New Topic
How to use the vpu lib (base on C)on our firfly-rk3288
1821
super moderator
Rank: 8Rank: 8
Posted at 1/27/2015 10:21:54        Only Author  1#
as you gus know .the vpu works fine on our android os. and we can use it by android api "mediacodec".
today.i will to show you how to use it directly.
the libs we need :
  1. LOCAL_SHARED_LIBRARIES := \
  2.         libvpu \
  3.         librk_on2 \
  4.         libcutils \
  5.         liblog \
Copy the code
the head file path
  1. LOCAL_C_INCLUDES := \
  2. $(TOP)/hardware/rk29/libon2/
Copy the code
actualy ,we need :
hardware/rk29/libon2/vpu_api.h
hardware/rk29/libon2/vpu_global.h
hardware/rk29/libon2/vpu_mem.h
first of all , open the vpu and get the context:
  1.     struct VpuCodecContext* ctx=NULL;
  2.     vpu_open_context(&ctx);
Copy the code
then ,  initialize it:
  1.     ctx->codecType=cmd->codec_type;  // CODEC_DECODER?
  2.     ctx->videoCoding=cmd->coding;
  3.     ctx->width=cmd->width;
  4.     ctx->height=cmd->height;
  5.     ctx->no_thread=1;
  6.     ret=ctx->init(ctx, pExtra, extraSize)
Copy the code
now we can do decode
get a packet from your file .
  1. VideoPacket_t* pkt =NULL;
Copy the code
after decoding :
  1. ret=ctx->decode(ctx, pkt, pOut)
Copy the code
we get a out packet
  1. DecoderOut_t *pOut=NULL;
Copy the code
ok  we get the output .how to use it?
the data of pOut contains :
  1. VPU_FRAME *frame=(VPU_FRAME *)(pOut->data);
Copy the code
both virtual and physical address of the decoded frame are contained in structure named VPU_FRAME,
if you want to use virtual address, make sure you have done VPUMemLink before.
  1. VPUMemLink(&frame->vpumem);
Copy the code
save the output data :
  1. fwrite((U8*)(frame->vpumem.vir_addr), 1, frameSize, pOutFile);
Copy the code
remember use VPUFreeLinear to free, otherwise memory leak will give you a surprise.
  1. VPUFreeLinear(&frame->vpumem);
Copy the code
done !
Posted at 10/8/2015 18:34:13        Only Author  2#
hi,isle,
I want to use rk3288 video HW(hevc) decoder on linux,I use libhyris directly invoke the libvpu method,Can this be achieved?
Posted at 10/8/2015 18:34:29        Only Author  3#
hi,isle,
super moderator
Rank: 8Rank: 8
Posted at 10/9/2015 15:48:46        Only Author  4#
In theoryIt can work.
you could try
Posted at 10/13/2015 12:04:35        Only Author  5#
isle Posted at 10/9/2015 15:48
you could try
hi,isle,
Thank you for your reply,I intend to do so, can you give me some advice do?such as,about vpu service,Is available under Linux?
Posted at 10/14/2015 14:49:34        Only Author  6#
you could try
hi,isle,
If I want to use h265 lib directly,which libs is need?
super moderator
Rank: 8Rank: 8
Posted at 10/15/2015 10:33:58        Only Author  7#
h265?
the libhevcdec.so is needed.
Posted at 10/15/2015 15:42:49        Only Author  8#
isle Posted at 10/15/2015 10:33
h265?
You mean I just need to libhevcdec.so,no need libvpu.so?What is the relationship between these two libraries?
Posted at 10/28/2015 15:06:14        Only Author  9#
hi guys!
to add some info here:
libvpu is mainly needed for VPU/GPU memory access; librkon2 is needed for encoding/decoding; librkon2 uses other rk libs like libhevcdec to do its magic.
librkffplayer is a more complete library based on ffplayer lib to (de)mux and encoding/decoding streams and is used by androids stagefright, not yet available in machybris but can be quite easily added.
machybris also exposes the very high level api for androids media service by libmedia: ubuntu made this for their ubuntu touch/phablet products
hope this helps...
Posted at 11/3/2015 16:25:06        Only Author  10#
mac_l1 Posted at 10/28/2015 15:06
hi guys!
Thank you very much.
Return to List
12
