF eng
* VRF eng and VLAN 25 have not yet been created
Which command lists will satisfy the requirements with the least number of commands?
  • A.
  • B.
  • C.
  • D.
This is the correct command list that will satisfy the requirements with the least number of commands. Option C contains four commands that will create VLAN 25, assign it to VRF eng, create an SVI for VLAN 25 with IPv4 and IPv6 addresses, and enable the SVI. The other options are incorrect because they either contain more commands than necessary or do not meet all the requirements.
NEW QUESTION # 99
HPE7-A01 Reliable Exam Pass4sure: https://www.dumpsmaterials.com/HPE7-A01-real-torrent.html
P.S. Free & New HPE7-A01 dumps are available on Google Drive shared by DumpsMaterials: https://drive.google.com/open?id=1kZii70d1-95fpNiW9WlfnYQMvpZe6XQV
