[General] Armbian and LibreELEC for rk3399
856
Posted at 12/29/2020 19:05:33
Added new versions of armbiantv images with the legacy kernel with different DE (XFCE\Mate\Lxde) for use with the HW video acceleration media script.
https://yadi.sk/d/_nL2P2g2VRtLrQ?w=1
Posted at 1/10/2021 01:10:44
New versions
Armbian 20210109 kernel 5.9.16 \  4.4 (please note that now all versions with the "new" and " old " kernel are in the same directory).
ArmbianTV 20210109 kernel 5.10.5
LibreELEC 20210108 kernel 5.10.5.
Posted at 1/19/2021 19:57:18
ArmbianTV 20210119 kernel 5.10.8
Libreelec 20210118 kernel 5.10.8
Posted at 1/23/2021 22:24:10
Armbian 20210123 kernel 5.10.9
ArmbianTV 20210123 kernel 5.10.9
LE 20210121 kernel 5.10.9
Posted at 1/23/2021 22:55:37
Please note that the composition of the images has changed. Now the main versions are Debian-12 Sid and Ubuntu-21.04 Hirsute. For Bullseye and Focal, only minimal server images are used (but you can install DE on them yourself). For those who need other versions of the distribution, I recommend using a self-build of the desired version directly on the device itself. To do this, there is a great video on how to build your distribution versions (your images) directly on M1 and P1.
Posted at 1/29/2021 22:51:07
Armbian 20210129 kernel 5.10.11
ArmbianTV 20210129 kernel 5.10.11
LE 20210129 kernel 5.10.11
Posted at 2/5/2021 01:30:31
The new version Armbian 20210204 and ArmbianTV 20210204-legacy.
Added support for NVMe analog audio and remote control.
Posted at 2/11/2021 18:06:25
Updated the Armbian\ArmbianTV images (20210211) kernel 5.10.15\4.4.
I checked both variants of Buster-legacy + media script on P1 (rk3399). I froze the kernel update, installed the script, checked the HW acceleration, everything works. Including remote control in KODI and on the desktop, analog sound works (by default, the sound level is set low, you need to go to settings and increase the volume), 4k works.
Update Libreelec 20210211 kernel 5.10.15
Posted at 2/19/2021 19:44:44
New version of ArmbianTV 20210218. kernel 5.10.17 4.4
An important difference.
I made the transition to the startup system using the settings only in the "extlinux.conf" file. You no longer need to use a lot of complex scripts and intermediate text files to describe the startup process. Setting up the DTB is done by editing the line in "extlinux.conf". There you can also change any other startup parameters (disable BOOTFLASH, add a forced binding to the MAC, etc.). That is, you can now use the officially supported parameter format for "extlinux.conf". I also stop publishing versions of Armbian images, because they differ little from the official versions of images from the Armbian download site (i.e. I remove redundant duplication).
Libreelec 20210218 kernek 5.10.17
Posted at 2/21/2021 17:04:59
The new version 20210221.
Important information.
The installation mode in eMMC has changed. Now, the standard application "armbian-config" and the corresponding menu items in it are used for installation in eMMC.
