New Topic
[General] Using imx219 camera with thunder boot
8
Posted at 5/11/2022 18:27:02        Only Author  11#
799959745 Posted at 5/11/2022 09:20
A Thunder Boot is fine. But the Quick Snapshot mode has not been tried, it should also be possible ...
I have ordered the OS04A10 camera, so hopefully I can use it with Thunder Boot with or without Snapshot Mode.
Posted at 5/13/2022 05:13:11        Only Author  12#
Some more questions:
1.
I noticed that there are Quick Snapshot MCU firmware for imx415 (rv1126_riscv_imx415_3864_2192_SGBRG10_compact_v1.00.bin),  os04c10 (rv1126_riscv_os04c10_2688_1520_SBGGR10_compact_v1.10.bin) and sc210iot (rv1126_riscv_sc210iot_1920_1080_SBGGR10_compact_v1.00.bin) but not for OS04A10.
Is there Quick Snapshot firmware available for OS04A10?
2.
Has the document Rockchip_Developer_Guide_RV1126_RV1109_Battery_Product_EN.pdf been updated recently by Rockchip? Current version in the Firefly SDK is v1.6.1.
3.
Does additional information exist about how to program the MCU? The documentation mentions for example the directory bsp/rockchip/rv1126-riscv but I can't find a similar path in the Firefly SDK.
super moderator
Rank: 8Rank: 8
Posted at 5/14/2022 16:39:52        Only Author  13#
There is no firmware for taking quick pictures. But it supports quick photo shooting. You can try it out by following the documentation first.
Posted at 5/14/2022 19:53:10        Only Author  14#
I read the information provided in Rockchip_Developer_Guide_RV1126_RV1109_Battery_Product_EN.pdf, but there is really no information about how to write code for the MCU.
Is there additional documentation somewhere?
Is there source files for the MCU that can be studied and compiled?
super moderator
Rank: 8Rank: 8
Posted at 5/17/2022 14:44:04        Only Author  15#
Fuzzy1 Posted at 5/14/2022 19:53
I read the information provided in Rockchip_Developer_Guide_RV1126_RV1109_Battery_Product_EN.pdf, bu ...
This part of rockchip has not released relevant information.
Posted at 8/12/2022 04:00:23        Only Author  16#
I found out that if I use I2C1 instead of I2C2 it works fine. So there's probably some kind of bug which prevents using I2C2 with Thunder Boot enabled.
Posted at 1/15/2026 17:45:16        Only Author  17#
What a phenomenal read, I truly appreciate you sharing it! Good luck on your exams! Here are the free C_P2WIE_2404 latest exam pdf questions for you.
restricted members
Posted at 1/18/2026 17:26:37        Only Author  18#
Cant get enough of this content, definitely liking it. The BUS105 reliable braindumps questions content is truly helpful, and it's offered without any cost.
Posted at 2/12/2026 07:27:11        Only Author  19#
I'm giving this a like without even thinking twice. The C_HRHPC_2505 new practice questions ppt test questions are the key to career successnow shared for free!
Return to List
12
