New Topic
[General] Armbian and LibreELEC for rk3328
936
Posted at 2/12/2021 13:50:21        Only Author  21#
Ver 20210211 Armbian\ArmbianTV  kernel 5.10.15\4.4
LE 20210211 kernel 5.10.15
Posted at 2/19/2021 19:46:05        Only Author  22#
New version of ArmbianTV 20210218.  5.10.17 and 4.4
An important difference.
I made the transition to the startup system using the settings only in the "extlinux.conf" file. You no longer need to use a lot of complex scripts and intermediate text files to describe the startup process. Setting up the DTB is done by editing the line in "extlinux.conf". There you can also change any other startup parameters (disable BOOTFLASH, add a forced binding to the MAC, etc.). That is, you can now use the officially supported parameter format for "extlinux.conf". I also stop publishing versions of Armbian images, because they differ little from the official versions of images from the Armbian download site (i.e. I remove redundant duplication).
Libreelec 20210218 kernel 5.10.17
Posted at 2/21/2021 20:36:09        Only Author  23#
The new version 20210221.
Important information.
The installation mode in eMMC has changed. Now, the standard application "armbian-config" and the corresponding menu items in it are used for installation in eMMC.
Posted at 2/26/2021 21:00:50        Only Author  24#
ArmbianTV Ver 20210226
LE ver 20210226
Posted at 3/11/2021 22:03:26        Only Author  25#
New version ArmbianTV 20210311. Kernel 5.10.22.
Please note. The composition of the images has changed. The name of the download folder has changed.
LE ver 20210311
Posted at 3/19/2021 23:25:39        Only Author  26#
Ver 20210319 ArmbianTV and Libreelec
Posted at 4/10/2021 15:32:27        Only Author  27#
Ver ArmbianTV and Libreelec - 20210409 kernel 5.10.28
Added support for Firefly-rk3328-roc-cc (see the corresponding directory named Renegade)
Posted at 5/6/2021 14:39:20        Only Author  28#
Ver ArmbianTV  20210505 kernel 5.10.34
Posted at 5/6/2021 22:00:56        Only Author  29#
LibreELEC ver 20210505 kernel 5.10.34
Posted at 5/18/2021 19:51:29        Only Author  30#
Ver kernel 5.10.37 (for rk3328-roc-pc and rk3328-roc-cc)
Return to List
12345
