Firefly-RK3288 Slackware Arm
191
Posted at 4/19/2016 09:06:49        Only Author  21#
hi mara, thanks so much for getting back to me, tired to download the torrent as that would be the best way for me to download without worrying about a dropped connection however i can't download the torrent file you posted, it says 'Forbidden' when i try to
I'm really excited to try out slackware so hopefully i can get this going soon
vip
Rank: 6Rank: 6
Posted at 4/19/2016 10:52:51        Only Author  22#
hi, AussieJohn
I'm sorry, does the right to file were limited fixed
donation   irradium
Posted at 4/19/2016 13:59:50        Only Author  23#
mara, thanks its working now, ill download and install tonight
I'm no expert in linux but let me know if i can help out in anyway with testing etc and id be happy to
Posted at 4/19/2016 19:41:18        Only Author  24#
mara
sorry to bother you again, I'm still having trouble downloading the xfce image, I've got every other file but that one drops the connection randomly still.
I've tried the torrent but theres no seeders
vip
Rank: 6Rank: 6
Posted at 4/20/2016 00:40:20        Only Author  25#
donation   irradium
vip
Rank: 6Rank: 6
Posted at 4/20/2016 03:38:36        Only Author  26#
create a bootable sdcard
http://p.fail.pp.ua/Pn6CSd2O
donation   irradium
Posted at 4/20/2016 06:20:58        Only Author  27#
thanks mara, i was able to download that last file, I'm at university right now but when i get home ill flash my firefly and let you know how it went
thanks again for all your help and for spending the time getting slackware running on this board
Posted at 4/20/2016 19:19:17        Only Author  28#
update:
I've flashed all the files to the correct locations etc using androidtools but when i boot the firefly theres a kernel panic that says
[ end kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1)
i haven tried reflashing a couple times but I'm not sure what to try next? i had a look at the parameters.txt but im not sure what i need to change
vip
Rank: 6Rank: 6
Posted at 4/21/2016 03:19:22        Only Author  29#
I wrote above, the firmware is successful on eMMC, but in fact and not sewn. so I put on root sdcard or all of the loader to the root partition
sufficient to eMMC flash parameters.txt, boot.img, kernel.img
create a partition on sdcard and pour back linuxroot (dd /dev/mmcb0p1)
above script to create such a sdcard (but be careful with the choice of card, the script has made a mistake, when you cancel it)
donation   irradium
Posted at 4/21/2016 14:50:41        Only Author  30#
mara, I'm having no luck getting it to work
tried androindtools and it flash with no error but hangs whole looking for root fs
tried the linux script to flash emac and it has same error on boot
also tried the sdcard script but i don't seem to be able to boot from sdcard
it appears to me that its failing to detect the root partition set in the parameters.txt file, perhaps theres is something wrong there?
