New Topic
[General] Armbian and LibreELEC for rk3328
934
Posted at 12/18/2020 14:20:17        Only Author  11#
Posted at 12/23/2020 22:06:56        Only Author  12#
Posted at 12/29/2020 19:06:10        Only Author  13#
Added new versions of armbiantv images with the legacy kernel with different DE (XFCE\Mate\Lxde) for use with the HW video acceleration media script.
https://yadi.sk/d/AXqdcX3K511DoQ?w=1
Posted at 1/10/2021 02:41:39        Only Author  14#
New versions
Armbian 20210109 kernel 5.9.16 \  4.4 (please note that now all versions with the "new" and " old " kernel are in the same directory).
ArmbianTV 20210109 kernel 5.10.5
LibreELEC 20210108 kernel 5.10.5.
Posted at 1/13/2021 18:54:42        Only Author  15#
Good news.
The new version Libreelec 20210113 for M1 (rk3328)  contains a fix for HW video playback up to 4k.
Posted at 1/19/2021 19:57:40        Only Author  16#
ArmbianTV 20210119 kernel 5.10.8
Libreelec 20210118 kernel 5.10.8
Posted at 1/20/2021 21:28:42        Only Author  17#
Launch LE on M1.
New image Libreelec (unoficcicial)
For M1, I release special images LE (arm and aarch64), there is no need to change anything, the system works immediately after writing to the SD card. All this works with almost all hardware (LAN WiFi HDMI sound, analog sound and remote control) without additional settings.
The name of the images contains rk3328-roc-pc
https://yadi.sk/d/8vNYuuxynz1L0w?w=1
Posted at 1/23/2021 22:26:19        Only Author  18#
Armbian 20210123 kernel 5.10.9
ArmbianTV 20210123 kernel 5.10.9
LE 20210121 kernel 5.10.9
Posted at 1/23/2021 22:56:19        Only Author  19#
Please note that the composition of the images has changed. Now the main versions are Debian-12 Sid and Ubuntu-21.04 Hirsute. For Bullseye and Focal, only minimal server images are used (but you can install DE on them yourself). For those who need other versions of the distribution, I recommend using a self-build of the desired version directly on the device itself. To do this, there is a great video on how to build your distribution versions (your images) directly on M1 and P1.
Posted at 1/30/2021 17:24:55        Only Author  20#
Armbian 20210129 kernel 5.10.11
ArmbianTV 20210129 kernel 5.10.11
LE 20210129 kernel 5.10.11
Return to List
12345
