New Topic
sdhci-arasan fe330000.sdhci: data error (-84)
84
Posted at 4/22/2017 01:15:44      View9974 | Replies12        Print      Only Author   [Copy Link] 1#
hi my friends ,my mini pc not work .all detail about this is written below .plz
1.696309] sdhci-arasan fe330000.sdhci: data error (-84)
[    1.696362] sdhci-arasan fe330000.sdhci: failed (-84) to handle RPMB request
super moderator
Rank: 8Rank: 8
Posted at 4/24/2017 15:53:26        Only Author  2#
what is your miniPC ,is a rk3399 board made by yourself?
Posted at 4/24/2017 17:40:14        Only Author  3#
It look like something wrong with eMMC .
You can try the new Firmware. Or wait the SDK update,
I heard this week will update 3399 source code .
Posted at 8/26/2017 06:42:07        Only Author  4#
I received my rk3399 board few days ago an I got same problem, I tried Android and flint_os. On flint_os I got kernel panic, on Ubuntu it's stuck on this:
[    1.665824] sdhci-arasan fe330000.sdhci: data error (-84)
[    1.666364] sdhci-arasan fe330000.sdhci: failed (-84) to handle RPMB request
u?   1.675940]
[    1.730858] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    1.752497] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 317
[    1.760954] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[    1.761539] mmc2: new ultra high speed SDR104 SDIO card at address 0001
any help?
Posted at 8/26/2017 07:10:00        Only Author  5#
And this is the output loading flint:
[    1.635925] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[    1.639277] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[    1.640196] mmcblk1: error -84 transferring data, sector 2602120, nr 32, cmd response 0x900, card status 0x0
[    1.641097] mmcblk1: retrying using single block read
[    1.651438] mmcblk1: error -84 transferring data, sector 2602147, nr 5, cmd response 0x900, card status 0x0
[    1.652317] blk_update_request: I/O error, dev mmcblk1, sector 2602147
[    1.655667] mmcblk1: error -84 transferring data, sector 2602148, nr 4, cmd response 0x900, card status 0x0
[    1.656658] blk_update_request: I/O error, dev mmcblk1, sector 2602148
[    1.660219] mmcblk1: error -84 transferring data, sector 2602150, nr 2, cmd response 0x900, card status 0x0
[    1.661148] blk_update_request: I/O error, dev mmcblk1, sector 2602150
[    1.666383] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[    1.669373] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[    1.670283] mmcblk1: error -84 transferring data, sector 1188736, nr 144, cmd response 0x900, card status 0x0
[    1.671246] mmcblk1: retrying using single block read
[    1.691750] mmcblk1: error -84 transferring data, sector 1188789, nr 91, cmd response 0x900, card status 0x0
[    1.692698] blk_update_request: I/O error, dev mmcblk1, sector 1188789
[    1.714908] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[    1.723999] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[    1.726966] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[    1.727876] mmcblk1: error -84 transferring data, sector 3290496, nr 32, cmd response 0x900, card status 0x0
[    1.728797] mmcblk1: retrying using single block read
[    1.732799] mmcblk1: error -84 transferring data, sector 3290498, nr 30, cmd response 0x900, card status 0x0
[    1.733768] blk_update_request: I/O error, dev mmcblk1, sector 3290498
[    1.737489] mmcblk1: error -84 transferring data, sector 3290501, nr 27, cmd response 0x900, card status 0x0
[    1.738480] blk_update_request: I/O error, dev mmcblk1, sector 3290501
[    1.741644] mmcblk1: error -84 transferring data, sector 3290502, nr 26, cmd response 0x900, card status 0x0
[    1.742590] blk_update_request: I/O error, dev mmcblk1, sector 3290502
[    1.745837] mmcblk1: error -84 transferring data, sector 3290503, nr 25, cmd response 0x900, card status 0x0
[    1.746782] blk_update_request: I/O error, dev mmcblk1, sector 3290503
[    1.750049] mmcblk1: error -84 transferring data, sector 3290504, nr 24, cmd response 0x900, card status 0x0
[    1.751002] blk_update_request: I/O error, dev mmcblk1, sector 3290504
[    1.759651] mmcblk1: error -84 transferring data, sector 3290519, nr 9, cmd response 0x900, card status 0x0
[    1.760588] blk_update_request: I/O error, dev mmcblk1, sector 3290519
[    1.763510] mmcblk1: error -84 transferring data, sector 3290520, nr 8, cmd response 0x900, card status 0x0
[    1.766667] mmcblk1: error -84 transferring data, sector 3290521, nr 7, cmd response 0x900, card status 0x0
[    1.771241] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[    1.774126] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[    1.774997] mmcblk1: error -84 transferring data, sector 3290496, nr 8, cmd response 0x900, card status 0x0
[    1.775869] mmcblk1: retrying using single block read
[    1.781227] mmcblk1: error -84 transferring data, sector 3290501, nr 3, cmd response 0x900, card status 0x0
[    1.784817] mmcblk1: error -84 transferring data, sector 3290503, nr 1, cmd response 0x900, card status 0x0
[    1.785930] Kernel panic - not syncing: Requested init /sbin/init failed (error -5).
[    1.786618] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.52 #21
[    1.787147] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
after that there is a long call trace
2Wan
hardcore
Rank: 8Rank: 8
Posted at 5/16/2018 18:08:49        Only Author  6#
nadsat Posted at 8/26/2017 07:10
[    1.635925] mmc1: Got data interrupt 0x00000002 even tho ...
Hello , I have met the same problem with you.
Have you solved it out ?
Thank you.
2Wan
hardcore
Rank: 8Rank: 8
Posted at 5/16/2018 20:12:50        Only Author  7#
I have solved this problem by decrease eMMC clk frequence from 200MHz to 150MHz.
maybe  there are some problems  about eMMC signal  on Hardware designing.
Posted at 1/10/2026 03:33:15        Only Author  8#
Your article is magnificent, thank you for sharing it with us! Free access to the CCAAK reliable test camp free test questions! Wishing you all the best in your exams!
Posted at 1/14/2026 02:09:40        Only Author  9#
Im inspired by the message in this article, thank you for sharing! Today, Im giving you the C_TFG61_2405 reliable test question questions that helped me secure a promotion and a raisefor free!
Posted at 1/18/2026 12:25:01        Only Author  10#
Truly an extraordinary article, Im thankful for your sharing. The NCP-AI Practice Online helped me get promoted and earn a raise, and now its open for free. Wishing you all rapid career growth!
Return to List
12
