New Topic
How do I use SPI?
26
Posted at 2/9/2015 12:29:27        Only Author  1#
How do I use SPI?
hello
------test source-----------
device="/dev/spi_misc_test";
fd = open(device, O_RDWR);
if (fd < 0)
  pabort("can't open device");
  * spi mode
ret = ioctl(fd, SPI_IOC_WR_MODE, &mode);
if (ret == -1)
  pabort("can't set spi mode");
however  error abort.
How do I use SPI?
Posted at 2/12/2015 11:00:01        Only Author  2#
Re: How do I use SPI?
hi schkiki
you can find that spi_misc_test don't have an open function in source file kernel/drivers/spi/spi-rockchip-test.c
static const struct file_operations spi_test_fops = {
.write = spi_test_write,
so, it will be an error abort when you open the spi_misc_test.
before you want to open it or read it, you should write an open function, read function by yourself.
by the way, the SPI in firefly-rk3288 using the linux common interface, you can get more samples by google.
Posted at 2/14/2015 06:10:40        Only Author  3#
Hello,
I have firefly rk 3288 board.
As I found on the tutorial on the website [wiki gpio ] I tried to use SPI /GPIO but could not found dts file or even kernel/drivers or kernel/.../boot/dts/..etc
I also tried with find and locate command. it does not return any file with *.dts
Are these all about kernel compilation from source ? what are the actual steps I need to perform and what are those ?
Could you please write some more details  about how use GPIO/SPI ..
thanks
Posted at 2/14/2015 07:57:32        Only Author  4#
As I found on the tutorial on the website [wiki gpio ] I tried to use SPI /GPIO but could not found dts file or even kernel/drivers or kernel/.../boot/dts/.. etc
dts is in kernel source tree.
Posted at 2/14/2015 15:55:33        Only Author  5#
HI
THANKS.
COULD YOU PLEASE MENTIONED MORE ABOUT HOW I CAN USE GPIO/SPI . IT WILL BE PERFECT IF YOU JUST SEND ME ABOUT THE STEPS WHAT I HAVE TO
DO ...
THANKS IN ADVANCE
Posted at 2/14/2015 20:03:08        Only Author  6#
Hi,
I as look on that, if I am not work , I have to download kernel source tree from here - https://bitbucket.org/T-Firefly/firefly-rk3288-kernel, after configuraing dts for gpio/spi I have to build it and install kernels and modules, Is that right?
Posted at 2/26/2015 05:39:50        Only Author  7#
dear all,
I am little bit  confused about the firefly. I modified the  dts file inside the kernel source /arch/arm/boot/dts firefly-rk3288.dts.
My confusion is when kernel compiled will it take firefly-rk3288.dts or firefly-rk3288_beta.dts . Both have the same node i guess.
thanks
Posted at 2/26/2015 09:21:37        Only Author  8#
hi LNX_HOBBY
it will take firefly-rk3288.dts when you compile kernel, if your board is hardware version 2014.09.30.
Posted at 1/11/2026 15:38:28        Only Author  9#
This article is a real treasure, thank you for sharing it with us. Test New-Jersey-Real-Estate-Salesperson dumps pdf offers great insights, and it's completely free to access.
Posted at 1/16/2026 21:05:42        Only Author  10#
ITƥȤJϵθǤޤϤҪˤʤޤϮʤδζƤޤCIPSL5M7Achieving Competitive Advantage Through the Supply Chain (L5M7)ԇYϤʤšĤҪʻڵĤʳ¤ˤʤꡢ¤󥹤kҊ뤫⤷ޤ󡣤ȤCIPSL5M7ԇYˤɤäƺϸ񤷤ޤ䤹뤳ȤϤʤǤ衢إפʤԪˤޤ顣GoShikenä֤ȤϤʤǤGoShikenCIPSL5M7Achieving Competitive Advantage Through the Supply Chain (L5M7)ԇY}ȽԇYʂΥѥ˥Ǥ顣
Return to List
12
