[General] Armbian and LibreELEC for rk3399
883
Posted at 2/26/2021 18:11:11        Only Author  31#
Version 20210226 ArmbianTV.
Fixed NVMe and added a separate DTB for roc-rk3399-pc  with Legacy kernel.
After testing for several weeks u-boot-2021.01 on different rk3399, the transition to u-boot-2021.01 was made
I remind you that the configuration of DTB and other startup parameters is now performed in the file /boot/extlinux/extlinux.conf
LE ver 20210226
Posted at 3/11/2021 21:53:04        Only Author  32#
New version ArmbianTV 20210311. Kernel 5.10.22.
Please note. The composition of the images has changed. The name of the download folder has changed.
LE ver 20210311
Posted at 3/19/2021 19:18:29        Only Author  33#
Update ArmbianTV to version 20210319.
Using kernel 5.10.24. Added support for Firefly-rk3399 in station-p1 images (for proper operation, you need to configure DTB in extlinux.conf). With the correct DTB setup, the HDMI audio LAN WiFi BT works in kernel 5.10. In kernel 4.4 worck remote control and analog sound.
Update Libreelec 20210319/
Add support Firefly-rk3399 (for proper operation, you need to configure DTB in extlinux.conf)
Posted at 4/10/2021 15:30:31        Only Author  34#
Ver ArmbianTV and Libreelec - 20210409 kernel 5.10.28
Posted at 5/4/2021 16:03:39        Only Author  35#
i can not boot my roc-rk3399-pc with Armbian_21.08.0-trunk_Station-p1_buster_current_5.10.32.img.
Power auto down.
Posted at 5/5/2021 15:12:56        Only Author  36#
ddown Posted at 5/4/2021 11:03
P ...
You need to properly configure the DTB in the /extlinux/extlinux.conf file for roc-rk3399-pc.
Posted at 5/6/2021 14:38:38        Only Author  37#
Ver ArmbianTV  20210505 kernel 5.10.34
Posted at 5/6/2021 22:00:27        Only Author  38#
LibreELEC ver 20210505 kernel 5.10.34
Posted at 5/9/2021 13:27:47        Only Author  39#
balbes150 Posted at 5/5/2021 15:12
I had change it.
But not working
Posted at 5/9/2021 19:07:36        Only Author  40#
ddown Posted at 5/9/2021 08:27
I had change it.
But not working
Provide more information about what steps you are doing, the UART log.
