Firefly New DualBoot Firmware Release£¨Beta£©
1821
super moderator
Rank: 8Rank: 8
Posted at 7/6/2016 09:40:25        Only Author  41#
Hi mac-l1
    Yes£¬ we will put these source code on the github in a few days.
Posted at 7/6/2016 15:17:50        Only Author  42#
mac-l1 Posted at 7/6/2016 04:25
Hi isle,
Can you also share your armsoc driver sources on github and also libdrm sources that you ...
Hi mac-l1:
libdrm and armsoc code has released.
libdrm https://github.com/T-Firefly/libdrm.git
note that libdrm default config disabled kms, need to enable kms by "--enable-libkms"
armsoc
https://github.com/T-Firefly/armsoc-rockchip
in autogen.sh, set
  1. CONFIGURE_DEF_OPT="--enable-maintainer-mode --prefix=/usr --with-driver=rockchip"
Copy the code
Posted at 7/10/2016 02:48:09        Only Author  43#
Hi,
Are you planning to release new flashable images with the the fixes you already committed?
Endre
Posted at 7/10/2016 23:51:17        Only Author  44#
Any updates for firmware or SDK on Bitbucket to be released soon?
Also try to add better spam detection to the forum since lots of users try to spam it regularly.
Can also try to make the captcha code more difficult and make users wait 30 seconds between posts.
super moderator
Rank: 8Rank: 8
Posted at 7/11/2016 14:46:20        Only Author  45#
andrewsmithty Posted at 7/10/2016 02:48
Hi,
End ...
Hi andrewsmithy
       we have opened the source code .so we  will not release images very  frequent.
you can make it by youself.
super moderator
Rank: 8Rank: 8
Posted at 7/11/2016 15:12:05        Only Author  46#
mo123 Posted at 7/10/2016 23:51
Also try to add better spam det ...
Hi mo123
   Yes ,we will update the sdk on bitbucket in fews weeks.there are some  bugs  that need to be solved.
Thank you very much for your suggestions. we will do our best to protect our forum cleaner.
Posted at 7/16/2016 11:23:08        Only Author  47#
Hi
I see new Firefly sources were released for Android.
Does it also work for Firefly Reloaded or are there still new code for Firefly Reloaded to be updated since it only contain pre-updated code for Firefly Reloaded?
Can you also add enable PIP, change PIP size, change PIP position settings shortcuts to the power button long press menu for Firefly Reloaded?
It would be much easier to access then to use the menu button or to open the HDMI-IN app first.
HDMI-IN app window should also use transparent black, grey colors to see background behind it.
Posted at 7/19/2016 20:03:26        Only Author  48#
Thanks a lot for the update. It is really important for us that you keep updating the software as often as possible.
But I still have the same issue going on. Firstly my HP w2408h monitor with (1920x1200) resolution is not recognized properly. Ubuntu sets the resolution to 1920x1080 and it is not changeable in the settings. So the corners of the screen looks cropped. I cant click windows etc... Very frustrating.
I really dont want to buy a 1080p monitor just for Firefly.
Raspberry Pi and other boards recognize my monitor resolution by default so it shouldnt be much difficult to implement. I think Firefly developers should look for all common 16:9 and 16:10 ratio resolutions and add firmware support to them.
16:9 = 1280x720, 1366x768, 1600x900, 1920x1080, 2560x1440,  3840x2160
16:10 = 1280¡Á800, 1440¡Á900, 1680¡Á1050, 1920¡Á1200, 2560¡Á1600
super moderator
Rank: 8Rank: 8
Posted at 7/21/2016 15:07:34        Only Author  49#
Hi cagancelik
   Thanks for your suggestion.
    We haven't has  such a monitor.
     We will buy one and support the 16:10 ratio .
    Thanks!
Posted at 7/21/2016 21:28:50        Only Author  50#
Hi,
I am on the released beta image.
Is the fire easy app supposed to work? I have a firefly reload, and it does not connect from my phone to the reload, even though: they are on the same wifi network / both devices have their bluetooth activated.
Endre
