New Topic
[Linux] How can I make a minimal os build in for PX30 board
16
Posted at 10/30/2024 18:59:05        Only Author  11#
Since you're working with Yocto for a minimal image on the Firefly PX30, here are a few steps that might help get things rolling.
If you still have access to the Yocto SDK (or can re-download it), you can set up a minimal image by using core-image-minimal as a starting point, which is really lightweight and great for troubleshooting hardware issues. To do this, youll need to reconfigure the build environment.
First, reinstall the Yocto SDK and set up the environment variables again. You can run:
  1. source oe-init-build-env
Copy the code
This sets up the default paths and configures the bitbake environment.
Once in the environment, you can build the core-image-minimal with:
  1. bitbake core-image-minimal
Copy the code
For bootloaders like U-Boot and kernel, if you have customizations, add them in local.conf or bblayers.conf as layers so they get included in the build.
Since you want to test peripherals one at a time, you can try disabling drivers or components in the device tree for each peripheral and then rebuild. This could help isolate the issue without hanging the boot process. If it still hangs, check the boot logs through serial output - it often gives clues on what part might be causing issues.
Posted at 1/9/2026 18:23:05        Only Author  12#
I deeply appreciate your article, it was truly memorable. I reached my career goals thanks to the Valid test COF-C02 bootcamp exam, and now you can access it for free!
Posted at 1/13/2026 16:20:21        Only Author  13#
This article is brilliant, and Ive gained a lot of inspiration from it. AD0-E605 test questions pdf provides amazing content, and it's completely free.
Posted at 1/23/2026 21:40:02        Only Author  14#
I learned a great deal from the article. I owe my success to the Latest test DOP-C02 collection file test, and now Im giving you access to it for free!
Return to List
12
