New Topic
[Linux] Ubuntu Gnome Linux is not working
54
Posted at 8/4/2022 17:36:15        Only Author  11#
Also, does your kernel source directory (in SDK) contains "ramdisk.img" file? If no, you should copy them from old version.
Posted at 8/4/2022 21:03:02        Only Author  12#
I also thought so, but there is no root pattern in my uboot vars. There is no RO pattern too. And there is no problem with similar uboot but booting debian. The problem is only with Ubuntu.
My printenv flie:
=> printenv
arch=arm
autoload=no
baudrate=1500000
board=evb_rk3588
board_name=evb_rk3588
boot_a_script=load ${devtype} ${devnum}{distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_extlinux=sysboot ${devtype} ${devnum}{distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=mmc1 mmc0 mtd2 mtd1 mtd0 usb0 pxe dhcp
bootargs=storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal  storagenode=/mmc@fe2c0000
bootcmd=boot_android ${devtype} ${devnum};boot_fit;bootrkp;run distro_bootcmd;
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_mtd0=setenv devnum 0; run mtd_boot
bootcmd_mtd1=setenv devnum 1; run mtd_boot
bootcmd_mtd2=setenv devnum 2; run mtd_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=0
cpu=armv8
devnum=1
devplist=3
devtype=mmc
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
eth1addr=da:d7:72:14:64:b7
ethaddr=d6:d7:72:14:64:b7
fdt_addr_r=0x0a100000
fileaddr=0xedf00000
filesize=0x1f34a
kernel_addr_c=0x05480000
kernel_addr_r=0x00400000
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
mtd_boot=if mtd_blk dev ${devnum}; then setenv devtype mtd; run scan_dev_for_boot_part; fi
partitions=uuid_disk=${uuid_gpt_disk};name=uboot,start=8MB,size=4MB,uuid=${uuid_gpt_loader2};name=trust,size=4M,uuid=${uuid_gpt_atf};name=misc,size=4MB,uuid=${uuid_gpt_misc};name=resource,size=16MB,uuid=${uuid_gpt_resource};name=kernel,size=32M,uuid=${uuid_gpt_kernel};name=boot,size=32M,bootable,uuid=${uuid_gpt_boot};name=recovery,size=32M,uuid=${uuid_gpt_recovery};name=backup,size=112M,uuid=${uuid_gpt_backup};name=cache,size=512M,uuid=${uuid_gpt_cache};name=system,size=2048M,uuid=${uuid_gpt_system};name=metadata,size=16M,uuid=${uuid_gpt_metadata};name=vendor,size=32M,uuid=${uuid_gpt_vendor};name=oem,size=32M,uuid=${uuid_gpt_oem};name=frp,size=512K,uuid=${uuid_gpt_frp};name=security,size=2M,uuid=${uuid_gpt_security};name=userdata,size=-,uuid=${uuid_gpt_userdata};
pxefile_addr_r=0x00600000
ramdisk_addr_r=0x0a200000
rkimg_bootdev=if mmc dev 1 && rkimgtest mmc 1; then setenv devtype mmc; setenv devnum 1; echo Boot from SDcard;elif mmc dev 0; then setenv devtype mmc; setenv devnum 0;elif mtd_blk dev 0; then setenv devtype mtd; setenv devnum 0;elif mtd_blk dev 1; then setenv devtype mtd; setenv devnum 1;elif mtd_blk dev 2; then setenv devtype mtd; setenv devnum 2;elif rknand dev 0; then setenv devtype rknand; setenv devnum 0;elif rksfc dev 0; then setenv devtype spinand; setenv devnum 0;elif rksfc dev 1; then setenv devtype spinor; setenv devnum 1;elsesetenv devtype ramdisk; setenv devnum 0;fi;
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}{distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}{distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}{distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}{distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x00500000
serial#=e84ddba3be4d1555
soc=rockchip
stderr=serial,vidconsole
stdout=serial,vidconsole
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
vendor=rockchip
Environment size: 4188/32764 bytes
arch=arm
autoload=no
baudrate=1500000
board=evb_rk3588
bootdelay=0
cpu=armv8
devnum=1
devplist=3
devtype=mmc
fileaddr=0xedf00000
filesize=0x1f34a
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
soc=rockchip
vendor=rockchip
Posted at 8/4/2022 21:04:13        Only Author  13#
I also tried to add rw to boot_prefixes var like this:
boot_prefixes=/ /boot/ rw
Posted at 8/5/2022 19:24:40        Only Author  14#
Everything is OK with the debian. DNS is easy to fix, language fixing in mk-base-debian.sh
GPU is working normaly - there is a lot of problem with the base videoplayer, but with MPV everything is OK - 2160@60 has good performance.
Thanks for everyone - the problem was solved
Return to List
12
