New Topic
debian stretch + kernel 4.4 firmware release (hw accelerated), kodi installable
690
Posted at 6/19/2017 14:54:54        Only Author  11#
ittai Posted at 6/19/2017 05:26
does this give acces to the hdmi input?
i dont know. i have only built this for the original firefly not the firefly reloaded. the original doesnt have hdmi in.
kernel could easily be replaced with firefly reloaded kernel as this is also supported by rockchip kernel in https://github.com/rockchip-linux/kernel/tree/release-4.4and https://github.com/rockchip-linux/build
Posted at 6/25/2017 19:11:06        Only Author  12#
Guys,
first of all thanks a lot to mac-l1 for his great job!!
I am trying to load the bin file onto my rk3288 Firefly but I got thi message:
# ./flash.sh
+ ./rkdeveloptool db rk3288_ubootloader_v1.01.06.bin
The  Device did not support this operation!
The device seems to be fine when I test it:
# ./rkdeveloptool td
Test Device OK.
Do you have hints?
Thanks!
Posted at 6/26/2017 01:16:48        Only Author  13#
zeno Posted at 6/25/2017 19:11
Guys,
Ok,
I had issues with bootloader and had to go to maskrom mode.
All works now!
Posted at 7/6/2017 23:15:55        Only Author  14#
Hello, guys! Thank you for your work.
I have an issue with thermal module in kernel. I used to successfully build opencv 2.4.9 on Firefly-RK3288 with Ubuntu 14.04 server firmware (slightly altered, I've installed X server and OpenBox there) with no issues on all 4 cores (make -j4).
However, with this firmware installed I got my Firefly automatically switched off with following message:
  1. Message from syslogd@localhost at Jul  6 14:56:19 ...
  2. kernel:[ 3690.721460] thermal thermal_zone0: critical temperature reached(90 C),shutting down
  3. Connection to 192.168.0.109 closed by remote host.
  4. Connection to 192.168.0.109 closed.
Copy the code
How can I disable this feature or make temperature limit higher? As I mentioned earlier, I've successfully built this version of opencv on all cores, but now kernel is more aware of current CPU temperature. Thanks.
Posted at 7/7/2017 00:19:17        Only Author  15#
Also I have an issue with taking backup of device partitions. Android Tool on Windows 8 show me, that my device is in Maskrom mode.
This strange behavior started to happen after I've downloaded rk3288_ubootloader_v1.01.06.bin bootloader. Could you please help with backing up procedure?
Posted at 8/12/2017 08:06:43        Only Author  16#
Can you please provide exact working device tree which has HDMI sound output for Reload that we can use on normal  RK3288-Firefly?
GIT link or patch,...
Thanks
Posted at 8/13/2017 18:28:25        Only Author  17#
+1 for git link.
I've tried this: https://github.com/rockchip-linux/kernel/tree/release-4.4 (it's 4.4.71 when mac-l1's distro is based on 4.4.55) with extracted configuration from /proc/config.gz, now I have eDP-1 presented in xrandr. If I switch eDP-1 off (e.g. xrandr --output eDP-1 --off or by passing kernel parameter video=eDP-1:d), then image shows normally.
I'm also interested in building fast booting system for embedded development, so it would be nice to have building instructions.
Posted at 8/16/2017 15:23:01        Only Author  18#
hi all,
I am also using https://github.com/rockchip-linux/kernel/tree/release-4.4 for my kernel which at the moment is 4.4.77.
But the HDMI output is not available as I believe is not implemented in device three.
Do you guys can get the audio on HDMI when using mac-l1 KODI packages?
I only have option for SPDIF output and there is no sound on HDMI!
I appreciate any assistance....
Posted at 8/16/2017 18:51:28        Only Author  19#
sghazagh Posted at 8/16/2017 15:23
hi all,
I am also using https://github.com/rockchip-linux/kernel/tree/release-4.4 for my kernel whi ...
Hello sghazagh. How do you build a kernel?
I use instructions from here http://rockchip.wikidot.com/linux-user-guide to build linux kernel and uboot. There is also device tree generated at build time. Make sure you are using latest source code from rockchip-linux.
Also, what is the problem with HDMI output? Despite having extra output eDP-1, image is pretty stable. You can switch eDP-1 off either with
xrand --display :0 --output eDP-1 --off
or by appending parameter
video=eDP-1:d
to kernel boot arguments.
Posted at 9/4/2017 13:19:00        Only Author  20#
Hi mac-I1,
i've found solution. to install libudev for i386 can make it work.
sudo apt-get install libudev-dev:i386
Return to List
123
