New Topic
[General] Board boots into recovery mode
Posted at 4/22/2022 09:39:00        Only Author  11#
799959745 Posted at 4/22/2022 09:29
Are you using our baseboards?
Could you take a picture?
Yes, I'm using the baseboard MB-JD4-RV11091126. I'll take a picture later.
Edit:
Posted at 4/23/2022 04:56:24        Only Author  12#
I can build the firmware with the thunder boot option and boot successfully after flashing. Everything boots and loads as intended.
./build.sh device/rockchip/rv1126_rv1109/aio-rv1126-jd4-BE-45-tb-v11.mk
./build.sh
I cannot, however, build and flash the normal firmware:
./build.sh device/rockchip/rv1126_rv1109/aio-rv1126-jd4-BE-45.mk
./build.sh
super moderator
Rank: 8Rank: 8
Posted at 4/25/2022 17:30:32        Only Author  13#
Fuzzy1 Posted at 4/23/2022 04:56
I can build the firmware with the thunder boot option and boot successfully after flashing. Everythi ...
Can you run without connecting to your peripherals and leaving only the core board and the backplane?
super moderator
Rank: 8Rank: 8
Posted at 4/25/2022 17:43:09        Only Author  14#
I compile and burn the device and it works fine.
  1. [root@RV1126_RV1109:/]# cat /proc/version
  2. Linux version 4.19.111 (lvsx@tchip14) (kernel commit id: 85988bd7b1fc67ac96e868b90f4e676f44c713ae) (sdk version: rv1126_rv1109_linux_release_20220324_v2.2.5b.xml) (gcc version 6.3.1
  3. 20170404 (Linaro GCC 6.3-2017.05)) #280 SMP PREEMPT Mon Apr 25 17:32:47 CST 2022
Copy the code
super moderator
Rank: 8Rank: 8
Posted at 4/25/2022 17:47:39        Only Author  15#
799959745 Posted at 4/25/2022 17:43
Maybe you can package the firmware for burning.
  1. ./build.sh updateimg
  2. upgrade_tool ef xxx.img
  3. upgrade_tool uf xxx.img
Copy the code
Posted at 4/25/2022 21:19:51        Only Author  16#
799959745 Posted at 4/25/2022 17:30
Can you run without connecting to your peripherals and leaving only the core board and the backpla ...
I disconnected everything except DEBUG connector but board still boots into recovery mode.
Posted at 4/25/2022 21:20:56        Only Author  17#
799959745 Posted at 4/25/2022 17:47
Didn't help, still same problem.
Posted at 4/26/2022 03:52:19        Only Author  18#
I have the same kernel commit id:
  1. Linux version 4.19.111 (fredrik@fredrik-Aspire-A515-55) (kernel commit id: 85988bd7b1fc67ac96e868b90f4e676f44c713ae) (sdk version: rv1126_rv1109_linux_release_20220324_v2.2.5b.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #41 SMP PREEMPT Mon Apr 25 13:01:45 CEST 2022
Copy the code
Posted at 4/26/2022 05:20:17        Only Author  19#
Found the problem:
I had disabled the FIQ debugger in the device tree:
  1. &fiq_debugger {
  2.         status = "disabled";
  3. };
Copy the code
When fiq debugger was enabled the board boots normally.
I don't know why the board boots into recovery mode when the FIQ debugger is disabled.
super moderator
Rank: 8Rank: 8
Posted at 4/28/2022 15:00:39        Only Author  20#
Fuzzy1 Posted at 4/26/2022 05:20
Found the problem:
I'll confirm the problem first
Return to List
123
