Possible to activate 24/32 bit color support in Lubuntu?
543
Posted at 2/14/2015 02:50:06
Hi
Is it possible to increase the color to 24 or 32 bit in Lubuntu.
I read somewhere some time ago, you need to compile a new kernel.
Any help or link to the post would be appreciated.
Posted at 2/14/2015 13:51:31
Re: Possible to activate 24/32 bit color support in Lubuntu?
I fixed my own problem, so no need for anyone to reply by following Radxa wiki pages.
Posted at 2/26/2015 14:32:35
This is the wiki link:  http://radxa.com/Rock/display
Posted at 2/26/2015 23:10:06
Unfortunately it only give me a black screen after following the Radxa wiki page.
I think the problem is because there is no framebuffer driver.
Maybe someone else can also test the solution and see if it works for them.
Posted at 2/27/2015 10:19:38
Hi dewet
you can do as followings
  1. cat << EOF > /etc/init/fbset.conf
  2. # fbset - run fbset to set truecolor fbmo
  3. dedescription "run fbset ASAP"
  4. start on startup and started udev or starting lightdm
  5. task
  6. script
  7. [ -x /bin/fbset ] && /bin/fbset -a -nonstd 1 -depth 32 -rgba "8/0,8/8,8/16,8/24"
  8. end script
  9. EOF
Copy the code
  1. cat << EOF > /etc/X11/xorg.conf
  2. Section "Screen"
  3. Identifier "Default Screen"
  4. DefaultDepth 24
  5. EndSection
  6. EOF
Copy the code
then you should Add the following to /etc/rc.local
  1. service lightdm stop
  2. fbset -a -nonstd 1 -depth 32 -rgba 8/0,8/8,8/16,8/24
  3. service lightdm start
Copy the code
Posted at 1/9/2026 07:39:34
I find this article very valuable, and I've gained a lot from it. The N16302GC10 latest test pdf content is fantastic and free, and I hope it helps you.
Posted at 1/10/2026 16:49:55
The article gave me so many new ideas. The E-S4CON-2025 Examcollection questions answers exam is fast approaching. Hope I pass it!
Posted at 1/20/2026 05:43:14
I deeply appreciate your article, it was truly memorable. The New CCAAK test duration exam is right around the corner. Wish me luck!
