Unable to enter loader mode
38
Posted at 1/16/2018 23:16:55      View10791 | Replies9        Print      Only Author   [Copy Link] 1#
I just got my hands on the AIO-3399 board.
I am trying to access the "upgrade" mode, but there is no device presented on the USB ports.
It does change boot mode, and I get different output on the screen connected to HDMI, but my workstation (linux) does not detect any devices connected on USB.
Any ideas?
Also, any information on which pads to short in order to enter maskrom mode?
Posted at 1/17/2018 09:14:04        Only Author  2#
Posted at 1/17/2018 15:58:58        Only Author  3#
Tried that, but there is no devices presented on my host PC (linux) when connecting the dual male USB cable to the PC.
I get the andriod recovery image on the screen, but no USB device is presented and listed. There is no entries in the syslog for any connected devices and "lsusb" does not show any rockchip devices either.
Posted at 1/17/2018 16:28:35        Only Author  4#
pani Posted at 1/17/2018 15:58
Tried that, but there is no devices presented on my host PC (linux) when connecting the dual male US ...
connect the double usb3.0 interface of the top side.
Posted at 1/17/2018 17:02:09        Only Author  5#
Thanks for the help.
Turns out that the USB hub I was using was causing the setup not to work. So for anybody else with this problem check with another USB hub..
Posted at 1/17/2018 17:04:02        Only Author  6#
Do you also know how to force the board to maskrom mode? I guess I will end up there sooner or later.....
Posted at 1/26/2018 17:19:33        Only Author  7#
pani Posted at 1/17/2018 17:04
Do you also know how to force the board to maskrom mode? I guess I will end up there sooner or later ...
http://en.t-firefly.com/index.php/doc/product/info/id/401.html
Posted at 1/28/2018 16:43:11        Only Author  8#
This describes the process for the rk-3288 board, not rk-3399 as my question is.
By looking at the board, I was able to make a relevant guess that it was the two exposed pads also on the 3399 board, but relevant documentation for 3399 would be appreciated.
Posted at 1/29/2018 17:08:40        Only Author  9#
pani Posted at 1/28/2018 16:43
By looking at the  ...
http://www.t-firefly.com/doc/pro ... ct/info/id/229.html
It seems they forget to update this web , just see that with chinese .
Posted at 1/24/2026 09:19:25        Only Author  10#
Your article has made a lasting impression, thank you! Wishing myself all the best for the Reliable C-S4CS-2508 exam objectives exam!
