New Topic
No HDMI output with Topfoison 2k display
78
Posted at 8/31/2017 04:18:21      View:8719 | Replies:25        Print      Only Author   [Copy Link] 1#
Hello, I have been testing my 2k display that just came in and it looks like the display works over HDMI with the PC at 2560x1440 and 1080p however upon connecting the display to the firefly the screen is dark. It shows an active handshake with the Firefly but nothing is displayed.
Anything you can do to help?
super moderator
Rank: 8Rank: 8
Posted at 8/31/2017 09:47:22        Only Author  2#
with the latest android firmware? get any log with adb?
Posted at 9/1/2017 02:02:55        Only Author  3#
We are running android 7.1.1 with firmware 4.5? would have to check on the additional details. ADB reports resolution as unsupported for some reason.
Posted at 9/1/2017 06:21:42        Only Author  4#
http://wiki.t-firefly.com/index. ... 99/Starter_guide/en  Also your Starter Wiki points out that you can set the resolution to Auto in the settings menu, however I do not see this option on our 7.1.1 system.  Is there a fix for this or is there a manual command we can run to force the device into 2560x1400 resolution?
super moderator
Rank: 8Rank: 8
Posted at 9/1/2017 10:00:47        Only Author  5#
wm size WxH
Posted at 9/2/2017 06:51:50        Only Author  6#
Tried that method through ADB the density of the screen was off and still no display on the topfoison screen. Do you think setting display output to DVI and or adding non EDID options could sort the issue? Is there a boot.ini or boot.scr file that cane be edited?
super moderator
Rank: 8Rank: 8
Posted at 9/4/2017 09:50:39        Only Author  7#
did you have another 2K monitor?
Posted at 9/6/2017 02:01:44        Only Author  8#
Yes will test with another 2K dispplay tonight and let you know.
Posted at 9/6/2017 10:12:40        Only Author  9#
Tested with Dell UD2717D 2560x1440 IPS monitor and was able to get Firefly to display. So there is something off EDID or HDCP or something with the TOPFOISON. Maybe it is causing the board to fallback to 1080p which that display does not support. Any logs I can send your way?
super moderator
Rank: 8Rank: 8
Posted at 9/7/2017 09:37:42        Only Author  10#
adb log & kernel log.
Return to List
123
